asagodowns Samba Member
Joined: January 29, 2004 Posts: 156 Location: North Carolina
Posted: Sun Feb 15, 2004 1:09 pm Post subject: Need information on roller crank! |
What is a roller crank and can anyone provide info. about them? |
toyjunk Samba Member
Posted: Sun Feb 15, 2004 2:43 pm Post subject: i have one |
this one is like new dont know anything about them would like to know myself thanks |
55samba Samba Member
Joined: June 21, 2002 Posts: 805 Location: CA Bay Area
Posted: Sun Feb 15, 2004 7:57 pm Post subject: |
I'll try not to make it too long, there are SPG roller cranks for VW's and Hearth for Porsches.
Sticking to the Spg cranks, they were made in the 60-70's, multi piece pressed together at the rod journals because the rods are one piece with roller bearings. The SPG cranks had no keys or splines so they could be twisted out of alighnment from hard starts ect. Detonation could also damage the rod bearings, there were no oil holes so you would have to cut groves in your main bearings to spray an oil mist for the lube slots in the rod bearings to catch as they rotate. The piston should be special with a correct inner spcing to guide the rods because they had no real guide on the crankshaft.
This type of crankshaft is worthles today, dont waste one moment on one, there are very few who can work on these and have the right tools to do so. Renn Sport was the only person I new of in the US who had the correct tools to align one up. Back in the day people would weld the joints on these so they would not twist them, you could not service them after that. |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4852 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Mon Feb 16, 2004 12:02 am Post subject: |
I could not agree more with 55samba, They are not worth the time/money. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
george4888  Samba Member
Joined: December 29, 2003 Posts: 730 Location: Hitchcock, Texas
Posted: Tue Feb 17, 2004 9:59 pm Post subject: Roller bearing cranks |
I agree that you should forget about the roller bearing crank. Porsche is the only one I know of that tried them and had lots of problems with them. If the Porsche factory stops using something, you know it has problems.
If you can find one, they probably cost in the thousands. Forget it--it is a bad idea. They were only good for limited low rpm road racing. They blew apart with higher rpms, so if you think the roller design would allow for higher rpm's , you are wrong. The way they were put together, they would twist at higher rpms. See the books, written by Harry Pellow, the POrsche 356 genius. He has pictures of the cranks twisted and broken. Being a Porsche expert, Harry agreed that it was not one of the factory's best ideas.----George |
Posted: Wed Feb 18, 2004 5:44 am Post subject: i already have one |
looks new was given to me |
gears Samba Member
Joined: October 28, 2002 Posts: 4411 Location: Tamarack, Bend, Kailua
Posted: Wed Feb 18, 2004 11:02 am Post subject: |
The Porsche 356 roller cranks were physically small, and thus weaker than the VW ones. In the '60s & early '70s, the SPG roller was the only option for stroking the VW engine. So long as you didn't dump the clutch, and so long as the oil was changed with regularity, these cranks lasted a very long time. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Wed Feb 18, 2004 5:14 pm Post subject: |
The thing about the cranks getting " twisted" is that it took alot of horsepower and a real hard launch/ bite to do it. So assuming every one of these cranks you run across is tweaked is probably not likely.
ANd possibly more likely to happen to the 82 stroke and not the 69 for obvious reasons.
the best info I've read on these old school cranks is in Bill Fisher's "How to Hot Rod Volkswagen Engines" by H. P. Books...
I think Pauter Machine or Rimco may be able to answer some questions on the modification needed to the mains.
I also heard ( although I have not tried it) that by assembling the crank . bearings and case... no cam or lifters needed) ( even on un modified bearings) and test fitting the cylinders, by careful measurement of the deck height you could check and see if the height was all the same, thus showing if one of the sections was indeed "twisted"
Has anyone else heard that ?...or think it is a feasable way to get some indication of if the crank is twisted? |
ekimthemad Samba Member
Posted: Wed Feb 18, 2004 6:18 pm Post subject: |
keifernet wrote: |
It might be beneficial to use a good crank pulley with a degree ring and check the actual TDC of each piston against the markings on the pulley. Maybe with a combination of the two checks it could be done. Obviously any binding would be a sure sign.
A lot of the small motorcycles use a similar design. Maybe someone that has a lot of experience with those cranks may know more about testing them other than with a dial indicator in a fixture.
Mike
59 single, 69 bus, 73 super _________________ Remember never argue with a moron. They'll drag you down to their level and beat you with a lifetime's worth of experince. |
E-boyz67 Samba Member
Posted: Wed Feb 18, 2004 9:33 pm Post subject: |
Like 55 samba said not worth it. Back in the early 70s I had spent a grand to have Brian Croford of Prototypes Plus do the work to make that crank as strong as possible.He did a beautiful job,welded steel pins through and around the areas where the crank is pressed together. The stroke was 78.4, pistons/cylinders were 90.5,cam was engle K-8 with 1.4 rockers,heads was 40/37 D port and polished,cced and 1 5/8 merge/dual mufflers and webers. Its also a very heavy crank and I don't recall the weight. One thing is that the motor would rev and accelerate quickly and decelerate as well. It lasted for a while due to the fact that I never would do a full on drag start, it was always a rolling start. Sold the motor to a friend and told him the rules about drag starts and few month later he told the motor blew to pieces. I asked what happened and his reply, I broke rule # 1 never do a drag start. _________________ 2-67
1-67vert
yetibone Samba Member
Joined: February 19, 2004 Posts: 163 Location: Not here.
