fi timing on 75 super
Rex lucy
Rex lucy is offline
PostPosted: Fri Mar 15, 2013 8:00 pm    Post subject: fi timing on 75 super Reply with quote
I have found something i don't grasp well. I purchased a boxed super . in the boxes i find a normal dissy and upon checking the book wiring diagram i see reference to a "flywheel position sensor". cannot find any parts that look like a flywheel sensor nor does the flywheel look different from any other.is this how the fi is timed or do i not have the correct dissy. checking the wiring harness i don't find the triple dissy plug the t-3 has. My firset fi super. ANY HELP PLS.
i JUST READ THE EFI-1 MANUAL AND STILL SHAKY.
70 T3 69 T-3 74 THING 75 VERT 57FORD
Tim Donahoe
Tim Donahoe is offline
PostPosted: Fri Mar 15, 2013 10:35 pm    Post subject: Reply with quote
I don't know much about fuel injection, but I suspect the "Flywheel Position" item is merely a gig for the old computer analysis thing they used to plug into your car to test things.
Tim
airschooled
Air-Schooled
airschooled is offline
PostPosted: Fri Mar 15, 2013 11:03 pm    Post subject: Re: fi timing on 75 super Reply with quote
Hi there-
The flywheel position sensor is for using the old VW computer analysis that is practically non-existant now. Don't worry about it now, as the diagnostic plug is probably gone and the wires are likely gone.
A normal timing light shines a light on the pulley in the back and we adjust the dizzy to time it. On the VWCA, there was a sensor on the other side of the engine so the technician could read the timing on the computer. With or without it, it doesn't change the way you will time it. Use a light, set it to 28-30 btdc, (hoses off) and enjoy.
www.airschooled.com
Road trip reports and tech blog:
airschooled
Air-Schooled
PostPosted: Fri Mar 15, 2013 11:04 pm    Post subject: Re: fi timing on 75 super Reply with quote
duplicate post deleted
www.airschooled.com
ashman40
ashman40 is offline
PostPosted: Sat Mar 16, 2013 1:50 am    Post subject: Reply with quote
On the Beetle, this sensor was installed in the right hand side of the case on the raised flange that is the front of the case:
It was a magnetic induction unit that would sense the steel pegs in the rear face of the flywheel:
As others have suggested, it was part of the diagnostic block and is no longer used. The only reason to keep it would be to maintain 100% authenticity.
AshMan40
Rex lucy
Rex lucy is offline
PostPosted: Sat Mar 16, 2013 10:03 am    Post subject: Reply with quote
thanks for the help. thats what i like about the samba,always someone to help. rex
