pfrancescutti Samba Member
Joined: January 26, 2015 Posts: 44 Location: Victoria BC
Posted: Wed Jul 01, 2015 9:52 am Post subject: In a bind: Charging issue |
Hi all
I just finished the first leg of a road trip in my '68 beetle. I drove from Victoria BC, down the Pacific coast then inland to Fresno. During the drive I ran into an issue. I'll do my best to describe the symptoms
Twice during the trip, after long stints of driving (>150 miles) the car wouldn't start. It appears the battery has gone flat. Ignition comes on, lights come on but no click or crank while trying to start. The lights go slightly dim when I try to crank and that leads me to the flat battery. The thing is after bump starting it one time and jump starting it the 2nd time, the car seems to be OK. After ~15 minutes of driving it starts fine.
I'm now sitting at my sister's breakfast table trying to figure out what to replace to get me the 1100 miles home. The car is sitting in her driveway with a flat battery for the third time. I'm leaving in 4 days so any expeditious help you could offer would be much appreciated.
Also, anyone in the Fresno area that could recommend where to get the necessary parts once I figure out what I need?
Cheers
Paul |
kamesama980 Samba Member
Joined: June 22, 2014 Posts: 323 Location: Columbus, IN
Posted: Wed Jul 01, 2015 10:14 am Post subject: |
I would lean toward bad solenoid or starter motor itself. If the battery were dead, you'd get taptaptaptaptap of the solenoid or the engine would turn over slowly. How long was the car sitting when it wouldn't start? Overnight? stop for gas? gas+dinner? If you have the means, try whacking the starter with a stick or non-conducting hammer. (don't be timid, the idea is to knock around the internals because it isn't making good contact). IF you do it while someone else is holding the key to "start": set the parking brake, chock the wheels when you crawl underneath, and make sure the car is not in gear! messing up one of those could cut the road trip short. _________________ -Russell
"You don't get to blame me for how I fix what you break"
1970 VW Beetle
1994 Pontiac Firebird
2001 BMW R1200C
2003 Subaru Baja |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5370 Location: Lefty, CA
Posted: Wed Jul 01, 2015 10:54 am Post subject: |
I've verified the ignition switch is working, moving onto the solenoid. Going to give it a mighty whack and see what happens. |
Posted: Wed Jul 01, 2015 11:22 am Post subject: |
So whacking the starter solenoid proved fruitful. She fired right up, which is great but:
If it's just the starter solenoid then why did jumping it from a good Samaritan's car work?
Is changing the starter an easy driveway job? I've done it on several water cooled VWs but never on an ACVW.
Where can I find a new starter in Fresno?
Cheers
Paul |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31389 Location: Hot Arizona
Posted: Wed Jul 01, 2015 11:59 am Post subject: |
pfrancescutti wrote: |
Is changing the starter an easy driveway job? |
Yes, quite easy. Get one that will be warrantied in B.C. though.
Disconnect negative battery cable.
Disconnect large wire to starter (13mm wrench) and pull off the small wire.
Remove the nut (17mm box or socket) by reaching around the fan shroud on the passenger side. Remove the one large nut on the starter from underneath (17mm wrench), support and lower the starter. I'm going to recommend you get a starter designated for an autostick bug, as those are self-supported, as then you don't have to deal with pulling, replacing the starter bushing in the transmission at all, and it's a little more powerful. There's no alignment or spacers to deal with, just bolt the new one back in.
Even places like O'Reilly and AutoZone will have starters, but I prefer "rebuilt by Bosch" (if still available) rather than a Bosch starter that has been rebuilt. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Wed Jul 01, 2015 12:02 pm Post subject: |
Park on a hill.
take out battery
clean all connections
even the crusty ground to body
get underneath and do the same with ground strap(s)
all the grounds to charging system at or around regulator |
Luft kühl Samba Member
Joined: January 21, 2009 Posts: 1178 Location: Allentown, PA
Cusser Samba Member
Posted: Wed Jul 01, 2015 1:55 pm Post subject: |
If he is able to replace a starter where he is at, why wouldn't he be able to to replace a bushing ? |
Posted: Wed Jul 01, 2015 4:24 pm Post subject: |
Thanks everyone for your input. I'm not convinced that the starter is the only problem.
I measured the battery voltage and I have 12.8V static, 11.9 while cranking and 13-13.3 when it's running and revving the engine. From what I understand, that's low for a charging voltage. The generator brushes "look" OK, is there a trick to determining if my problem is the generator or the regulator?
