Escorial Syncro Samba Member
Joined: May 02, 2004 Posts: 449 Location: Manitou Springs, CO
Posted: Tue Feb 18, 2014 8:47 am Post subject: Will a 2011 Subaru 2.5 block work with older wiring? |
Hey Guys,
I've done a number of Subaru Vanagon conversions and have always been lucky enough to find complete donor cars. Lately they've all been 2000-2004 subaru 2.5 setups. But I've got a situation where I've got a 2011 2.5 engine, and I'm wondering if I can use this long block with the intake and FI system, ecu and wiring from a 2000-2004 OBDII car that I'm more familiar with? I know there is VVT on the newer motor that could not be used. Thanks for the help, just not too familiar with the newer drive by wire stuff.
Joel _________________ Joel Lane
1985 Vanagon converted to syncro, ALH TDI w/GTB2056 turbo, Reimo clone top with Westy interior
2002 Toyota Tundra 4x4 |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2987 Location: Issaquah, WA
Posted: Tue Feb 18, 2014 9:08 am Post subject: |
Hi Joel,
Those late model VVT EJ25s are used quite often for conversions, but the typical solution is to use the wiring and ecu from a previous generation Forester or Impreza. These cars both had the proper ecu that is compatible with the VVT system and throttle by wire, but they were still non-canbus cars, so the wiring was still reasonable.
I don't know that I've ever seen the early Phase II ecu and wiring used on a VVT EJ25, but it seems like it would work as long as you used the intake manifold assembly from the non-VVT engine. The main questions are whether or not the crankshaft and camshaft position sensors from the non-vvt engine could be mounted in the late block, and whether the VVT phase adjuster remains passive and in zero position if not hooked up.
I think Ben would have the answers to those three questions.
Dave |
NC Dude Samba Member
Posted: Tue Feb 18, 2014 9:09 am Post subject: |
You should give small car performance a call and talk to a fella name mao. He is very helpful and I remember a similar scenario at a shop I worked at. They proved to be very knowledgable |
insyncro Banned
Posted: Tue Feb 18, 2014 9:54 am Post subject: |
Hands down Benny is the 2.5 Master  |
JeffRobenolt  Samba Member
Joined: February 25, 2007 Posts: 1531 Location: Wisconsin
Posted: Tue Feb 18, 2014 11:45 am Post subject: |
If I remember right Ben likes to use the 2007 Harness on the newer motors.
Jeff _________________ For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com |
