Anyone store their Bug in a shed with 72" door opening?
Lucky Lager
Lucky Lager is offline
PostPosted: Sat Oct 05, 2013 6:14 pm    Post subject: Anyone store their Bug in a shed with 72" door opening? Reply with quote
My friend (hes not local) tells me he has a shed 12' wide 16' deep (9' high walls) with double doors measuring a 72" (6') when open. He says he has no problem going in or out. Anyone else have this set up? HE exaggerates from time to time....hoping someone here would know or have a pic. I want to build a shed just for the VW (running out of room in garage) and if I can get away without buying a roll up door and just construct a 6' double door opening, ill do it. Thanks
I have a 59. as it measures it should work......but is it a hassle?
In the wild, health care is, Ow, I hurt my leg. I can't run. A lion eats me. I'm dead.
esde
esde is offline
PostPosted: Sun Oct 06, 2013 6:28 am    Post subject: Reply with quote
I have rolled my bug through 6' doors, though the fenders were off. Tight. Not sure I'd want to do it often or by myself
Lucky Lager
PostPosted: Sun Oct 06, 2013 6:41 am    Post subject: Reply with quote
What's your exact measurement in width as yours sits now?
bowtiebug
bowtiebug is offline
PostPosted: Sun Oct 06, 2013 7:16 am    Post subject: Reply with quote
I wouldn't take a chance on a 6 ft door opening even if it fits there is no room for error , instead I would build 2 4ft door that swing open , Shed style doors for 8ft clearance .
http://www.etsy.com/shop/AlphaKnots
slalombuggy
slalombuggy is offline
PostPosted: Sun Oct 06, 2013 7:23 am    Post subject: Reply with quote
The deck on my trailer is 6' wide. I've rolled my 57 with 1.25" wider rear fenders and a wide Bugpack flip front end on it a few times. It's tight but doable. But I gotta pay attention to everything when loading.
If you're building it from scratch, I'd go wider even 7' would be lots.
brad
joe56vw
joe56vw is offline
PostPosted: Sun Oct 06, 2013 9:30 am    Post subject: Reply with quote
I would be more concern with the width inside the shed since you will need to get in and out of the car to drive it
how much room inside will you have to open the door
'60 15 window walkthrough
why is there no sarcasism button on here?
bowtiebug
PostPosted: Sun Oct 06, 2013 9:39 am    Post subject: Reply with quote
12' wide will be plenty to get in and out , that leaves 3' on each side if centered more if moved to one side ..
Lucky Lager
PostPosted: Sun Oct 06, 2013 10:24 am    Post subject: Reply with quote
Thanks everyone, Im building a 14x20. I was trying to just save quite a bit on the roll up door and build typical 72" double doors(I really don't like going bigger than that on swing doors) Plus it looks a little nicer..... I may just quit being a pud and do an 8' roll up. already spent $300 for 4 windows Smile
joe56vw
joe56vw is offline
PostPosted: Sun Oct 06, 2013 12:08 pm    Post subject: Reply with quote
get this kit for the door then you won't have to worry about the doors being to big
it has a adjuster on it to help keep it from sagging over time and adjust the sag out of it if it does sag after a few years
http://www.homedepot.com/p/Adjust-A-Gate-2-Rail-Ga...lG0oZrn9jo
Lucky Lager
PostPosted: Sun Oct 06, 2013 3:25 pm    Post subject: Reply with quote
Cool thanks
Lucky Lager
PostPosted: Mon Oct 07, 2013 2:50 pm    Post subject: Reply with quote
Building 8 foot opening, easy - thanks everyone
