acepilot Samba Member
Joined: July 03, 2009 Posts: 20 Location: Bloomer, Wisconsin
Posted: Tue Aug 21, 2012 9:33 pm Post subject: Quad CHT gauge? |
| Does anyone make a quad CHT gauge (gauge in one standard 2-1/16" or 2-1/4" hole with 4 needles) for CHT monitoring of all 4 cylinders without any sort of switching needed? |
BDubVdub Samba Member
Posted: Tue Aug 21, 2012 10:14 pm Post subject: |
| Finding a quad gauge that small won't be easy. Westach makes a lot of quad gauges and actually has a 2" and 2.25" CHT gauge but they're almost $400 or more. |
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2916 Location: Virginia
Posted: Wed Aug 22, 2012 3:52 am Post subject: |
Yup saw that one...a bit pricey but probably worth it. The only thing wrong with it is its size...standard aircraft size (3-1/8") and would look out of place with my existing gauges. Besides the fact that it has a digital display and mine are all analog needle types... |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2377 Location: Mount Airy, Maryland
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3517 Location: Charleston, SC
Posted: Wed Aug 22, 2012 5:20 am Post subject: |
| acepilot wrote: |
The MGL TC-1 is 2 1/4" http://www.aircraftspruce.com/catalog/inpages/1105719.php
There are several display options. I have mine configured to display text, rather than the bar graph, and the 4 cylinders are organized on the display in the same way they are oriented on the engine:
Cyl 3 Cyl 1
Cyl 4 Cyl 2
which makes reading the gauge intuitive. Yeah, the gauge doesn't jive well with analog gauges, but I want to know my CHT when I look at the gauge; not fiddle around with a selector switch, or waste timing trying to figure out what the exact temp is or isn't from which graduation the needle is in front of, on, or behind.
Have you actually thought about how well you could read a 2 1/4" gauge that has 4 analog needles on it? If such a gauge existed, it would be all but worthless. Even the single and dual analog CHT gauges are typically restricted to 25 degree increments at best (the VDO CHT gauge is absolutely laughable in that regard). So, if you're looking for just a dash ornament that tells you when you're running too hot, you don't need 4 thermocouples, and an analog gauge will work just fine. If you want to know the actual temp for tuning your engine and cooling system, a digital gauge is what you'll need. _________________
| 66brm wrote: |
| Bodacious wrote: |
| Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
metalchomper Samba Member
Joined: June 27, 2005 Posts: 706 Location: Statesville, NC
Posted: Wed Aug 22, 2012 9:56 am Post subject: |
The MGL gauges are really trick. Haven't found anything comparable.
_________________ Brett
Devil Dog Dubs
I live vicariously through me
'62 Beetle, "Zombie Mojo"
'68 Manx II "Conundrum"
'72 SB "Luftwaffle", 2270 T4
'75 SB Wizard Rodster "Olympias" (Mrs. Metalchomper's car) |
krusher Samba Member
Joined: September 24, 2002 Posts: 7661 Location: europe
Posted: Wed Aug 22, 2012 10:38 am Post subject: |
So what temp differentials are you guys seeing across 4 cylinders? _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
