roy63 Samba Member
Joined: August 16, 2004 Posts: 1338 Location: Mechanicsville Va.
Posted: Wed Jan 01, 2014 10:26 am Post subject: |
EverettB wrote: |
You can also buy new ones, example:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111937037
I am considering doing this for one of my cars as a couple of the fuses get hot and I already cleaned up everything else and rebuilt the headlight switch and am still getting some voltage loss.
Or I may remove the entire fuse box and clean and solder every connection... this is what I did for the headlight switch.
I would never put in some modern fuse block, that makes me puke a little in my mouth just thinking about it. |
The WW is a good unit, but it does have 1 flaw, the push on termnials on the key / headlight switch are on the wrong side, you can make it work but it is backwards from the factory
Jon65:
Also you may want replace the wiring harness, as stated previously in the thread the wires will build up corrison between the indvidiual wires in the wire. that also will cuase amp draw and amp draw is heat which will cause voltage drop _________________ MyBuild http://www.thesamba.com/vw/forum/viewtopic.php?t=571921
Some day when the rust is gone, I will at last found inner peace... (Peace has Been Found)
"Wide awake, and keeping distance from my soul" |
payin_vw Samba Member
Joined: November 27, 2012 Posts: 117 Location: Colorado USA
Posted: Wed Jan 01, 2014 10:56 am Post subject: |
roy63 wrote: |
EverettB wrote: |
Jon65:
Also you may want replace the wiring harness, as stated previously in the thread the wires will build up corrison between the indvidiual wires in the wire. that also will cuase amp draw and amp draw is heat which will cause voltage drop |
the tabs can be rearranged if you want to, just use 2 thin flat screw drivers or similar tool to pray off the tabs that secures both fuse legs holders in place, this tabs are located on the side where the fuses go in. _________________ 61 work in progress restoration, more work than progress actually. |
grandpa pete Samba Member
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11057 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat May 07, 2016 5:17 am Post subject: Re: Modern fuse box conversion. |
^ too many years trucking Pete..
Circuit breakers while a good idea and have a place in some wiring systems are rough on small diameter wiring and low tension small terminals with a continued cycling short.
Even small amp circuit breakers must reach and maintain the amp rating before it heats the breaker to the tripping point.
Fuses open once an amp rating is reached protecting the circuit from damage
In general, only if a blown fuse is replaced with a higher amp fuse (or a breaker) will circuit damage occur
Advice, choose breaker locations and substitutions carefully. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sat May 07, 2016 7:44 am Post subject: Re: Modern fuse box conversion. |
VOLKSWAGNUT wrote: |
Advice, choose breaker locations and substitutions carefully. |
live and learn ; you are an asset to this community ; I was looking for you at Sevier ville ..... _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
kevlarian Samba Member
Joined: October 16, 2014 Posts: 636 Location: Orange County, CA
Posted: Sun May 22, 2016 8:47 am Post subject: |
Will someone explain to me where the actual FUSES go? I want to 'upgrade' my fuse box to this, but I fail to see WHERE the fuses go.
roy63 wrote: |
EverettB wrote: |
Jon65:
Posted: Sun May 22, 2016 7:47 pm Post subject: |
This is the business side... not the fuse side.....
In other words... if you want to "upgrade" you need to know which end is up...
kevlarian wrote: |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Sun Aug 23, 2020 6:59 pm Post subject: Re: Modern fuse box conversion. |
Anyone got a write up or pics of your install of the modern GM style fuse block on the left? Just the writeup or pics please, don't want to hear why you think the original fuses are better, Thx
_________________ 1963 Ragtop Bug |
DesignBuild Samba Member
Joined: September 29, 2016 Posts: 314 Location: TEXAS
Posted: Sat Feb 24, 2024 5:26 pm Post subject: Re: Modern fuse box conversion. |
Some of the fuse boxes on Amazon with the screw connections have buss bars instead of individual connections across the fuses. One has individual screw connections then the fuse but there is no connection from the fuse to the opposite screw connections.
I have a '72 Super Beetle and I replaced the 12 fuse block once but the side facing the interior where the fuses reside have very poor spring fuse connections. The OEM had actual brass or copper alloy flat springs with a hole to hold the torpedo shaped fuses. the new ones or reproduction 'springs' are no longer springs and some of my fuses fall out when I hit a pot hole or a joint in concrete pavement. Now the 12 fuse units are no longer available.
Years ago I owned a Saab 96 and the fuse box was similar to the VW using the torpedo style fuses, except it was located in the front engine compartment with a much more secure bakelite cover held in place with two knurled thumb screws. In addition the flat spring connectors to the fuses were on both sides and they were real springs, alloy steel with nickel plating. The nickel plating eliminated the corrosion aspect and the owner's manual suggested coating the contacts with petroleum jelly (vaseline).
Amazon has a new 12 way fuse block with male spade connections on both sides with modern fuses across the connections. Where needed I will jumper some of the connections together or fuse them separately. 8amps becomes 7.5amps and 16 becomes 15amps. The other option is to measure the current draw and use the appropriate fuse.
Talking about circuit breakers in automobiles, some American manufacturers didn't use many fuses but relied on circuit breakers. Over the years I have owned 3 Studebakers. The first was a 1958 Packard that had only one fuse in the car and it was for the radio. Everything else was on circuit breakers and the circuit breakers were completely enclosed. The second car was a 1951 Studebaker Champion Deluxe. I added an original radio and self lighting cigarette lighter. Both had individual fuses but everything else in the car was on circuit breakers. Oh, I forgot, the electric overdrive was on a slow blow 30 Amp fuse for the actuating solenoid. It was located high on the engine side of the firewall near the kickdown switch. Lastly, I owned a 1961 Studebaker Lark Regal 4-door sedan. It had only a fuse for the Air conditioning compressor clutch. Everything else was on the circuit breakers in the car and they were all located behind the dash, but at least they were all along the lower outside edge. If you knew where they were you could sit in the drivers seat and reach up along the bottom edge of the dash and feel them.
