knewknew Samba Member
Joined: July 06, 2007 Posts: 217 Location: Alexandria, VA
Posted: Tue Jul 28, 2015 6:13 pm Post subject: Headlights are dead. Possible bad turn signal lever? |
My high and low beams will not turn on. They worked fine one minute, then poof. Nothing.
I checked the fuses and they are good. Fuse terminals are clean too.
However, now the turn signal lever is acting funny. When using the turn signals, the flash indicators (green arrows) will blink only once. But, the relay is clicking fine, and the signals are blinking as they should.
Also, when pulling on the high/low beam switch, it no longer 'clicks' into place. ....But, I cannot recall for sure if there is supposed to be a mechanical 'click' or not. Is there??
If there is, then I am sure the lever has gone bad. But id like to know if there is anything else I should try before tearing apart my steering column. How bad of surgery is it? _________________ 1970 Squareback |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue Jul 28, 2015 7:24 pm Post subject: |
There should be a brown ground wire that pushes onto a tab at the top of the fusebox mounting screw closest to the column. Did that wire come off? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Wed Jul 29, 2015 7:04 am Post subject: |
There is no click in the high beam switch function on the T/S arm. You are just hearing the relay click. The arm just closes a wire momentarily to trigger the latching headlight relay.
You say the fuses are good but can you tell where you do or don't have power in the circuit? Do your brake lights work? Running lights? |
Posted: Wed Jul 29, 2015 2:39 pm Post subject: |
Hey guys, so this afternoon I cleaned every terminal on the fuse box and checked for loose connections under the dash. Nothing stood out, and the problem still persisted.
I then checked to see if there was 12v being sent to the headlight fuse terminals (3/4/5/6). I was turning the headlight switch on/off and there was no change. However, I then tried the signal lever (high/low) and heard the relay finally 'click'. I tested the fuses again got 12v. The fuses went back in and the headlamps worked!
I am happy to have it working again, but really wish I knew what went wrong in case it acts up while I am on the road.
Another problem not solved is the turn signal light indicators. The signals outside of the car work as before, however, the green arrow lights on the gauge only flash a single time when the switch is first turned on. The relay is clicking, the lights are blinking, but not on the gauge.
Could it be a funny relay? I still think it might be the signal lever. Any other ideas? thanks! _________________ 1970 Squareback |
grandpa pete Samba Member
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Wed Jul 29, 2015 5:28 pm Post subject: |
It says '1970 Squareback' in his signature! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Jul 29, 2015 8:26 pm Post subject: |
Mike Fisher wrote: |
It says '1970 Squareback' in his signature! |
Yeah, it is my '70 square. Sorry for any confusion. _________________ 1970 Squareback |
Posted: Thu Jul 30, 2015 12:21 pm Post subject: |
Hello Mike ; I saw the signature ; I wasn't going to dig into wiring diagrams until I KNEW what year we were looking at . .....Thankyou for playing
knewknew ; I don't see anything in common in the headlight circuit that might affect directional except grounds......... The same capacitor in the flasher that blinks the directional should blink the dash lights ..........ground troubles can be tough to trace . It's easier to just clean them all . sorry I couldn't be more help .
If it isn't an expensive part I would try changing the flasher . _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Wed Aug 05, 2015 3:16 pm Post subject: |
One theory I am looking into is a bad ground at the gauge housing. But holy crap, it is hard to get to!
I tried to remove the headlight switch to clean the terminals and spray contact cleaner in the unit. One of the wire tabs broke off, so now it looks like I have to get a new switch, doh! _________________ 1970 Squareback |
Posted: Fri Aug 07, 2015 6:37 am Post subject: |
knewknew wrote: |
I tried to remove the headlight switch to clean the terminals and spray contact cleaner in the unit. One of the wire tabs broke off, so now it looks like I have to get a new switch, doh! |
I've seen several threads about using a zip tye to keep broken switches together _________________ 63 two fold rag
vdubin Samba Member
Joined: September 09, 2006 Posts: 305 Location: Huntsville, Al
Posted: Fri Aug 07, 2015 8:25 am Post subject: |
a friend of mine had a prob like this on his 67 beetle. we ended up jumping 12v across the headlight relay, from 12v in to the headlight 12v outs, and that reset the relay and it started working. been fine for two years. your mulimeter testing could have done the same thing. _________________ If at first you don't succeed... Get a Big Friggin' Hammer!!! |
gnarballs Samba Member
Posted: Fri Aug 07, 2015 10:28 pm Post subject: |
i drive a 72 regularly. I have had the same problems but i can get them to turn on every time by jiggling one of the wire plugs on the belly of the column. the one just to the left of the ignition one i believe. The plastic cover on the bottom of my column is off allowing access. Works every time for me. |
