JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Fri Mar 21, 2014 10:28 am Post subject: |
@ Glen and VWracerDave, what are the two grooves for? I got six packs of Zots with my Berg pulley order
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Fri Mar 21, 2014 11:48 am Post subject: |
If you are talking about the two drill locations; those are for balancing by removing material from that half of the pulley _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15316 Location: Deep in the 405
Posted: Fri Mar 21, 2014 6:46 pm Post subject: |
Yes those two dimples on the bottom are where they removed material to balance the pulley. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Sat May 03, 2014 8:53 pm Post subject: |
I like my Saco power pulley. It's very well made and has a removable steel hub. _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
BugMan114 Samba Member
Joined: March 22, 2007 Posts: 3744 Location: Ellenwood, GA
Posted: Sun May 04, 2014 4:31 pm Post subject: |
I didn't even know that the groove wearing out was a thing. I don't think I've ever seen that, or had that happen to me. Honestly, I've never had a problem with scat aluminum pulleys. I've seen a few that had a crack in the hub, right where the key goes, and a few that were bent, but I'd guess it was due to PO's damaging them. I've never had one actually fail on me, and I've bought plenty of used $5 swapmeet aluminum pulleys. And I've never had one leak oil from the threads unless I didn't have the breather hose hooked up properly. but even a stock will leak without the breather hose. I'm sure the berg is a lot more durable tho, as I've ruined some trying to get them off when the crank gets rusty. I'm not saying that the scat pulley is the same quality as the berg, just saying I've never had a reason to spend the extra moola on a berg pulley. even if I ruin it, to get it off, I've got a stack of swapmeet ones ready to use, all of which were cheaper then one berg pulley _________________ 1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!! |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sun May 04, 2014 8:05 pm Post subject: |
vwracerdave wrote: |
Sand seals are designed to keep sand out of the engine. They are not deigned to keep oil in. ***(Flame away mini I put on my fireproof panties)*** |
Boo friggity hoo, they do keep oil in so suck my left teet. Or Bergs, if you prefer. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Sun May 04, 2014 8:15 pm Post subject: |
Oh, I missed that - now if I put a heavy pulley on, or have a type 3, I'll twist the snout off my crank, and if I fit a sand seal all the oil will run out the rear of my case. Dagnamit, I'll just have to build a stock 1500 and reduce the CR to 6.5 or run the risk of everything falling apart. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
KILLERWATT Samba Member
Joined: November 18, 2003 Posts: 3298 Location: Vero Beach
Posted: Tue Aug 30, 2016 3:49 pm Post subject: Re: Your favorite pulley and why? |
Just happened to have a few pulleys out so I thought I'd add some pics of why folks gets oil sprayed all over their engine and what to look for in purchasing a pulley..
Stock VW: deep threads and where the hub meets is a sharp squared off edge.
Gene Berg: several lazer sharp, deep threads with a squared edge where the hub joins the pulley.
Scat: hardly any threads and very shallow at that. Radiused joint that promotes spraying oil like a fire sprinkler.
I'll try to find an Empi. I keep the Scat around for building because it's degreed and then swap it out for a better one. |
mark tucker Samba Member
Posted: Tue Aug 30, 2016 7:49 pm Post subject: Re: Your favorite pulley and why? |
I must be stupid or something I like my seals to do what seals do...SEAL. not just dirt out but oil in. I dont know who the moron was that decided that they are only there to seal dirt out but.... they are a oil seal. as for favorite pullys....I have so many I cant decide. but it sure isant heavy. honnestly I dont have a clue as to what the one on my bug looks like other than being aluminum it might have round holes..or triangle holes or..funkey shaped holes...I havent a clue it's been so long since Ive looked at it. I do have some sand seal oe pullys but there on the shelf...along with the steel berg pully. I did get one of those bugpoop spintrue alt pullys...what a fricken lie..should be wobbletrue or true wobble....the empi pully is somuch better and runs much truer. thinken about making a duel speed alt pully...but too much stuff in the works as it is. |