The only time I had a circuit breaker pop was when I was changing the headlight sealed beams in the '51 and accidentally grounded the high beam connector. I heard a pop sound from inside the car and them after a few minutes another ping and the headlight came on. Soon after I found an original factory shop manual and discovered all the electrical things that were on circuit breakers instead of fuses. Some circuit breakers were as small as 3 and 5 amps. The headlight circuits were on two 6V relays one for each side of the car and separate circuit breakers. The headlight switch was still working reliably 55 years after the car was built and I sold it off. On the '51 the smallest wire was 16 gauge. Only two instruments were electric; the gasoline and engine temperature gauges. The oil pressure was a bourdon tube with an 1/8" copper tube supplying engine oil pressure at the oil pump and the electrical charge function was an ammeter that showed the direction of current flow.
Regarding electrical failures I don't know how it would happen that the fresh air motor in my Super would be melted together when it was supposed to be on an 8amp fuse. The brushes are fused to the plastic holders and the motor armature windings are all burned. That should have poped an 8amp fuse long before all those parts fused together. It appears that the motor is not available anywhere anymore. |
Posted: Sat Feb 24, 2024 5:51 pm Post subject: Re: Modern fuse box conversion. |
This is the fuse block I have ordered. It has male spade style (6.3mm) connections on the sides with the fuses placed between the connections. The later Supers use 12 fuse boxes, though an additional 4 fuses would come in handy, plus something to hold the additional relays that should be used for the headlights, etc.
Here is a picture of what I am bought.
indianpeaksjoe Samba Member
Posted: Sat Feb 24, 2024 8:20 pm Post subject: Re: Modern fuse box conversion. |
I bought a modern fuse box conversion from Torque Resto Products, I went to install it in my 66 the other night and it doesn’t have the right amount of “blades” on the #8.
Now, I have no idea what is original or not. But, just wanted to share my experience.
-Joe _________________ Adventures in owning a 66 beetle |
Posted: Sat Feb 24, 2024 8:43 pm Post subject: Re: Modern fuse box conversion. |
Which is #8 on a 66 model? You could get a separate box for additional fuses, say for 4 circuits like the one I posted but with four instead of 12.
I looked at the diagram for 1966 and there are multiple connections at each end of the fuse box. |
Posted: Sat Feb 24, 2024 9:04 pm Post subject: Re: Modern fuse box conversion. |
On my current fuse block, #8 is drivers side, last fuse closest to the speedo. It has 3 prongs on the front side and 3 on the back. The Torque Resto one I bought only has 2 prongs on each side.
Cheers,
Posted: Sat Feb 24, 2024 9:22 pm Post subject: Re: Modern fuse box conversion. |
Joe, If #8 is on the right side (driver's side) then three of the wires could be joined into on female spade terminal, The wire going to the brake switch, the wire going to the horn, and the wire going to the 54 connection on the wiper switch could be joined to one female spade terminal since they are all 1. 0 sq.mm. That takes care of 3 wires. Then you have the one additional wire going to the 15 terminal on the flasher relay. It would have its own female spade terminal. That takes care of the wires and uses only 2 male spade terminals.
You could also take apart the OEM block and use the male spade terminals to build up the number of terminals on the new block, but remove the new spade terminals from the new block before soldering the additional spade terminals to the new ones. The buildup of heat could damage the new block.
Then there is this option too.
https://www.amazon.com/RED-WOLF-Automotive-Distribution-Damp-Proof/dp/B0BK18QTMW/ |
Posted: Sat Feb 24, 2024 9:32 pm Post subject: Re: Modern fuse box conversion. |
On my '72 Super Beetle #1 is closest to the speedometer and #12 is on the opposite end.
On yours, I gave a description of what you could do besides adding the spade terminals from the original. You could use plumbers flux and high tin solder to join the old and new spade terminals. I suggest the high tin material because the high tin solder is harder than the old type. Using the separate flux will enable you to sweat the parts together where the solder will wick between the contact surfaces. You could also add a tiny screw to the middle of the connections. |
OldSchoolVW's Samba Member
Posted: Sat Mar 23, 2024 8:37 pm Post subject: Re: Modern fuse box conversion. |
indianpeaksjoe wrote: |
-Joe |
I just installed this in my '63. The blade number/configuration was identical to the original, so worked perfectly. I appreciate that Dave was happy to provide/preload the fuses to match the needs for my application. VW seemed to like moving the fuse wiring around from year to year, so I could see where some years would need more blades on certain circuits than other years. I imagine a piggyback connector would be the simplest way to add a blade if needed.
_________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sat Apr 20, 2024 4:42 pm Post subject: Re: Modern fuse box conversion. |
-Joe |
I just installed the Torque Resto Products fuse box into my ‘66 convertible. Hassle free install, went right in. Best part, not mentioned on the web site https://www.torquerestoparts.com/product-page/61-66-beetle-ghia-blade-fuse-box is that the OEM plastic cover fits right into place!
As for indianpeaksjoe problem he mentions above, the Torque Resto fuse box has the exact same number of tabs as factory OEM. What the factory did was install a 1-2 spade terminal adapter (Y splitter) to accommodate the proper amount of tabs required _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
