Cab Door ID T2
Tcash
Tcash is offline
PostPosted: Mon Mar 14, 2016 9:48 pm    Post subject: Cab Door ID T2 Reply with quote
To link to this thread
Code:
[url=http://www.thesamba.com/vw/forum/viewtopic.php?t=650351&highlight=]Cab Door ID T2[/url]
CAB DOOR ID
First off, thanks to everyone who posted data!
68 only, 2 access holes, pull knob lock, push button outer handle, 15mm pins
69 only, 2 access holes, lever door lock, 15mm pins
70-71 1 access hole, lever door lock, 15mm pins
72-73 riveted vent slide, lever door lock, 15mm pins
74-75 riveted vent slide, pull knob lock, 15mm pins
75-76 riveted vent slide, pull knob lock, 8mm pins
76-M77 welded vent slide, pull knob lock, 8mm pins
M77-79 welded vent slide, pull knob lock, 8mm pins, Check Strap changed
1968 only to Ch# 218 220 000
Lock pull knob by window, push button outer handle
1968-75 #3 to 215 2 153 712
15mm pins
1969-73 Ch# 219 000 001 to 213 2 300 000
lock moved next to release lever
1969-79
outer handle changed to pull lever, at some point key tumbler became not removable
1972-E76 from Ch# 212 2000 001 to 2162 047 257
vent introduced in door, rivited slide
1974-79
Door lock Pull knob moved back by the window
M75-M76 215 2 153 713 to 216 2 126 631
#(2A) transition? 9mm pins, countersunk hinge half
M76-79 216 2 126 632 to 219 2 300 000
#2A 9mm pins, threaded hinge half
1976-79 from 2162 047 257
Vent slide welded to door instead of riveted.
M77-79 from Ch# 2172 137 043
check strap changed
Hinge Half
>75 #2 15mm hole Countersunk mounting holes 1975 to 215 2 153 712
M75-M76 #(2A) transition? 9mm 215 2 153 713 to 216 2 126 631
M76-79 #2A 9mm 216 2 126 632 to 219 2 300 000
Hinge Washer
#6 either to 71 or from 72 ??
Hinge Pin
>75 15mm #3 to 215 2 153 712
1975-79 8mm 215 2 153 713 to 219 2 300 000
New front door hinges (from 236-2126-632)type2.com
Ventilation opening
1972 Ch# 212 2000 001 introduced in door
1976 from 2162 047 257 Vent slide welded to door instead of riveted.
Inner door lock
1968 Door lock Pull knob by the window
1969-73 Lever door lock moved next to release lever
1974-77 Door lock Pull knob moved back by the window
Outer door handle
1968 push button where key is inserted in middle of handle used to open door
1969-79 release lever on handle between handle and door cavity now squeezed to open door
Check Strap
1968-77 to Ch# 2172 137 042 wire spring with rollers, Strap vertical, Mounting holes ????
1977 from Ch# 2172 137 043 Nylon insert, Strap now horizontal and flat, Mounting holes ????
http://www.jerseylooker.com/FicheDump/EarlyBaywindow/EarlyBay-Main.html
http://www.jerseylooker.com/FicheDump/LateBaywindow/LateBay-Main.html
15mm Hinge halfs. To 75 #2 15mm hole Countersunk mounting holes 1975 to 215 2 153 712
M75-M76 transition? 8mm pin countersunk hinge 215 2 153 713 to 216 2 126 631
9mm Hinge half attached to door. Requires 8mm pin. 1975-79 215 2 153 713 to 219 2 300 000
[Left 15mm pin, countersunk hinge 68-M75][Middle transition hinge? 8mm pin, countersunk hinge M75-M76 ][Right 8mm pin, threaded hinge M76-79]
Hinge Washer
#6 either to 71 or from 72 ?? The parts manuals are in conflict with this one. Either the washers where dropped in 71 or added in72??
Early door pillar mount 68-M76
Late door pillar mount M76-79
Cab door hinge conversion kit. This 8mm cab door hinge pin conversion kit allows the fitting of early and late T2 doors (from T2s made between 1969-1976) to any T2 from 1967–1979.
Check Straps
Front door hinges - Conflicting Information
Bay Window Front Door Latch Problems
Replacing the '69-79 Bus Front Door Lock Spring
Installing Door Panels
Restore, Rebuild, Refurbish Front Door
door check sound like a gun shot?
(door) Vapor Barrier Replacement How-To, Colin
Please post any revisions or additional information.
Thank you
Tcash
agave57
agave57 is offline
PostPosted: Wed Oct 27, 2021 7:47 am    Post subject: Re: Cab Door ID T2 Reply with quote
Hi guys.
How did you manage to get out the pin and make one oversize on the fixed part please?
