zoti Samba Member
Joined: December 26, 2007 Posts: 2065 Location: Plano, TX USA
Posted: Mon Jan 17, 2022 4:45 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Some updates.
The board design is progressing and most of it is already laid out again. We are going order prototypes and keep testing.
dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
Posted: Mon Jan 17, 2022 6:23 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Thanks for the update, can’t wait to try one.
Went on a road trip today and the idle finally got so bad surging up to 3k I had to unplug the unit to get home. Until today running the A/C would keep my idle normal, but that trick is sadly no longer working.
I think you will sell a lot of these _________________ Driving a 90 Carat since 2014
Previous Buses: 59 Westy, 60 Westy, 74 Bus, 82 Westy, 85 Westy, 87 Syncro
Checkout my Syncro Video: https://www.youtube.com/watch?v=0JSWhLS7jLY |
zoti Samba Member
Posted: Mon Jan 17, 2022 7:48 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
dart330 wrote: |
I think you will sell a lot of these |
As a temp solution you can disconnect the idle air control valve and then raise idle by 50-100 rpm. You can do this in the summer only. |
4Gears4Tires Samba Member
Posted: Mon Jan 17, 2022 8:05 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
And you raise the idle by turning the big flat screw on the throttle body counter clockwise. _________________ '87 Syncro
zoti Samba Member
Posted: Wed Feb 02, 2022 8:58 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Today I am sharing a video my partner made of the actual valve in the idle control valve and how it reacts when you turn the AC on or off and use power steering.
On the left is our simulation running on a PC. It controls a prototype of the driver for the valve. On the right is the valve itself. You can see how it reacts to the extra load required at idle.
The valve has a delay because not all the code is implemented yet.
zoti Samba Member
Posted: Fri Feb 18, 2022 5:07 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Our prototype board and code is going along. This seems a bit complicated but basically all these components will end up on the actual board.
We currently run everything with inputs that simulate the engine but obviously once we have our prototype it will run of the engine and we will make final adjustments.
VWagabond Samba Member
Joined: March 19, 2011 Posts: 272 Location: Charlotte, NC
Posted: Fri Feb 18, 2022 9:20 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
I want it..I want it..I want it....you can't have it!!!! At least not yet. Looking forward to the release date. _________________ The Road Goes Ever On & On……...
VWagabond
87 Camper GL
87 Syncro GL |
VWagabond
87 Camper GL
87 Syncro GL |
VWagabond
87 Camper GL
87 Syncro GL |
Posted: Fri Feb 18, 2022 9:21 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
VWagabond
87 Camper GL
87 Syncro GL |
VWagabond
87 Camper GL
87 Syncro GL |
zoti Samba Member
Posted: Sat Feb 19, 2022 10:22 am Post subject: Re: Idle Stabilizer Control Unit Alternative |
VWagabond wrote: |
I want it..I want it..I want it....you can't have it!!!! At least not yet. Looking forward to the release date. |
I know it looks simple and I admit I thought it is not that complicated but as we dive more and more into it we find more stuff. We also want it to be reliable of course so we are testing everything. |
AirCooledCurtis Samba Member
Joined: June 26, 2012 Posts: 35 Location: Portland, OR.
Posted: Sun Feb 20, 2022 4:21 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Oof this looks incredible. My ICU is starting to slowly give me more and more problems. I suppose I'll have to try my hand at repairing mine while I wait for these to be on sale. |
Vana Guy Samba Member
Posted: Sun Feb 20, 2022 9:04 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
That is some very impressive work!
You might want to throw some capacitors at the ends of those power busses on the bread boards. |
zoti Samba Member
Posted: Mon Feb 21, 2022 11:42 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Today I started working on a test platform that will enable us to run each unit attached to the van and have banana connectors so we can scope it.
Posted: Tue Feb 22, 2022 6:15 am Post subject: Re: Idle Stabilizer Control Unit Alternative |
Very exciting and cool! _________________ '87 Syncro
zoti Samba Member
Posted: Wed Mar 02, 2022 9:54 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
So exciting news. We received the prototype boards from the manufacturer and are testing the fit to the box and starting to load them with components.
The code is almost complete as well.
zoti Samba Member
Posted: Wed Mar 02, 2022 10:54 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Wed Mar 02, 2022 11:37 pm Post subject: Re: Idle Stabilizer Control Unit Alternative |
Fantastic! I can't wait 👏🏻 |
