GetPsycho Samba Member
Joined: February 14, 2004 Posts: 1440 Location: The Frayed Ends of Sanity
Posted: Sun Jun 16, 2013 6:24 pm Post subject: Back of headlights? |
Do I need to be concerned about the back
side of the headlights being exposed? It
just seams to me like it might cause problems
with water/mud splashing all over the back of
the socket/assembly? _________________ SOME MORNINGS IT'S JUST NOT
WORTH CHEWING THROUGH THE
LEATHER STRAPS!! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20382 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jun 16, 2013 8:37 pm Post subject: |
Probably not a really good idea,. but its not going to keep them from working until corrosion sets in to a point the metal starts corroding really bad.... Liberal coating of dielectric grease would protect them from electrical standpoint...
Posted: Sun Jun 16, 2013 9:14 pm Post subject: |
So, should I try to figure out some way to
close them in? Any suggestions or ideas? _________________ SOME MORNINGS IT'S JUST NOT
LEATHER STRAPS!! |
pafree Samba Member
Joined: August 16, 2005 Posts: 2298 Location: dayton, the one in texas
bartman Samba Member
Joined: February 22, 2004 Posts: 767 Location: palatka, fl
Posted: Mon Jun 17, 2013 4:09 pm Post subject: |
Mine were open at the back when I bought my baja in 1999 and are still open. Never had a problem. _________________ Remember, kids------> KCR Transmissions SUCKS |
Posted: Mon Jun 17, 2013 4:13 pm Post subject: |
Do you use dielectric grease? _________________ SOME MORNINGS IT'S JUST NOT
LEATHER STRAPS!! |
thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Mon Jun 17, 2013 6:31 pm Post subject: |
I use a pair of 1971 Renault R10 headlight assemblies. They have nice steel buckets behind the sealed beams.
The lights are protected from things sliding around inside the trunk.
_________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
Posted: Mon Jun 17, 2013 6:48 pm Post subject: |
GetPsycho wrote: |
Do you use dielectric grease? |
No, never even thought of it.
Even stock buckets aren't watertight. I never really though it was much of an issue. _________________ Remember, kids------> KCR Transmissions SUCKS |
Bad Hippie Samba Member
Posted: Thu Jun 20, 2013 2:01 pm Post subject: |
Empi makes and just about everyone sell a plastic "Baja Headlight Bucket." They are enclosed on the back side. They were installed on my car when I first got it. Both were destroyed in the wreck so I just replaced them with new Empi units. The only issue I've had is it doesn't seem like you can adjust the light down towards the road enough. I'm not sure if it's the buckets, or how my fenders are positioned. I've ended up installing spacers to aim the lights both before and after the wreck.
I think my main concern with an open bucket would be (if the lights are in the fenders) breaking the back of the bulb with a rock from the tire. Other than that a liberal coating of DC4 dielectric grease would keep the contacts operating. |
Posted: Thu Jun 20, 2013 4:41 pm Post subject: |
Yeah, mine are in the fenders.
Rocks flipping up are my biggest concern.
I might just put some heave mesh arcoss the back. _________________ SOME MORNINGS IT'S JUST NOT
LEATHER STRAPS!! |
Posted: Thu Jun 20, 2013 8:39 pm Post subject: |
Here are the Empi buckets on my car.
If you look closely you can see the spacers I added between the bucket and the fender. The units come with chrome trim rings which I have not mounted with this set. Being that cheap Chinese chrome it will likely rust and pit within a week anyway. The units also come with a short three prong wiring harness, but no bulbs. They are no too expensive either. $25 - $30 each depending on who you get them through
I know a lot of folks around these parts aren't really happy with the quality of Empi parts over the last few years (after seeing the quality of my replacement double tube front bumper, I may be on the way to becoming one of them) at least I was happy enough with my old buckets to replace them with new Empi ones.
Having said that they will now probably fall off, blow up or give me some form of cancer.
Oh well, it's not an endorsement, just an option. |
Posted: Fri Jun 21, 2013 12:03 pm Post subject: |
How about some plastic bowls for 99 cent store...
