Ferguson Samba Member
Joined: October 23, 2010 Posts: 433 Location: Avon, Indiana
Posted: Thu Sep 12, 2013 6:34 pm Post subject: Power windows installed in my 72 Beetle |
I thought that I had posted this but I never did, just thought some of you might like to see the power windows I installed, I was still putting the car back together when we made the video, here is a link to it on youtube
_________________ (o)\!/(o) Proud owner of a 1972 Beetle, 72 Super Beetle, 76 convertible Beetle and a 69 Fastback
www.CCVW.org |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2482 Location: Gladstone, Ore
Posted: Thu Sep 12, 2013 7:01 pm Post subject: |
I can admire your ingenuity while knowing I would never do it myself, good job. _________________ 1972 1302
HPMX 40's & 019 |
Posted: Thu Sep 12, 2013 7:07 pm Post subject: |
Thanks cletus, my buddy was joking when he said I should make the radio control the windows, but I kinda got bored one night and made it all work _________________ (o)\!/(o) Proud owner of a 1972 Beetle, 72 Super Beetle, 76 convertible Beetle and a 69 Fastback
www.CCVW.org |
olmer2 Samba Member
Joined: June 28, 2009 Posts: 781 Location: chattanooga TN
Posted: Fri Sep 13, 2013 10:06 am Post subject: |
Thanks olmer, it is something that I haven't seen done to another car for sure , also thanks to whoever fixed the link for the video _________________ (o)\!/(o) Proud owner of a 1972 Beetle, 72 Super Beetle, 76 convertible Beetle and a 69 Fastback
www.CCVW.org |
superdude72 Samba Member
Joined: January 18, 2012 Posts: 244 Location: United States
Posted: Fri Sep 13, 2013 12:04 pm Post subject: |
| What power window kit did you buy? |
Posted: Sun Sep 15, 2013 9:12 am Post subject: |
| Thanks! How hard was it to install? It looks pretty intricate. |
Posted: Sun Sep 15, 2013 9:27 am Post subject: |
installing the window motors and running the wires was pretty easy, if you buy the switches made for the window kit you pretty much just run the wires and hook up power, ground and the illumination wire, the way I did mine took me a couple of hours, and that was installing everything and modifying the radio _________________ (o)\!/(o) Proud owner of a 1972 Beetle, 72 Super Beetle, 76 convertible Beetle and a 69 Fastback
www.CCVW.org |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sun Sep 15, 2013 2:22 pm Post subject: |
Probably a bit late now but what I did when I installed mine to stop the spindles sticking through the door panels was open up the mechanism and spin it all around so the spindle faced inside the door instead.
Posted: Sun Sep 15, 2013 2:52 pm Post subject: |
Joel I am already working on that part, thanks to seeing how you did yours, I have an extra set of regulators that I have been working on switching around just working on it when i have time _________________ (o)\!/(o) Proud owner of a 1972 Beetle, 72 Super Beetle, 76 convertible Beetle and a 69 Fastback
www.CCVW.org |
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
Posted: Mon Sep 16, 2013 2:39 pm Post subject: |
if you look at it you can see a connector that pinches the two pieces together, I drilled those out but I haven't started putting it back together yet I will probably just use a short boltand a nut and assemble it back together with those _________________ (o)\!/(o) Proud owner of a 1972 Beetle, 72 Super Beetle, 76 convertible Beetle and a 69 Fastback
www.CCVW.org |
Joel Samba Member
Posted: Mon Sep 16, 2013 3:26 pm Post subject: |
| I'll get a pic of mine later, I just used big rivets either 5/32 or 3/16 ones. |