Posted: Thu Feb 19, 2004 5:11 pm Post subject: |
Funny thing about roller cranks is that they actually have MORE friction than plain bearing cranks, but LESS rolling resistance.
Since the needle bearings at the rod journals have less surface area than lead-babbet bearings, the bearings tend to push oil out of the way, instead of riding on a film of oil.
Plain bearings, however, have a much greater surface area that can be supported by oil, and thus the friction is reduced. |
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Fri Jul 06, 2012 1:09 pm Post subject: |
yetibone wrote: |
But wouldn't the rolling aspect make up for the friction? Like the difference between a wheel and a sled. The wheel has more friction because hypothecitally if it were locked up it would stop very quickly. The sled, however, creates more drag and relies on snow or ice to have less friction. But when compared together the "wheel" or roller is normally the perfered choice over the "sled" or shell bearing in many applications not only because of reduction in drag but also because of longevity. For an example VW went to roller wheel bearings way back in the beginning. These lasted much longer than solid wheel bearings. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Fri Jul 06, 2012 3:00 pm Post subject: |
Plain bearings are waaay better at supporting heavy loads than roller bearings - as compared when weight and bulk is an issue. At the wheel bearings, this is not much of an issue but at the crank it is.
Roller bearings are also bad when the engine detonates - they may desintegrate not so gracefully...
Plain bearings have less friction, but higher starting friction - which is only of interest when the engine is started. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23088 Location: Oklahoma City
Posted: Sat Jul 07, 2012 8:05 am Post subject: |
Juanito84 wrote: |
yetibone wrote: |
But wouldn't the rolling aspect make up for the friction? Like the difference between a wheel and a sled. The wheel has more friction because hypothecitally if it were locked up it would stop very quickly. The sled, however, creates more drag and relies on snow or ice to have less friction. But when compared together the "wheel" or roller is normally the perfered choice over the "sled" or shell bearing in many applications not only because of reduction in drag but also because of longevity. For an example VW went to roller wheel bearings way back in the beginning. These lasted much longer than solid wheel bearings. |
No ..... even though friction and rolling resistance is inter-related...they are not the same thing. They are measured differently.
You CAN have much lower rolling resistance and still have high actual friction. This issue on roller cranks is strictly because you have metal to metal contact on the needle bearings. This does not mean that the friction is harmful. If it were...none of your transmissions would operate. They all have roller and needle bearings. However when friction gets high enough...like if piston drag is excessive or the roller bearings get too tight because of heat expansion or poor tolerance....or if the rollers get screwed up....yes.....rolling resistance will increase.
A great example of this that many railroad afficionados will know....is that in the 1930's.....Timkin had a Northern type 4-8-4 steam locomotive outfitted with their new (at the time) roller bearings on all axles. Until that point all locos had pressurized oil fed plane bearings (just like our engines). This train traveled the country from coast to coast with a rolling dyomometer car attached as a working showcase for Timkin roller bearings. The documented savings in coal/fuel was close to 25%....due to lower rolling resistance...even though roller bearings with their metal to letal contact jave much higher friction coefficient than oil fed bearings.
Its worth it to rememeber that these locomotives wwith tender weighed over 325,000 pounds .
What this all means is that the engine spins and revs more easily with less hp loss.
The SPG roller cranks...many years ago I spoke with a few people who used them long ago...worked fine....after you pinned the journals.
The problem is that they were designed to reduce the power necessary at cruise rpms.....which they did quite well. A great many aircraft engines in the 20's, 30's and 40's used roller cranks for this very purpose.
Bugatti used them eons ago on their straight 8 engines (I think theirs were splined). Roller cranks really had usage in the days when max hp on engines was much lower than engines these days.
They were primarily designed for road racing.
The people who really had problems with unpineed/unsplined roller cranks are those who used them for drag racing. Drag racing is a high hp high torque event ....much different from road racing.
But because these cranks are 40+ years old now...unless you found one known to be new in the box....it probably is bent. I wouldn't waste the money either. Ray |
Posted: Sun Jul 08, 2012 2:19 pm Post subject: |
So - why did every engine maker in the world stop using them? Except some small engines like mopeds and such?
There is no problem making split rollerbearing shells, so pretty ordinary cranks can still be used.
I would suggest because they are unsuitable for internal combustion engines of our kind.
If they had better efficiency, they would be used in F1 for example, but they are not. |
