First timer with a build that doesnt run yet
TSFR
TSFR is offline
PostPosted: Sun May 19, 2013 5:52 pm    Post subject: First timer with a build that doesnt run yet Reply with quote
Hello everyone, I'm Jeff and I have just taken delivery of this 1968 VW Dune Buggy. I knew it wasnt running when I got it and figured at worst case we would just rebuild the motor. I won it off eBay of all places LOL!
Here it is, although I'm not really sure what it is. I looked on the registry but couldnt find a complete match.
I do know that under the flat black is purple and under that is the (I think) the factory red flake.
Well, the motor does in fact, not run. Sad In fact it will not even turn over. Once I got the rear bar dropped out of the way I tried again and was only able to tighten the bolt Rolling Eyes
The motor is/was a 1835 GEX? block pushed out to 1904 with a Weber 38mm progressive carb (thats what I measured) with electric fuel pump and a regular distributer so I guess I dont have to worry about points.
Are there supposed to be this many jumper wires? Is this normal for old VW's or am I just expecting too much?
The wiring is kindof a mess too....Is it a bad sign when wires from sides of the battery are red? LOL Either way, I think I can clean it up a little bit.
It has sat for about 5 months and seems pretty locked up. I pulled all the spark plugs and none of them were rusted or anything so....Now I'm gonna start reading up on the motor to get ready for a rebuild I guess. I'm going to try some lube in the jug as a last ditch effort as I've read on here. I'll let y'all know how that works out.
Any suggests or comments are welcome.
Thanks,
Jeff
bowtiebug
bowtiebug is offline
PostPosted: Sun May 19, 2013 5:57 pm    Post subject: Reply with quote
good looking buggy .
It appears from the photo of the fan shroud that the heater outlets are NOT plugged off ( is that the case ? ) if so that explaines whay it wont turn , most likely over heated and siezed up ..
http://www.etsy.com/shop/AlphaKnots
TSFR
TSFR is offline
PostPosted: Sun May 19, 2013 6:05 pm    Post subject: Reply with quote
Thanks! Its the style I was looking for.
What you see is exactly how I received it. The PO had the motor built under scandel so it wouldnt surprise me. If the outlet is plugged how does it get air flow? or is it not supposed to? If its siezed, whats my next step?
bowtiebug
PostPosted: Sun May 19, 2013 6:08 pm    Post subject: Reply with quote
the two holes pointing out of the fan shroud just above each intake , they are for heater connections and in your case should be plugged off so air is forced over cylinders instead of wasted away ,
if it is seized you will most likely need new Pistons and cylinders .
TSFR
TSFR is offline
PostPosted: Sun May 19, 2013 6:20 pm    Post subject: Reply with quote
What do you plug the hole with? Is the GEX block (is that even right?) still a good starting point? Is there a recommended place to look for parts?
Thanks for all the help!
bowtiebug
PostPosted: Sun May 19, 2013 6:25 pm    Post subject: Reply with quote
i'm not sure of the size but you can get freeze plugs and install them in the holes with clamps or tack weld them in .
GEX is a rebuilder of engines .
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Sun May 19, 2013 6:30 pm    Post subject: Reply with quote
Remove plugs and put some Mystery oil in each cylinder. Let it sit a few days then try to turn it over. Often works to loosen frozen rings up.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
manxdavid
Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
manxdavid is offline
PostPosted: Mon May 20, 2013 1:24 pm    Post subject: Reply with quote
If you get it running the first thing you want to do is to change the fuel hoses, they look plastic and nasty! That fuel filter isn't in the best of places either.
The carb looks like a 32/36 dual progressive Weber.
TSFR
TSFR is offline
PostPosted: Mon May 20, 2013 1:32 pm    Post subject: Reply with quote
I cant find weber on it anywhere...I will snap a picture after work, but both barrels look the same and I measured the inside of them both at 38mm inside to inside. they both look to be the same size, maybe I measured the wrong way.
What kind of tubing should I look at?
Thanks for the advice everyone, I will be needing lots of it. Right now I'm reading the dune buggy handbook that I managed to find at the library.
manxdavid
PostPosted: Mon May 20, 2013 2:33 pm    Post subject: Reply with quote
Have a look on top of the float chamber, you may need to remover the airfilter.
jspbtown
jspbtown is offline
PostPosted: Mon May 20, 2013 3:16 pm    Post subject: Reply with quote
Read about GEX engines in the Buyer/Seller feedback section.
Dale M.
Dale M. is offline
PostPosted: Mon May 20, 2013 5:46 pm    Post subject: Reply with quote
GEX or not first thing is to see if you can unstick it.... IF not open it up.... Unless inside it total disaster, you probable can salvage most of it....
Dale
TSFR
TSFR is offline
PostPosted: Mon May 20, 2013 5:50 pm    Post subject: Reply with quote
here is the carb...they look the same unless I'm looking at it wrong.
TSFR
TSFR is offline
PostPosted: Mon May 20, 2013 6:03 pm    Post subject: Reply with quote
and the Mystery oil has been added. Guess now its a waiting game
TSFR
TSFR is offline
PostPosted: Mon May 20, 2013 6:20 pm    Post subject: Reply with quote
Shocked So I see the GEX is an upstanding christian company with outstanding morals and amazing customer service.... Rolling Eyes
Dale M.
Dale M. is offline
PostPosted: Mon May 20, 2013 7:52 pm    Post subject: Reply with quote
NO... They are not the same.... The devil is in the details... Ignore the fact it has 2 square ventures and look at other details...
Pull air cleaner plate off and see if there is any name under it...
Dale
TSFR
TSFR is offline
PostPosted: Tue May 21, 2013 7:52 am    Post subject: Reply with quote
Not sure what it is, but it does appear to be progressive and have an electric choke.
On the bowls it says 26 and 27
Any ideas?
TSFR
TSFR is offline
PostPosted: Tue May 21, 2013 7:58 am    Post subject: Reply with quote
Also is the bottom number on the block a casting number? I'm not even sure what it is anymore...
After reading all the reviews, even if the mystery oil works I'm going to pull the motor and do a complete rebuild anyway just to see/know what I have and whats going on. If those are not case numbers, when I find them should be 123A and 123B or 123 and 124? Just trying to find a path to follow. Thanks again for all the help.
My end game is to have something reliable which on occasion will pull up the front end. Cool
Dale M.
Dale M. is offline
PostPosted: Tue May 21, 2013 4:16 pm    Post subject: Reply with quote
The "AB" number on case makes it a universal replacement case, 66-79, 1600cc, could be from Mexico, Brazil or Germany...
After GEX had a hand in it, no telling what is now...
Dale
andk5591
andk5591 is offline
PostPosted: Tue May 21, 2013 6:00 pm    Post subject: Reply with quote
OK - lets back up a sec - Motor wont turn over means what? You turn that key and nothing happens or it cranks and doesnt start? Big difference, If it doesnt crank. - first make sure that your have power to the starter. Now - look at the starter a little closer. I am assuming that you have a good battery and the cables are connected.
You will see a big heavy wire held on with a nut and a small wire that is a slip on connection. Make sure the car if not in gear and you should block the wheels. Take a screwdriver and jump across the big and small terminals. If it cranks, then you have an issue with the wiring or ignition switch.
Post where you are with things and then we can go from there. Be clear in your descriptions.
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
Page 1 of 8
