johnchr82 Samba Member
Posted: Fri Feb 14, 2014 9:53 am Post subject: 1966 Bug Headlight Relay |
I am converting my 66 bug to 12v, and have wired it using the diagram below. Everything exept the rear lights worked for a while. After having it turned on and off a few times it now blows out fuse number 2 every time i try to turn on the lights. This thing is currently driving me crazy... Any ideas?
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36300 Location: Conejo Valley, CA
Posted: Fri Feb 14, 2014 11:22 am Post subject: |
Rear lights are not part of this circuit at all, so that is unrelated.
The headlight relay wiring should be very simple. If you are blowing fuses then something is miswired or shorting out.
Maybe you can post a photo of your fusebox so we can see the rest of the wiring. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11210 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Feb 14, 2014 11:30 am Post subject: |
Yep.. the dimmer and headlamp circuits are not part of the tail lamp circuits.
Fuse 2.. second from left... should be High beam left and High beam indicator ONLY.
That is.... if your fuse box load circuits are connected correctly.
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
KTPhil  Samba Member
Posted: Fri Feb 14, 2014 11:40 am Post subject: |
Congrats on Norway's Olympic prowess, by the way.
If you have a Euro model, terminal 30 should have a thick wire running to it, NOT the thin jumper from terminal 56. With a dedicated 30 wire, you can use your headlamp passing flasher function. USA models lacked this, and used the 30-56 jumper.
Since that 30 wire will carry both high beam's current while you hold the button down, it should be as thick as the white/yellow/B&W striped wires. Connect it to a fused connection with power when the key is off. Not sure which one, maybe the one at the other end of the fusebox. |
Posted: Sat Feb 15, 2014 5:56 am Post subject: |
| KTPhil wrote: |
| Congrats on Norway's Olympic prowess, by the way. |
I havent had the time to watch a lot of Olympics lately. Thanks for the update though
| KTPhil wrote: |
If i remember correctly, which is never a guarantee, the red wire is a thick wire, the same as the yellow and white (although the yellow is black from the fusebox to the relay. Probably replaced in later times).
Anyway.. Thanks for the info so far I will take some pictures of the fusebox and of the wiring tomorrow. |
Aynthm Samba Member
Joined: July 07, 2010 Posts: 1315 Location: Beaverton, Oregon
Posted: Sun Feb 16, 2014 12:15 am Post subject: |
| Check for proper grounding on your tail light assemblies. |
