buggzee1964 Samba Member
Joined: April 26, 2011 Posts: 17 Location: New Mexico
Posted: Mon Jan 20, 2014 4:52 pm Post subject: Crows foot rims |
| I have two crows foot rims and two non. One crows is dated 2/58 and one is 9/58. I am putting these on a 66 split with a straight axle kit on the rear and wilwood discs with a 3 in drop in front. Do the crows go in the rear or front. Thanks |
durfeec Samba Member
Posted: Mon Jan 20, 2014 5:09 pm Post subject: |
Crows feet rims wont work on a 66.  _________________ 1960 Bus Panel/Camper |
turbo_g Father of Samba Cookie Lover
Joined: October 30, 2002 Posts: 722 Location: Laguna Hills, Ca
Posted: Mon Jan 20, 2014 5:38 pm Post subject: |
I agree, send them to me...  _________________ Turbo_g
66 TinTop Westy SO42
63 Sub-hatch Westy SO33
SV2s Member #425
"Three out of four voices in my head say 'Go for it'." |
Stocknazi Samba Member
Posted: Mon Jan 20, 2014 5:46 pm Post subject: |
crows feet 15 inch wheels were used on buses up through around 60; some buses got them , some did'nt; some got a mix of crows and non-crows
they were different manufactures
your bus should have 14 inch wheels _________________ WANTED:
Thomas Jefferson |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Mon Jan 20, 2014 5:56 pm Post subject: |
since he is lowering it and putting disc brakes on I doubt the stock 14" rims will work for his bus
plus there is a better option with low profile tires in the 15" size
15" crows feet bus rims are the same as 15" non-crows feet rims so it doesn't really matter where you put them
also the "crows feet" part of the rim is hidden by the hubcap anyways _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Mon Jan 20, 2014 8:20 pm Post subject: |
| what joe56 said... |
lowindO Samba Member
Posted: Mon Jan 20, 2014 8:29 pm Post subject: |
What/whose disc brakes? _________________ Why don't you have a narrowed beam yet?
My Squareback's Video |
Slow Steve Samba Member
Joined: October 23, 2008 Posts: 715 Location: Midlothian, VA
Posted: Mon Jan 20, 2014 8:30 pm Post subject: |
Funny you say that. My 66 SC has 2 crow's and 2 non. And what ^ said. 14's won't fit over disc brakes. 15's will work though. _________________ BarryL wrote:
100 years from now when they have reverse atom regeneration attractor technology perfected and in a hand held back yard mechanic's price range, someone will dig up this thread and go, "What were those guys thinking? The whole thing was all there just waiting to be re-atomized. Funny how easily they cut them up back then."
___________________
74 911
72 914
65 13w Deluxe
60 Ragtop |
Chad M Samba Member
Posted: Mon Jan 20, 2014 8:39 pm Post subject: |
The slots in crowfoot rims are larger than non-crowfoot. Just try sliding your hand into a non-crow... its a no-go.  |
fig Samba Member
Joined: August 17, 2000 Posts: 1080 Location: 26.15°S, 28.2°E
Posted: Mon Jan 20, 2014 9:15 pm Post subject: |
| Chad M wrote: |
I don't think so ...
I think you may be confusing 15in and 14in rims.
The crow's foot name comes from the pressings around the bolt holes, as in this picture:
_________________ fig
Kaapse Kombi Kult
"Don't make a fuss, just get on the bus ..." |
Z Samba Member
Posted: Mon Jan 20, 2014 9:28 pm Post subject: |
| fig wrote: |
| Chad M wrote: |
Have to agree with Fig...while there are some VERY minor differences between crow/non, the size of the slots are virtually identical. |
Chad M Samba Member
Posted: Mon Jan 20, 2014 9:54 pm Post subject: |
I'm going out to check my stash again...
edit: The slots in the Crows are definitely bigger... not longer, but the windows are larger.
I stick by what I said. |
Clara  Samba Member
Posted: Mon Jan 20, 2014 10:07 pm Post subject: |
There are different sizes of the slots, crows are bigger.
Some non-crow have the bigger slots, same as crow.
Some have slighter smaller slots. |
fig Samba Member
Interesting ...
So I guess it's a matter of which manufacturer made the wheel? _________________ fig
Kaapse Kombi Kult
sammysamba Samba Member
Joined: October 16, 2010 Posts: 66 Location: devon,uk
Posted: Tue Jan 21, 2014 12:42 pm Post subject: |
I thought offset on crows were slightly different?
As a lot run crows front non crow on rear! |
OP Samba Member
Joined: January 27, 2004 Posts: 42 Location: Newquay, Cornwall, UK
Posted: Tue Jan 21, 2014 1:18 pm Post subject: |
Crows feet were on commercial splits as the crows feet shape was stronger. There is also a slight difference in off-set between crows and non crows of about 4mm. So don't run one of each on the same axle. _________________ www.dubberware.com "Personalise Your Ride" Stickers, Clothing, Gifts Etc |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20955 Location: Sandpoint, ID
Posted: Tue Jan 21, 2014 7:40 pm Post subject: |
| OP wrote: |
| Crows feet were on commercial splits as the crows feet shape was stronger. There is also a slight difference in off-set between crows and non crows of about 4mm. So don't run one of each on the same axle. |
Nope. I have four original crowsfeet wheels on my 58 standard. It did not matter if the bus was a commercial bus or passenger bus. Crowsfoot wheels are not stronger, and they do not have an appreciable difference in offset. 4mm would be the absolute max that I have ever measured. They are usually less than 2mm difference.
To the OP, mount those wheels wherever you want, It doesn't matter. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4181 Location: San Diego
Posted: Wed Jan 22, 2014 3:05 pm Post subject: |
| Quote: |
| Crowsfoot wheels are not stronger |
Thats just your opinion which isnt based on anything factual. The stampings around the bolt holes arent just for looks
The slots in Crows feet wheels are larger than non- crowsfeet wheels. Stick your hand in there and you will feel the difference |
Posted: Wed Jan 22, 2014 6:01 pm Post subject: |
| chrisflstf wrote: |
| Quote: |
If they are stronger, why is that possibility never ever mentioned in any literature, and crows foot wheels are found on any variety of buses regardless of intended use? I can see that the stampings could provide for some lateral stiffness around the lug hole, but to say that they are a stronger wheel because of that is supposition at best.
As to the slots...
| Clara wrote: |
Chad M Samba Member
Posted: Wed Jan 22, 2014 8:08 pm Post subject: |
Are there more wheel manufactures than the Lemmerz, Kronprinz and VW for the 15" split buses?
I have not run across the "bigger slot" non-crow... which manufacturer would have made these?
Are the wheels marked VW actually made by VW?
Thanks in advance! |
