RDAY Samba Member
Posted: Mon Jan 28, 2013 8:06 am Post subject: |
[quote="krydan"]
<p>
How did u route the wires up to the dash on here did u built it yourself? What's it made out of? What gauges switches and lights do u have? Looks like alot lol |
under construction Samba Member
Posted: Tue Jan 29, 2013 10:46 am Post subject: |
tsj5677 Samba Member
Joined: December 12, 2012 Posts: 126 Location: Springfield MO
Adrenaline Junky Samba Member
Joined: April 11, 2006 Posts: 274 Location: Roseville, CA
Posted: Thu Jan 31, 2013 7:35 pm Post subject: |
That's thing is interesting for $90. A set like mine was like $375 from egauges.
Huffypilot Samba Member
Posted: Sun Feb 03, 2013 2:08 am Post subject: |
Im yet to test these out but the important thing is they look cool. lol
Standard dash is running VDO classic gauges and the microtech will handle EFI and engine monitoring. Best of both old and new school I hope...
[/img]http://www.thesamba.com/vw/forum/album_search.php?search_author=Huffypilot
[/img] |
northstarbeetle Samba Member
Joined: February 06, 2009 Posts: 160 Location: golden co
Blackoutt Samba Member
Joined: March 03, 2012 Posts: 240 Location: Waterford, MI
Posted: Fri Mar 01, 2013 1:55 am Post subject: |
Let me know what you think of that ultra gauge. It seems like a cheaper version of a dashhawk. I'm curious to know cause that's a nice clean easy set up for gauges. |
LatheLizard Samba Member
Posted: Sat Mar 02, 2024 11:06 am Post subject: Re: Lets see ur gauges |
Came to post some pic. Just built gage panel (machinist). Never seen forum thats so incredibly difficult to do a lot of things, posting new pics being one. |
Wulfthang Samba Member
Posted: Sat Mar 02, 2024 8:20 pm Post subject: Re: Lets see ur gauges |
This is the main panel out of my Rat Rod Trail Rail.
Here it is in the car.
It also has a smaller panel mounted on the shifter.
Gauges are oil temp, water temp, oil pressure, vacuum and voltage. There's a tach on the steering column and a GPS speedo on the overhead. The oil temp and water temp are the same gauge with a switch to select between the two sensors.
indianpeaksjoe Samba Member
DesertSasquatchXploration Samba Member
Posted: Tue Mar 05, 2024 10:22 pm Post subject: Re: Lets see ur gauges |
indianpeaksjoe,
That's all you need nothing changed in the last 50 years worked then works now.
I run dual idiot lights wired in parallel just to be safe. If the lights are off and I have fuel were good to go. Keep your eyes on the trail and take mental notes of mountain ridgebacks the shape and color. Also the direction of the sun, If its in your eyes heading out it better be in your eyes coming back vise versa. Basic common sense.
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1059 Location: St. Louis
Posted: Wed Mar 06, 2024 6:13 am Post subject: Re: Lets see ur gauges |
Aluminum extrusion, machined out with laser cut panels bolted to it to hold the gauges.
90% of the car's complex wiring contained within the dash for an extremely clean car frame.
And now with the fake carbon fiber overlay
_________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
PhillipM Samba Member
Posted: Wed Mar 06, 2024 9:31 am Post subject: Re: Lets see ur gauges |
Same idea, all the wiring for the ECU/Fusebox and controls are self contained in the dash - it just has two plugs at one end and the whole lot removes with the dashboard:
Dan_Lockwood Samba Member
Joined: October 03, 2023 Posts: 189 Location: Clare MI
Posted: Wed Mar 06, 2024 10:18 am Post subject: Re: Lets see ur gauges |
How do you guys reach your dash for all the buttons/switches when in a harness? Do you loosen up every time you need to lean forward?
Thanks, Dan |
Posted: Wed Mar 06, 2024 10:28 am Post subject: Re: Lets see ur gauges |
I love all the different ways people are approaching this.
Some of the solutions are just awesome.
Have a great drive all.
-Joe _________________ Adventures in owning a 66 beetle |
Posted: Wed Mar 06, 2024 1:30 pm Post subject: Re: Lets see ur gauges |
Dan_Lockwood wrote: |
Thanks, Dan |
The buttons are reachable with harnesses on, but it's setup so basically you don't really need to hit anything once it's set anyway for mine.
It's autodimming on the screen and it runs light sensors for headlight pods in the dark if they're fitted, etc, so they're automatic as are the running lights at the rear. The screen changes depending on if any readings are in a warning zone or flashes lights if needed for anything that's an emergency, the power steering automatically adjusts itself for speed and idles itself when the car is stood, rad fans automatically adjust their speeds to temperatures, etc.
The adjustment knob on the left is for launch control so you only really need to hit that once and the one on the right is for brake bias which only really needs a tweak between stages. |
Posted: Wed Mar 06, 2024 3:30 pm Post subject: Re: Lets see ur gauges |
Thanks, Dan |
I have a smaller switch panel mounted on my shifter that has a start/stop switch, horns, a Super Cool switch to spray water on the radiator and the Bush Cruiser switch, my offroad cruise control.
Everything else is pretty much automatic but if I want to over ride that, I have a metal rod with a wire loop on the end to reach the switches while strapped in. |
Schepp Samba Member
Joined: March 22, 2020 Posts: 78 Location: Petaluma, CA
Posted: Thu Mar 07, 2024 10:21 am Post subject: Re: Lets see ur gauges |
Tried to keep it simple.
Had the kid who owned the car before me hadn’t cut a gaping hole in the dash to fit a 30$ shit stereo I likely wouldn’t have done it this way.
I think it turned out pretty good.
Marshall gages are backlit LED.
RAILFUN Samba Member
Joined: September 21, 2017 Posts: 16 Location: South West Michigan Benton Harbor/St. Joseph
Posted: Thu Mar 07, 2024 11:16 am Post subject: Re: Lets see ur gauges |
Here is what I have for my gauges.
Tach, speedo, oil temp, oil pressure, fuel air, fuel ratio, amps |
