DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Wed Jun 24, 2015 5:54 pm Post subject: |
Has anyone installed the beetle version of the sidewinder exhaust on a splitbus? CarCraft has a raw 1-1/2" version for less that $300.
The above pix looks like there maybe some tweeking required to clear bumper bracket. Wondering if there maybe a fumes issue since it doesn't exit like the bus specific exhaust.
http://carcraftstore.com/sidewinder158exhaustsystem.aspx
Their product discription indicates that some people are installing them on splitbuses.
I need an exhaust for a 1600 that's getting a top end rebuild to 1700cc and that same exhaust will be reused on a mini stroker around 1900cc.
Thanks |
wrenchnride247 Samba Member
Joined: August 17, 2010 Posts: 251 Location: Cleveland, TN
Posted: Wed Jun 24, 2015 7:17 pm Post subject: |
DerrickfromNC1 wrote: |
Thanks |
I have the stainless one, and it is very good quality. But, getting it to work in a bus takes some cutting and bending on the apron . The #2 primary tube is the main offender. And if you leave the tail pipe in their exit location...wear ear plugs. _________________ SPL
'62 SC 69x90.5 SP TI
'70 T1 84x105 DP T4 |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Sun Jun 28, 2015 11:20 pm Post subject: |
I almost purchased one OCTO weekend.. Sounds like there's to many issues with this system to fully commit on spending $500 bucks! Leaks, rubbing, not fitting correctly, weak welds! It's probably the nicest looking "stock" system on the market and that's why I'm drawn to it, but till I read more positive posts than negative I'll wait for the next thing.. _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Mon Jun 29, 2015 9:41 am Post subject: |
pyrOman wrote: |
JohnnyRingo wrote: |
If I go with A1 again I will order it with the v/band clamp.....it was a pain removing the three bolts every time to remove muffler. |
X2 on that! I'd also add that if I get another sidewinder it will be just the collector, then I will "graft" a smaller muffler to it. The MONDO muffler that usually comes with it is just too damn loud and annoying on long trips. |
I totally agree about the loudness of the Magnaflow muffler on the A1.
The header is great, but the muffler is too damn loud. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
markyb Samba Member
Posted: Wed Jul 01, 2015 6:03 pm Post subject: new VS muffler on a lowered T2 |
http://youtu.be/tYA0Hz0iqFY
No problems with fitment on my lowered T2, I have dry-fit the breast plate and apron and found good clearance on all. The sound is excellent, of course I just upgraded from a 1641 single port to this 1776 dual port with a progressive carb.
Boy, am I glad that I bought the lowered version. There would have been trouble with the standard pipe. |
MrPolak Samba Member
Joined: June 20, 2004 Posts: 1337 Location: AG ,atnaltA
Posted: Thu Jul 02, 2015 7:54 am Post subject: Re: new VS muffler on a lowered T2 |
markyb wrote: |
That sounds awesome. It's now on my bucket list of things to buy for my bus.
jason Samba Member
Posted: Thu Jul 02, 2015 9:10 am Post subject: |
My issues were with the bumper itself having to be cut. |
markyb Samba Member
Posted: Thu Jul 02, 2015 10:59 am Post subject: |
Jason,
I'll know more when I fit the bumper next week and post some pics of the finished work.
I swapped out the 4 bolts and nuts that connect the pipe to the muffler flange. I already had one rattle loose since the kit had no lock washers, so I used grade 8's with lockwashers and flange-head bolts. I figured now is the time to do it before everything is buttoned up.
I could see how there might be issues with the flange coming loose from the pipe as noted earlier in this thread, there was a slight gap on each of the flanges that had to be drawn in on the outer bolts when tightening. I'll keep an eye on it for any cracks that might show up. |
sled Samba Member
Posted: Wed Nov 18, 2015 9:04 pm Post subject: Re: Vintage Speed Exhaust Recent? |
so, I ended up purchasing one of these exhaust systems despite my concerns of fitment and quality issues.
I have to say that the exhaust appears to be a very nice piece upon initial inspection and with only 400 miles on it.
I do have to say that the fitment left a lot to be desired, but I have to imagine this is because VintageSpeed is trying to make this exhaust adaptable to many different engine configurations. While I understand this from a manufacturing and fabrication standpoint, I do not think it is in their best interest. I think if they offered a couple different models, instead of just offering one with a ton of 'adjust-ability' it would result in a much better fitting product.
that being said, I could tell on mock up that I was going to have gasket sealing issues, so I went ahead and used some high-temp copper RTV on all the gaskets except at the heads, where I used some CB performance graphite crush gaskets.
the over all look is awesome, and I appreciate that there is a company offering a single left-exit tip exhaust that mimics the stock style..which is why I chose this exhaust. I am also very happy with the sound. Sounds nice and sporty at idle, but has zero drone or obnoxious volume at highway speeds.
