jetting for solex 34pci
beetleseb
beetleseb is offline
PostPosted: Wed Mar 19, 2014 4:37 am    Post subject: jetting for solex 34pci Reply with quote
Hi guys.
I'm running a 1600 single port. Stock cam. Twin solex 34pci
It's on red boxes but with proper tyres and 60mph is 3341 rpm
Engine runs cool and well but I am only getting 22mpg. I have checked ignition and that all looks ok. I know its a touch rich but obviously more than I realised.
I used the jets suggested on a German website about tde setups but wondered if fellow vintage speed nuts could suggest a better start. Ideally I will rolling road it but want to be as close as poss.
Currently
27mm venturi (tde used 28 but I don't have any)
145 main
175 main air
1.1mm idle air
10 mix tube
50 idle jet.
Any better suggestions. The main jet is a pig in these and you have to strip the carb to get to them.
Thanks
Seb
Wanted - OG 50 split bug door panels, brown mats and old running boards
VWCOOL
VWCOOL is offline
PostPosted: Wed Mar 19, 2014 4:44 am    Post subject: Reply with quote
145?
My cammed 1916s have 140s so maybe 145 is a little rich?
beetleseb
PostPosted: Wed Mar 19, 2014 8:24 am    Post subject: Reply with quote
Yeah I followed the advice of a German website about early solex 34pci kits. I realise this is very wrong and want to get closer before I shell out on a dyno to tweak.
The maths suggests you multiply the venturi size by anything from 4.2 to 5 depending on who you listen too and that means anything from 115 to a 135 main. But I know nothing about carbs....
Seb
beetleseb
PostPosted: Sat Mar 22, 2014 12:53 am    Post subject: Reply with quote
Hi
No suggestions? I did speak to a carb guy in the UK but the suggestions he made didn't quite seem right either.
He suggested 2 setups.
Main jet 150
Air correction 200
Idle jet 55
Or
Main jet 135
Air correction 200
Idle jet 45
I did thing about using the jetting from the 32pbic from the okrassa carbs
Any bright ideas?
Seb
nize
nize is offline
PostPosted: Tue Mar 25, 2014 7:08 am    Post subject: Reply with quote
I am about to put a Riechert Tuning kit with dual Solex 34 PCI on a stock single port 1600cc engine me too.
I got the following advice from Riechert Tuning:
venturi= 28 i.d.
main jet 142,5
air corr. jet 175
emulsion tube 10
needle valve 1,2
idle jet 50
accelr.pump valve M w/o bypass !
volume = 0,4-0,6 ccm each press,each carb !
don t change idle air jet.
Do you guys know where to purchase these jets?
----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
beetleseb
PostPosted: Tue Mar 25, 2014 8:19 am    Post subject: Reply with quote
My venturis are smaller so thats why I need smaller value jets
I cant get venturis but did find all the jets here in the uk. The emulsion tubes are the same as 28pci carbs and they use a 10 so that fairly easy.
I should have the 175 and the 142.5 here and can order the others with my new jets and send them on. They are about £8 each from my supplier tho so adds up quickly!
Seb
