1911tex Samba Member
Joined: June 14, 2014 Posts: 63 Location: Central Texas
Posted: Sun Jun 22, 2014 7:40 pm Post subject: My breather tube needs a diaper |
The only leak under my Thing is what drips out of the breather tube after driving. Don't mind my garage...use a flattened cardboard box; but others don't like my Thing to relieve itself in puddles on their driveway ! Suggestions? Thanks. |
Posted: Sun Jun 22, 2014 8:22 pm Post subject: |
I forgot to mention that the breather tube goes straight down from below the oil fill, then through the pan and below. Thanks again. |
Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1009 Location: Redlands, CA
Posted: Mon Jun 23, 2014 3:12 pm Post subject: |
Are you running a stock motor with the stock oil bath air cleaner? If not, you may want to looking into an aftermarket breather box or search here on the Samba for ideas on how to make one. http://www.thesamba.com/vw/forum/viewtopic.php?t=224958&highlight=breather+box
If you are running a stock motor and air cleaner, make sure the hose from the oil fill/breather tube is connected to the air cleaner.
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Mon Jun 23, 2014 4:54 pm Post subject: |
Shoyrtt wrote: |
since you are using a picture of my brothers engine notice that his engine does not have the tube off the breather that is only used on early bug engines the thing does not have a tube
Posted: Mon Jun 23, 2014 5:12 pm Post subject: |
citroen wrote: |
I used your brother's photo knowing it was probably 100% factory correct. So what is the hose from the oil fill over to the air cleaner for? |
Posted: Mon Jun 23, 2014 8:08 pm Post subject: |
It is the same as the early one with the tube but the late system was a little bit more of a closed system so it breathes thru the air cleaner and yes my brothers engine is as close to 100% as you will fine except for the new one we are building. thanks |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Wed Jun 25, 2014 7:54 pm Post subject: |
Towel Rail: That is what I am looking for ! Thank you. Yes, my thing for some reason, the PO installed a B series '70 engine. It runs great, but when the time comes (financially) I will spring for a rebuilt AM engine. |
Posted: Thu Jun 26, 2014 8:04 pm Post subject: |
1911tex wrote: |
Cool. With these cars, it's a wonder that any of them still have their original engines, if they were driven much. My car came to me with an engine and transmission from a '71 Ghia, of all things. It would be neat to have an AM block back in there. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
SCVGuy Samba Member
Joined: March 11, 2006 Posts: 31 Location: Valencia, CA
Posted: Sat Sep 20, 2014 11:03 pm Post subject: |
Just reading through this thread because I'm right in the middle of all this. My tpTjing came with its original AM case but had been enlarged to an 1835 with a Dellorto DRLA 36 carb. The PO cut a hole through the above deck to make room for the carb and filter. Had all the seals changed and a tune up done when I bought it but it leaks a constant stream of oil. I pulled the motor out and am saving up for a rebuild into a reliable 1776. Until then, I just installed a 1600 single port from my friends 70 Ghia and bought a stock filter assembly.
Having no opportunity to take pics before I'm looking for any reference pics or diagrams showing how the whole filter assembly, brackets, hoses, etc attach to the car and motor. Also, does oil need to be added to the filter before using.
Any help or references would be greatly appreciated.
Thank you
SCVGuy
'73 yellow Thing |
Posted: Sun Sep 21, 2014 7:18 am Post subject: |
here is a picture of how the stock setup of the air cleaner looks in a VW bulletin in 1973 you will find more pictures of thing engines in our website the Domeck Brothers at http://kubeltreffen181.com and yes the air cleaner needs oil.
GI Joe Samba Member
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Sun Sep 21, 2014 4:10 pm Post subject: |
GI Joe wrote: |
It's been Long time since I was in An oil bath cleaner, but I believe there is a red(or green?) line In the base for proper oil level... |
It's a red line in the oil bath air filter.
and YES put oil in it!
I think spec says 30wt but any oil is better than none.
I believe I have 5w20 in mine just cause it was all I had at the time I changed it., little thinner but it's still oil. _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
