scottjk Samba Member
Joined: May 31, 2006 Posts: 485 Location: Salt Lake City, UT
Posted: Fri Nov 16, 2012 7:11 am Post subject: Subaru Engine Owners - Critical Bulletin |
I received this from a fellow Subaru owner.
http://www.gates.com/australia/downloads/download_...n_id=18884
This is a .pdf from the Gates Corporation. If you don't want to open this file just Google search 'Gate Subaru Timing Belt Clearance. _________________ 1985 Westfalia 2.5L EJ |
wasserbox Samba Member
Joined: April 08, 2008 Posts: 533 Location: Durango, CO
Posted: Fri Nov 16, 2012 8:38 am Post subject: |
Good to know.
Thanks for posting it. |
insyncro Banned
Posted: Fri Nov 16, 2012 9:35 am Post subject: |
My new EZs have chains
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Fri Nov 16, 2012 11:49 am Post subject: |
Interesting info, thanks for posting. It should be noted that only manual trans Subaru engines came with that guide.
None of my EJ engines have that belt guide, not even my JDM EJ20G came with it, and that engine was mated to a 5MT. My understanding is that it was for manual transaxle cars only, and the problem it solves was the belt slipping off when the trans was left in gear for the boat ride over. The back and forth rocking would cause the belt to skip a tooth. My EJ20G has a redline of 7400 RPM and it's fine without the guide.
So I guess you could leave it on and space it off with the special tool. Or if you aren't planning any long boat rides just remove the guide altogether. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Fri Nov 16, 2012 12:00 pm Post subject: |
| presslab wrote: |
| My understanding is that it was for manual transaxle cars only, and the problem it solves was the belt slipping off when the trans was left in gear for the boat ride over.. |
Interesting.. So not a problem for the 3.3s either? _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
| danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Fri Nov 16, 2012 3:12 pm Post subject: |
I did my adjustment with the engine on the stand after rebuild and verified it after tightening the bolts. I do like that gauge plate they made to set the gap.
I believe the purpose of the plate was for miss-shifts as it is only on manual transmission engines. So if hot rod guy missed his 1st to 2nd shift it would keep the timing belt in place before the rev limiter kicked in. _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
Posted: Fri Nov 16, 2012 3:41 pm Post subject: |
| j_dirge wrote: |
| Interesting.. So not a problem for the 3.3s either? |
None of the EG33 engines I've seen have this guide. It's not listed in the parts manual either.
http://opposedforces.com/parts/svx/us_c12/type_5/engine/camshaft_and_timing_belt/illustration_2/
The rocking of the boat makes sense to me. Rotating the engine backward would pull the timing belt backward; this will slacken the tensioner. When rotating forward again the timing belt will be loose and could easily jump a tooth. The tensioner responds very slowly and won't be able to take up the slack soon enough.
I've bounced my EJ25 off the rev limiter many times; and I actually raised the limiter a bit. The engine doesn't rev any higher than the limiter, it keeps the RPMs in check. However a bad downshift could certainly over-rev the engine, but I can't think off the top of my head how the timing belt will jump in this scenario. _________________ 1986 Vanagon Westfalia EJ25
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
tschroeder0 Samba Member
Joined: April 14, 2008 Posts: 2098 Location: Boulder CO
Posted: Mon Nov 19, 2012 9:46 pm Post subject: |
this makes me sick...I just got my engine back together with that guide and did not know anything about this BUT I did notice some wear in the mentioned area..shit
shit, shit, shit
Let me tell you a story of how an engine swap has ruined one guys love affair with his van... |
Racerrojo Samba Member
Joined: August 01, 2006 Posts: 827 Location: ALBUQUERQUE 87120
Posted: Mon Nov 19, 2012 9:57 pm Post subject: |
| tschroeder0 wrote: |
shit, shit, shit
patience, once you get to drive it the love will rekindle _________________ Tight is tight... too tight is expensive!!!!
Too many vans and mostly all projects  |
Posted: Tue Nov 20, 2012 6:11 am Post subject: |
shit, shit, shit
I'm in the same boat, actually just added the guide as recommended by my conversion mechanic when I replaced my water pump, but look at it this way... the EJ25 is much easier to work on than the WBX. Shouldn't take more than a couple hours to pull the timing covers off and either remove or check the clearance. I'm going to remove mine all together. _________________ 1985 Westfalia 2.5L EJ |
Posted: Thu Nov 22, 2012 3:58 am Post subject: |
Hey scott,
Here is what i did so i did not have to take everything apart. Remove the front pulley
find something about 3 inches in diameter trace a nice circle and use a dremmel to cut out a nice circle around the interior crank pulley, be careful not to go deep. Then remove the guide, the bigger hole will be covered by the pulley. |
kalispell365 Samba Member
Posted: Sun Nov 25, 2012 8:55 am Post subject: |
| the guide mentioned here is made to keep the manual transmission cars from jumping time when shutting off,NOT just for shipping.as a subaru tech i have seen many a manual trans outback jump time when this was left off...you can set them at the spot with the most space possible between them and the timing belt and they work great,no need to measure. |
Posted: Sun Nov 25, 2012 9:40 am Post subject: |
While not trying to question a real suby tech, I can tell you my guide was at the highest point and I was getting some significant discoloration right where it would touch, even thou I could rotate the engine and it had clearance. So it was obviously touch at some point when running.
My question is, is,it normal to see wear on theses, even when adjusted correctly?
Thanks
Todd |
Posted: Sun Nov 25, 2012 9:42 am Post subject: |
| kalispell365 wrote: |
| the guide mentioned here is made to keep the manual transmission cars from jumping time when shutting off |
Like if someone stalls the engine by letting out the clutch? Otherwise with clutch in or in neutral how is a manual trans different than an automatic here? _________________ 1986 Vanagon Westfalia EJ25
Vango Conversions Samba Member
Joined: October 04, 2010 Posts: 1054 Location: Seattle, WA
Posted: Sun Nov 25, 2012 10:05 am Post subject: |
It's super easy to adjust on a stand, but in the car you might need a mirror to adjust it.
I haven't sen any problems with leaving it off. Most of the motors come from auto cars so they don't even have it. Never seen a problem on any conversions.
Kind of seems like it's just better to leave it off. Just make sure your tensioner is in good shape. |
connorsvw2 Samba Member
Joined: August 16, 2008 Posts: 361 Location: Denver, CO
Posted: Sun Nov 25, 2012 11:50 am Post subject: |
Seems like the easiest thing for those of us with the guide installed is to pull the right hand TB inspection cover and check the back of the belt for unusual wear patterns. I installed mine on the stand with careful spacers installed (I used drill bits of appropriate thickness as shims). _________________ '85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car) |
Posted: Sun Nov 25, 2012 12:49 pm Post subject: |
| presslab wrote: |
Like if someone stalls the engine by letting out the clutch? Otherwise with clutch in or in neutral how is a manual trans different than an automatic here? |
Presslab,correct...thank you for explaining it better than i did.i was half asleep.it shouldnt rub if you are using a genuine belt.if it does,just bend it slightly.i am in no way trying to convince anyone to use it,just explaining why it is there...unlike the germans,the japanese dont tend to add something for no reason. |
