KCh30allener Samba Member
Joined: January 25, 2015 Posts: 6 Location: Meadville PA
Posted: Sun Jan 25, 2015 7:38 pm Post subject: Frame Head and Napoleon's hat replacement |
I need to replace my 1973 Thing Frame head and napoleon's hat. I cannot locate replacement parts. Can I use Ghia parts? Any suggestions for locating correct parts? Thanks |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Mon Jan 26, 2015 12:36 pm Post subject: |
The part # for the frame head is a beetle # so I am guessing the other part is beetle also. |
Posted: Mon Jan 26, 2015 2:55 pm Post subject: |
Thanks!. I have a parts manual and I will look up the numbers. didn't think of that. |
ernieballbass Samba Member
Joined: June 14, 2006 Posts: 191 Location: Orlando, Fl
Posted: Tue Jan 27, 2015 12:39 pm Post subject: |
how bad is your frame head?
the only reason i'm asking is because it's a hard job, especially with the quality of repro parts.
i was able to patch the bottom of the frame head and welded just the ends of the napolean hat.
sorry, i didn't take a picture of the bottom plate repair. _________________ What I lack in brains, I make up for with good intentions. |
Posted: Tue Jan 27, 2015 1:08 pm Post subject: |
Sadly, mine was much worse, on both sides. The head itself underneath was gone. I did not save it, not thinking it would be tough to find. I had the same problem with the area above the "hat" and manage to cut and paste (weld) sections from a bettle to rebuilt the entire bottom half. |
Derek Cobb Annoying
Posted: Tue Jan 27, 2015 1:20 pm Post subject: |
I always suggest finding a rust free used frame head. They are MUCH better quality than the thin, poorly made re-pops. Call a VW salvage yard in the dry desert. |
