Transmission ID?
72vwtype2
72vwtype2 is offline
PostPosted: Fri Jan 23, 2015 9:35 am    Post subject: Transmission ID? Reply with quote
Why is it difficult to find a table that identifies a bus transaxle by the code stamped on it's side? Most information is vague, such as this table:
http://i147.photobucket.com/albums/r301/David58Bug/Type2gearboxcodes.jpg
For example, if I had a transmission CK116####, could you identify the year and month of the bus it came from. From what I have seen the best you could do is probably indicate that it came from a 72/73 bus and would need to rely on differences in various features (bell housing, switches, etc...) to be able to somewhat pinpoint more accurately.
If anyone has a good table please post it.
Thanks.
sodbuster
sodbuster is offline
PostPosted: Fri Jan 23, 2015 10:00 am    Post subject: Reply with quote
Unless you are doing a full 100 point restoration and insist on some sort of numbers matching scenario for your build why would you need to break it down to to month? There are three basic styles of type 2 IRS gear boxes.
1,Three rib (002 early) 5.357 to 1 ring and pinion ratio. 1600cc & 1700cc. up to 1973
2, Five rib (002 late) 4.86 to 1 ring and pinion ratio. 1800cc. 1974 1975.
3, six rib (091) 4.57 to 1 ring and pinion ratio. 1800cc & 2000cc. 1976 up to 1979.
This is just from memory so if I'm off a little on this, that is why. Wink
SGKent Premium Member
SGKent is offline
PostPosted: Fri Jan 23, 2015 10:16 am    Post subject: Reply with quote
http://www.docstoc.com/docs/89820949/ETKA-VW-Transmission-Gearbox-Codes
George Carlin:
Skills@EuroCarsPlus:
Tcash
Tcash is offline
PostPosted: Fri Jan 23, 2015 11:05 am    Post subject: Trans Codes Reply with quote
72vwtype2
PostPosted: Sat Jan 24, 2015 11:27 am    Post subject: Reply with quote
Thanks guys. The information provide re-confirms what I am saying. There does not appear to be a table that confirms specific month which I would like to see for my restoration.
Thanks.
Tcash
Tcash is offline
PostPosted: Mon Jul 27, 2015 9:10 am    Post subject: Trans ID Reply with quote
Trans Code Location:
KrAzY-BaJa wrote:
Gears & years
http://irelandaircooled wrote:
TRANSMISSION CODES
AA 1200 4.375 from chassis No 0 981 810
AB 1300 4.375 Up to 8/70
AC 1500 4.125 Also some 1300 from 8/70
AD 1200 4.375 Limited Slip Differential (LSD)
AE 1300 4.375 Limited Slip Differential (LSD)
AF 1500 4.125 LSD up to 8/70; also some 1300 from 8/70
AG 1200 4.375 Type 147 (Fridolin)
AH 1500 4.125 IRS suspension from 8/68
AH 1600 4.125 8/69-8/72
AK 1500 3.875 Type 181 Trekker up to 8/70
AK 1600 3.875 Type 181 Trekker from 8/70
AL 1500 3.875 Type 181 with LSD to 8/70
AL 1600 3.875 Type 181 with LSD from 8/70
AM 1300 4.375 Saloon and Cabrio from 8/70
AN 1600 3.875 Karmann Ghia IRS from 8/70
AO 1600 3.875 Karmann Ghia from 8/70
AP 1300 4.375 LSD from 8/70
AQ 1600 4.125 LSD 8/70-8/72
AR 1600 3.875 K-Ghia LSD from 8/70
AS 1600 3.875 Type 1 from 8/72
AT 1600 3.875 1303S and Cabrio from 8/72
AU 1600 3.875 Ditto with LSD
BA 1300 4.375 Semi-auto from 8/68-8/70
BA 1500 4.375 Semi-auto from 8/68-8/70
BC 1300 4.375 Ditto with LSD
BC 1500 4.375 Ditto with LSD
BE 1600 4.125 Semi-auto from 8/70-8/71
BF 1600 4.125 Ditto with LSD
BG 1300 4.125 K-Ghia semi-auto from 8/70
BH 1300 4.125 Ditto with LSD
BJ 1300 4.375 Semi-auto from 8/70
BK 1300 4.375 Ditto with LSD
DA 1500 4.125 Type 3 swing-axle to 8/68*
DA 1600 4.125 Type 3 swing-axle to 8/68*
DB 1500 4.125 Ditto with LSD*
DB 1600 4.125 Ditto with LSD*
DC 1500 4.125 Type 3 with IRS from 8/68
DC 1600 4.125 Type 3 with IRS from 8/68
DD 1500 4.125 Ditto with LSD
DD 1600 4.125 Ditto with LSD
*Note that reinforced swing-axle design was available on
post 8/68 Type 3 models as an option (M263)
[/quote]
http://www.ratwell.com/mirror/sandlizrd.baja.com/gears.htm
David
http://www.shoptalkforums.com/viewtopic.php?t=113852
http://www.vaglinks.com/Docs/Catalogues/ETKA_VW_Transmission_Codes.pdf
http://vw.zenseeker.net/Transaxle.htm
Clutches - what pressure plate with what throwout bearing