Cheers
Paul |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24770 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jul 01, 2015 7:17 pm Post subject: |
Sounds OK. Regulator is only going to put out 14 volts when battery is badly discharged. _________________ In Stereo, Where Available! |
Hedjemunkee Samba Member
Joined: February 26, 2013 Posts: 51 Location: Phoenix, Arizona
Posted: Thu Jul 02, 2015 6:58 am Post subject: |
I measured the battery voltage and I have 12.8V static, 11.9 while cranking and 13-13.3 when it's running and revving the engine. From what I understand, that's low for a charging voltage. The generator brushes "look" OK, is there a trick to determining if my problem is the generator or the regulator? |
Doesn't sound like a charging problem. You could have a sticky starter or the ignition is going. Mine liked to do the same thing. Lights would dim... But nothing to the starter. If I did turned it a few times it would catch.
I just bypassed the ignition until I could put in a new one. Still needed the key to run the car... I installed a push button for the starter. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15989 Location: North Florida, USA
Posted: Thu Jul 02, 2015 8:12 am Post subject: |
I measured the battery voltage and I have 12.8V static, 11.9 while cranking and 13-13.3 when it's running and revving the engine. |
That does sound a bit low on the charging rate. Is that measured at the battery terminals (not the posts)? Try taking the same measurement from the B+ terminal of the VR.
Follow testing instructions here on Speedy Jims page:
http://www.speedyjim.net/htm/gen.htm
Running the test will bypass the VR and force the generator to max output. If you get a reading up above 30v then your generator is probably okay. You can suspect your VR.
You could try cleaning all the contact points on the VR and see if that improves performance. _________________ AshMan40
CarlIseminger Samba Member
Joined: May 12, 2008 Posts: 833 Location: Grand Forks, ND
Posted: Thu Jul 02, 2015 10:43 am Post subject: |
Also keep in mind that when you jump start the car, you are getting FULL power. With our older bugs, the wiring and connections get weaker. So even if your battery is "good", you might not be getting all that juice where it needs to. It is a long way from the battery to the ignition switch and then a long way back to the starter selonoid for that power to go.
My starter would "stick" too when it got hot, such as after a long drive. Whacking it with the hammer would do the trick. But around town, it was fine. _________________ 1969 VW Beetle Convertible |
Posted: Thu Jul 02, 2015 10:59 am Post subject: |
What carl said ^
sometimes, when it's still kinda working, the extra amperage available is enough to overcome the partially failed part's shortcomings.
Whacking the starter and then it works could mean a few failure points within: solenoid sticking, solenoid not making good contact (burned spot on contacts, impact knocks it to a clean spot), bad/worn brushes, bad commutator ring, and probably other's I don't know. Without removing it and rebuilding it with new solenoid, bushings, bearings, brushes, cleaning/checking the commutator, etc, the solution is to just replace the whole thing. _________________ -Russell
1970 VW Beetle
2001 BMW R1200C
2003 Subaru Baja |
Posted: Thu Jul 02, 2015 11:03 am Post subject: |
Yes, I replaced my starter when it happened a couple of times to me.
I also installed a "hard start" relay. This allows all those yards of wire to just carry enough current to operate the relay. And then the relay dumps power right from the battery to the starter selonoid. Every short distance that way. _________________ 1969 VW Beetle Convertible |
Posted: Sat Jul 04, 2015 9:02 am Post subject: |
Cusser wrote: |
Even places like O'Reilly and AutoZone will have starters, but I prefer "rebuilt by Bosch" (if still available) rather than a Bosch starter that has been rebuilt. |
Hello all
I replaced my starter last night. It only took 20 minutes thanks to the instructions given by Cusser.
I did the unthinkable and bought a cheaper brand starter with the intent that it would get me home and I'll rebuild my original one when I get there.
I bought the starter at http://www.sebringwest.com/parts.htm and they gave me good confidence in the unit I bought.
Anyway, she fires right up now and I'm a bit more confident about setting out tomorrow morning for the 1100 miles we have to get home.
Thanks again everyone.
Cheers
Paul |
Cusser Samba Member
Posted: Sat Jul 04, 2015 12:36 pm Post subject: |
If that new starter stays working, leave it installed !!!
Also, learn how to push-start your VW, you at least won't get stranded by a bad starter again. Happy drive home. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
