Dmuldoon Samba Member
Joined: July 10, 2019 Posts: 34 Location: Huntington Beach ca
Posted: Mon Sep 16, 2019 9:49 am Post subject: Trailers |
Who uses a t trailer to tow their buggy. Let see them. Wanting the lightest possible trailer for my rail. Hauling with my suv that maximum tow is 5k. What’s the options cheapest option possible. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20388 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Sep 16, 2019 10:44 am Post subject: Re: Trailers |
Old skool "T" trailer...Dont get much lighter...
I seriously doubt even with small 2 wheel utility trailer and sand rail you will come close to your 5K limit...
https://www.frenchtowntrailer.com/2020-quality-ste...7CMmb.html
My 2 axle car carrier (7K gross) only come in at about 1400 pounds empty...
Posted: Mon Sep 16, 2019 12:12 pm Post subject: Re: Trailers |
These are custom built? Or where do I find them for purchase? |
Posted: Mon Sep 16, 2019 1:09 pm Post subject: Re: Trailers |
Dmuldoon wrote: |
Usually custom built. You could possibly pick up a tow dolly and have welding shop extend the tongue..
That is also why I included suggestion of basic utility trailer....
cbeck Samba Member
Big Al Samba Member
Joined: June 14, 2014 Posts: 184 Location: Tucson, AZ
Posted: Wed Sep 18, 2019 11:13 am Post subject: Re: Trailers |
If you can fabricate, a boat trailer is an easy conversion. Plus, they have more ground clearance than most car trailers. Picking the right trailer to modify is the most important part. I advertised on craigslist and found many with the boat still on them. Opted for a bare trailer for $200.
My friend found an old house trailer frame and made a two buggy trailer. We used 2X12's for the rails. Very easy to do.
Al |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5371 Location: Lefty, CA
Posted: Thu Sep 19, 2019 1:18 am Post subject: Re: Trailers |
Personally, I would see if you could find a junk tent trailer, and use its frame. That's what I started with. I got lucky and found a stripped one for $110. Bought an axle with brakes for $50 and turned it into this.
A rail would fit on it, and it is so light that one person can pull it around. As loaded it has more weight on it than a typical rail and it tows like a dream. It has to for me because I pull doubles. As it is loaded, it probably has close to 2000lbs of cargo on it. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Big Al Samba Member
Posted: Thu Sep 19, 2019 9:29 am Post subject: Re: Trailers |
Multi69s wrote: |
PIX Deleted...
A rail would fit on it, and it is so light that one person can pull it around. As loaded it has more weight on it than a typical rail and it tows like a dream. It has to for me because I pull doubles. As it is loaded, it probably has close to 2000lbs of cargo on it. |
In Arizona you can only pull doubles IF the first trailer is a goose neck or fifth wheel.
Don't ask how I know that:)
Al |
Posted: Mon Sep 23, 2019 11:33 am Post subject: Re: Trailers |
love the flat trailers but I can not justify spending the cash on that at this moment. looking for a cheap alternative one that is also able to be stood up in the side of the house when not in use Or if length will work, slid under sandrail. In garage. I like the modify idea going to need to check into the modifications. Also keep my eye out online see what I see |
Stormin189 Samba Member
Joined: February 14, 2018 Posts: 55 Location: Santaquin utah
Posted: Fri Mar 08, 2024 5:42 pm Post subject: Re: Trailers |