I had zero fitment issues with the bumper or apron
_________________ drive your split. |
Posted: Thu Feb 18, 2016 11:07 am Post subject: Re: Vintage Speed Exhaust Recent? |
Any new info/input on your guys Vintage Speed exhausts? Sled do you still feel the same about it from your latest trip? Also with the engine pulled I've had a little time to think about upgrading mine (A1 sidewinder).. With OCTO being this weekend,, I might pull the trigger and pick one up. Also wanted to ask about the difference in the 2 stock style systems. Besides 38mm and 42mm, is the adjustable (engine size) style only for Buses running heater boxes? I don't plan on runner heat and my engine is 1776 61 Bus and I'm shooting for the 38mm header style. Thanks! _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
sled Samba Member
Posted: Thu Feb 18, 2016 1:29 pm Post subject: Re: Vintage Speed Exhaust Recent? |
Somewhat recently got back from a 4300 mile trip, yes. A LOT of miles on the open highway and I have to say I love this exhaust. I took my time fitting it and used sealant as mentioned and I have zero leaks. I LOVE it.
All of their can systems have the same adjustable design, regardless of heater boxes or j-tubes. The flanges they provided for heater box hookup left a lot to be desired so I just welded flanges on my heater boxes and they sealed up nicely.
For a very mild engine like a 1776 you will most likely not see any kind of performance difference between the a1 or VS. pick which ever one you like the look of most and want to afford.
I do have to say, having the tip exit out the back is much nicer than the turn-down tips on the sidewinders when ground clearance is not required. _________________ drive your split. |
dirtylawnchair Samba Member
Joined: January 26, 2004 Posts: 1234 Location: Bradenton FL
Posted: Thu Feb 18, 2016 2:48 pm Post subject: Re: Vintage Speed Exhaust Recent? |
johny__utah wrote: |
Any new info/input on your guys Vintage Speed exhausts? |
I love mine. I've had it on since August 2015. I had no fitment issues or leaks. Just be sure to use Loctite on the threaded bungs on each side.
_________________ Paulie
63 Standard OG paint |
joshbuchan Samba Member
Joined: April 12, 2007 Posts: 712 Location: victoria bc canada
Posted: Sat Feb 20, 2016 1:22 pm Post subject: Re: Vintage Speed Exhaust Recent? |
Has anyone running these attempted to tune with a wideband via the bungs on the muffler? I had crazy readings on my lm1 that made no sense on a 2276 w 44IDFs....I came to the conclusion that due to internal design of baffles, was t getting a good mixed signal? after much frustration went with plug reading and feel it was a lowered version in a 57 SC. The polished robot welded log was fancy but the rest was discusting! I made it fit and seal but the bends and welding looked like was done by some scab at Midas muffler oh ya and the pipe hit the pressed bumper and blows dirt like a mofo....you should see his engine bay |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sat Feb 20, 2016 5:19 pm Post subject: Re: Vintage Speed Exhaust Recent? |
joshbuchan wrote: |
Josh can you post some pics? I was wondering on this lowered set up in a pressed bumper bus. |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Tue Feb 23, 2016 12:13 am Post subject: Re: Vintage Speed Exhaust Recent? |
joshbuchan wrote: |
An LM1 was just used on mine last night and it was working fine. We used the right side bung. _________________ -Adam
'59 Mango Bus
'11 Golf TDI 6-speed
'69 Bug |
Posted: Tue Feb 23, 2016 1:25 pm Post subject: Re: Vintage Speed Exhaust Recent? |
^^^ that's odd, readings were all over the map! Same sensor and meter were then used in my 55 rag 2332 in a proper merged collector bung and had zero issues
Eric, that was 2 summers ago and have douched my phone of pics dozens of times since. I think I posted a couple somewhere, I'll try and dig up. |
Posted: Tue Feb 23, 2016 2:13 pm Post subject: Re: Vintage Speed Exhaust Recent? |
joshbuchan wrote: |
Hmm, odd. I don't know if it makes a difference, but I have the regular version for use with heater boxes...
And an update. Had mine for a while on my 1641SP single carb and loved it, and it just went on my new 1776DP dual carb and the tone is obviously different, and I still love it. _________________ -Adam
'59 Mango Bus
'69 Bug |
offshores Samba Member
Joined: February 08, 2012 Posts: 1085 Location: So Cal
Posted: Tue Feb 23, 2016 2:58 pm Post subject: Re: Vintage Speed Exhaust Recent? |
I got one of the lowered Bus ones last June or so and it bolted right up perfectly and sounds great. No issues yet, but haven't hooked up a wideband to it so don't know about that. |
curtis4085 Samba Member
Posted: Thu Feb 25, 2016 7:20 am Post subject: Re: Vintage Speed Exhaust Recent? |
I use my lm-2 in left side Bung. No issues. It's installed currently.
Edit: I forgot to mention.. If the sensor cord going to the meter is bumped or not fully seated you will get wonky readings. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Thu Feb 25, 2016 11:18 am Post subject: Re: Vintage Speed Exhaust Recent? |
how if installed in left does it know whats going on in right carb? we welded a 3rd bung in the start of the tail pipe and while it helped i think we were getting a contaminated reading due to fresh air reversion? |
