Brian Samba Moderator
Posted: Thu May 14, 2015 8:58 pm Post subject: Carputer - Help brainstorming |
I'm planning a project to make a BlackBox for my car. Not the CB black box, but a data logger. What types of things would you want to log if you could for a long trip or a daily basis?
Head Temp
Oil Pressure
Oil Temp
Case Temp
RPM
MPH
Voltage
AFR
EGT
Brake Temp
TPMS
300% overkill on an old car, but I like having side projects. May be good application for tuners? I don't know. Input welcome _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
kamesama980 Samba Member
Joined: June 22, 2014 Posts: 323 Location: Columbus, IN
Posted: Fri May 15, 2015 10:23 am Post subject: |
Are you running FI/electronic timing or carb/dizzy?
Can't believe you don't have:
TPS
MAP
other ideas:
ignition advance
charge air temp
crankcase pressure
charge airflow
ambient temp
AFR by bank depending on the induction/fuel system you have.
barometer
humidity
thermostat position
choke position (if applicable)
idle air valve position (if applicable)
gear (calculated by rpm-mph comparison...I do it in excel post-processing)
TPMS? really going overboard with modernizing the bug or did you mean TPS? _________________ -Russell
"You don't get to blame me for how I fix what you break"
1970 VW Beetle
1994 Pontiac Firebird
2001 BMW R1200C
2003 Subaru Baja |
Petfisheric Samba Member
Joined: November 27, 2014 Posts: 121 Location: Knoxville, TN
Posted: Fri May 15, 2015 5:58 pm Post subject: |
WHY???????? |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Fri May 15, 2015 8:32 pm Post subject: |
Petfisheric wrote: |
WHY???????? |
So that you can idiotech the thing. _________________ Jack Staggs
Actual name |
Joined: January 01, 2007 Posts: 16890 Location: sticksville, ct.
Posted: Sat May 16, 2015 10:31 am Post subject: |
if you want, I can come up with a list of PID's next time I plug in a car. but I think fuel temp, tank pressure, cam correlation and fuel pump duty cycle can get crossed off the list.
edit:
here is a 100mph list
http://en.wikipedia.org/wiki/OBD-II_PIDs _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Zeen Samba Member
Joined: July 24, 2004 Posts: 1308 Location: The Sunny Part of Michigan
Posted: Sat May 16, 2015 1:56 pm Post subject: |
When you say "old car" and want to measure "case temperature", does that mean you are refering to your ACVW? If that's the case, there is no OBD-II, no CAN bus, no ECU. So you are talking about taking raw sensor data, things like voltages, and converting that to readable digital parameters before you log them. That's no simple task, but perhaps someone makes such a box. Maybe you could rig up your own if you get sensors, ECU and OBD-II from a newer car and plug in to that. I'm sure it would freak out and constantly throw codes, but you might still be able to read the parameters you are looking for.
_________________ The consequences of your decisions should not be confused with fate. |
Posted: Sat May 16, 2015 2:46 pm Post subject: |
I'm talking about reinventing the wheel. And yes, for ACVWs with all raw data. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Zeen Samba Member
