J1 Samba Member
Posted: Mon Aug 18, 2014 1:12 pm Post subject: First real test... too arduous? |
First "in action" photo since I got her about half a year ago (sorry, really cheap camera phone) and the first real test of her abilities. This may be the first time these hills and canyons near Santa Clarita CA have seen a Ghia since this is about a mile into a gravel road.
I came here to get away from the masses and do a little solo rock climbing (my other obsession). I drove her 70 miles from the LA beaches up to Sepulveda Pass (I-405 freeway) which has an elevation of 1100 feet and through multiple little hills along the way... in 95 degree temps. In retrospect, it could've ended inconveniently given I am still learning her temperament, I was driving alone, far from home, had no jack, and down this gravel road, there was spotty cell service and few other breathing humans.
But keeping her under 60 mph, she performed grandly for the full 140 mile round trip, even on the gravel switchbacks. I don't think she likes getting dusty and having all those sharp pieces of rock going under her tender feet, so this will probably be her last time here.
Anyway, I have a simple question, really. After I came home, I remembered Muir saying that the oil dipstick is a good way to check how the engine is doing. If too hot to hold by hand, the engine is overheating. Well that was the case for this near-original engine.
How true is this? Other than keeping her tuned up and driving gently, is there really anything you can do to minimize overheating in situations like this, going up and down hills, in high temps? Was this trip too arduous for this baby girl? OK, gotta go dust her off now. _________________ 1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth. |
ccihon Samba Member
Joined: September 12, 2012 Posts: 227 Location: Columbus, OH
Posted: Mon Aug 18, 2014 1:37 pm Post subject: |
Nice looking ghia. I personally don't place much stock in the "too hot to touch" thing, because I know using a thermometer a safe operating range for the oil is ambient to 200F or so, and after spirited driving in the heat it can "safely" reach 225 or so. I certainly have toughened hands, but I sure can't hold on to a metal object at those temps. Must be that Muir was a tough guy. Most home hot water is at or below 140F, and most folks don't tolerate that heat for very long.
You might try a stick-style candy thermometer or similar to actually check, and there's another recent thread here discussing what would cause high temps. Basically, all the tins, good airflow from the fan, and free flowing oil. |
c21darrel Samba Member
J1 Samba Member
Posted: Mon Aug 18, 2014 2:45 pm Post subject: |
Thanks for the reality check. Feeling better now.
Maybe a more important question then is how does one prevent overheating of your bottomside (ie, your butt) when you're sitting in this kind of heat for extended periods of time?!!
Granted I had been hiking and climbing in the sun but after driving in the heat for a couple hours and arriving home, I stepped out of the car and noticed that my entire rear section of my shorts had gotten completely soaked. I suppose the unbreathable vinyl seats don't help. I think I was having too much fun to even notice!
I'll need to factor that in if I'm driving to a formal gathering where a dry butt is required. Maybe keep an extra pair of shorts along with the spare generator belt and fuses?! _________________ 1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth. |
Ojai63dbl Samba Member
Posted: Mon Aug 18, 2014 4:50 pm Post subject: |
I have an old school version on this in mine to keep my a.. cool - and it actually helps.
http://www.sportsimportsltd.com/kokovesecu.html
now they apparently have an electrical fan version on this site |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Mon Aug 18, 2014 4:59 pm Post subject: |
Under your Ghia sits one of the greatest of-road chassis ever designed... but you should buy a jack!
Touching the dipstick a USELESS way of measuring engine temp.
Would you feel the radiator of a Chev, then nod knowingly and say "Hmmmm... yes, I think it's about the right temperature"..
How about cooking cakes.. would you stick your hand in an oven to check the temperature? No... |
Loren Samba Member
Posted: Mon Aug 18, 2014 6:11 pm Post subject: |
The above mentioned Berg dipstick sensor is a good indicator to determine if your engine is running hot. The other option is to buy a VDO temp gauge so you can see "exactly" how hot the engine is running. I use quotes around exactly because most temp gauges don't give completely accurate readings (it depends where you locate the temp sensor), but it will give you a good indicator of how the engine is doing. |
Kmolenda Samba Member
Joined: June 18, 2013 Posts: 309 Location: Cottage Grove Mn
Posted: Mon Aug 18, 2014 7:23 pm Post subject: |
I personally use a infrared thermometer on mine, is very accurate, plus gives you temps wherever you point it at, (each cylinder, intake etc) works great and They are pretty reasonable now too. |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Mon Aug 18, 2014 11:56 pm Post subject: |
I'm with Darrell. These cars were made to be driven and in all conditions. Dr Porsche might have had the freezing Northern European winters in mind when he designed this air-cooled car, but they serve just as well in the subtropics and especially well on bad roads. Ask those guys who drove VW's in the Australian Outback or Southern African bush, and you'll hear heaps of stories about VWs going through mud and dirt when others slid off the road or wallowed in the wet.
I just see no reason why you shouldn't go back up the hill every time you feel like it. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
J1 Samba Member
Posted: Tue Aug 19, 2014 10:39 am Post subject: |
Thanks for the several options for monitoring engine temps (I will def look into those) and the encouragement to have fun with her (though I think I'll keep her off the dusty roads since I'm too lazy for the post-ride cleaning).
And maybe most of all, thanks for the suggestion for my "sitting in a puddle of sweat" problem! That may become one of the most significant "upgrades" _________________ 1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth. |
VWCOOL Samba Member
Posted: Wed Aug 20, 2014 6:11 pm Post subject: |
the common type of dipstick warning units are calibrated too 'cold' to be of any real use on a hotter-than-Chev running VW engine. They are calibrated to cause you to worry at 104C... so the VW performance parts salesman can then sell you an oil cooler "to make your engine run cooler"
Your standard engine is just fine in 30C heat |
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Fri Aug 22, 2014 7:37 pm Post subject: |
Kmolenda wrote: |
That's what I use, and it's great for checking temperatures for the engine case, oil, carb, intake maifold, etc. The dipstick method is for holding the handle of the dipstick, not the dipstick itself. Big difference, but still not meaningfull. I think that the original point was that, if the handle burns you, you have a problem! My engine temps are right around 174 F in normal driving, with the oil temp usually being 10 to 15 degrees cooler. Drive it hard and the oil temperature catchs up to the engine temp. The hottest I have been able to get my engine is 202, and that was pulling a half-ton trailer at 80mph. When idling or driving gently, they cool back down. This is why after hard run, I'll get off the freeway an exit early and drive casually the last couple miles. If you don't have that option (like in the mountains), then letting it idle for a minute before shutting down helps.
Paul |
Altema Samba Member
Posted: Fri Aug 22, 2014 7:45 pm Post subject: |
Yeah, those work well... I hate sitting on plastic in the summer OR winter! I discovered a couple years ago that my Ghia handles heat a LOT better than I do: The outside temperature was near 100 degrees F, and the pavement temps were 130+ when I got stuck in a huge traffic jam. I was ready to pass out from the heat, but the Ghia did not care one bit... unlike a few modern cars that wound up on the side of the road due to overheating. |
