mazzidumato Samba Member
Posted: Wed Jun 01, 2022 2:16 pm Post subject: Gas leaking when tank is filled completely. Help please. |
I filled the tank after replacing the fuel lines and all of a sudden had a lot of dripping in the center of the van. Upon inspection and lowering the gas tank (picture 1) is what I noticed is broken. Does anyone know the name of these? According to the mechanic here i Mexico, these are for the gas fumes to leave and shouldn't leak unless the tank is over filled. Maybe replacing this broken part might resolve. Any suggestions? And if there are parts similar that I would find in Mexico?
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Wed Jun 01, 2022 2:31 pm Post subject: Re: Gas leaking when tank is filled completely. Help please. |
That's the cross over.
They always break.
Reseal your tank, since you have it out now.
Buy the kit and these fittings will be included.
https://gowesty.com/products/fuel-tank-re-seal-kit _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Wed Jun 01, 2022 2:36 pm Post subject: Re: Gas leaking when tank is filled completely. Help please. |
mazzidumato wrote: |
This is one of the most common problems with a Vanagon.
Your mechanic is right - the hoses are for fumes to escape the tank and go into the evaporative system (those plastic boxes in your front wheel wells). He's NOT right that overfilling is the problem - the problem is obviously the broken fitting and can also be due to old hoses or bad o-rings on the filler neck, fuel level sender, or where those fittings plug into the tank.
All of the vendors sell the parts to fix that stuff
I would go with this one but it's out of stock right now;
https://vancafe.com/complete-2wd-fuel-tank-reseal-...-fittings/
So there's this one;
https://vancafe.com/complete-2wd-fuel-tank-reseal-kit-with-plastic-pipe-fittings/ _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1092 Location: Atlanta, GA
Posted: Wed Jun 01, 2022 2:54 pm Post subject: Re: Gas leaking when tank is filled completely. Help please. |
Plastic and rubber on these vans, especially with the fuel system gets brittle and fails over time.
You can go with new plastic fittings like the one in the previous comment. I know I've seen some folks fit metal fittings for those hoses too.
If that failed, check and see if you still have the plastic fuel connector on the firewall (passenger side) that connects the fuel hose from the fuel filter to the fuel supply hose coming in to the engine system. If you still have that item have it removed and replaced with a metal unit. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion-Road Testing Phase
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
Posted: Wed Jun 01, 2022 3:45 pm Post subject: Re: Gas leaking when tank is filled completely. Help please. |
Since we are in Mexico and couldn't find the specific parts. This is what the mechanic thought of. Any reason this could be a problem?
skemems Samba Member
Joined: February 23, 2017 Posts: 207 Location: Portland
Posted: Wed Jun 01, 2022 3:53 pm Post subject: Re: Gas leaking when tank is filled completely. Help please. |
As long as the hose going into the seals are snug and have a good seal, that should work. The plastic replacement however has ridges that prevent it from popping out. _________________ 87 VW Westfalia - EJ25
86 VW Westfalia - EJ22
85 VW Westfalia - WBX 2.1 project |
Posted: Wed Jun 01, 2022 3:55 pm Post subject: Re: Gas leaking when tank is filled completely. Help please. |
Thanks skemems. This is pretty tight. 👍👍 |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4029 Location: Redwood City, California
Posted: Wed Jun 01, 2022 7:42 pm Post subject: Re: Gas leaking when tank is filled completely. Help please. |
This may have been covered in great detail a time or two before, this is a great time to learn to use the FAQ’s they are quite handy and cover 99% of what happens to our vans.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Wed Jun 01, 2022 8:41 pm Post subject: Re: Gas leaking when tank is filled completely. Help please. |
You don't want any undue force between the fitting and the grommet, as that may cause a leak. What you have shown may well work, but I would try to find molded hoses to fit onto the vertical fitting to take some of the twist out of how the hoses fit. Maybe use what the mechanic has made up for now and order the correct parts. My experience is that some kits are way better than others, but its been quite a few years at this point since I bought a kit, so don't want to comment on any specific one. |
netforest Samba Member
Posted: Sat Mar 16, 2024 11:00 am Post subject: Re: Gas leaking when tank is filled completely. Help please. |
I have a similar issue when I fill up the tank and after driving awhile the issue is resolved. Anyone know what the cost might be to have a VW repair shop fix the issue? |
Borg Samba Member
Joined: October 18, 2012 Posts: 120 Location: Western Washington
Posted: Sat Mar 16, 2024 11:15 am Post subject: Re: Gas leaking when tank is filled completely. Help please. |
netforest wrote: |
It "resolves" because driving around drops the fuel level below whichever seal,fitting/line is leaking. Don't fill the tank all the way is one (temporary) solution, but that only works if your leak isn't as catastrophic as the OP.
The usual vendors have re-seal kits, $100-$120(?) for parts but the real work is getting the tank out. You can do it on the ground (I did with the van on jackstands) but a lift would be easier. Messy job too, lots of crusty and probably fuel dosed junk up in there. Snaking the evap and fuel lines is kind of fussy too.
Start to finish by a knowledgeable Vanagon mechanic with a lift....I'd budget 4 hours of shop time. Potentially less than that but you just never know what gremlins are lurking, and you may as well get all the lines in the system done while you are in there. _________________ Steve |
Joined: January 01, 2007 Posts: 16893 Location: sticksville, ct.
Posted: Sat Mar 16, 2024 11:31 am Post subject: Re: Gas leaking when tank is filled completely. Help please. |
Borg wrote: |
.I'd budget 4 hours of shop time. Potentially less than that but you just never know what gremlins are lurking, and you may as well get all the lines in the system done while you are in there. |
1 day (8 hours) minimum for a full reseal.
It takes a lot of TLC to remove all of this shit and not break a nipple off of the expansion tanks when replacing the lines
Also, brace for impact...I use legit fuel injection clamps not those asshole oetiker clamps and there is a TON of clamps.
you're looking at 1k easy for a shop charging 100/hr and 100/hr is cheap these days _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
jimf909 Samba Member
Posted: Sat Mar 16, 2024 11:47 am Post subject: Re: Gas leaking when tank is filled completely. Help please. |
^^^ $100 an hour is dirt cheap anywhere where people live. Don't be surprised if any shop willing to accept this job charges $185/hour. _________________ - Jim
Abscate wrote: |
E1 Samba Member
Joined: January 21, 2013 Posts: 6617 Location: Westfalia, Earth
Posted: Sat Mar 16, 2024 11:56 am Post subject: Re: Gas leaking when tank is filled completely. Help please. |
If you still have the original tank, and pay for this work, personally there’s no way I’d pay for the labor and NOT replace the fuel tank.
There’s still plenty of $100/hr shops in America around in less-expensive areas of the country. I’d suspect Panama is half of that. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9811 Location: Mt Lemmon, AZ
Posted: Sat Mar 16, 2024 12:46 pm Post subject: Re: Gas leaking when tank is filled completely. Help please. |
I just had this done at a Tucson shop -- I provided the kit and they did the work: $500.
I'm past an age where I enjoy lying on my back under cars and I no longer have my lift so I was happy to pay. Everything was perfect the first time (which isn't always the case with this project).
Filled the tank to the absolute max: no runs, no drips, no errors.
Looking at the bill, they charged me for 3½ hours @ $140/hour plus $10 in shop supplies. This is a shop that specializes in Mercedes, Porsches, BMW and Vanagons.
I brought the van in with the tank almost empty and a 1 gallon can of gas on board.
Posted: Sat Mar 16, 2024 12:50 pm Post subject: Re: Gas leaking when tank is filled completely. Help please. |
E1 wrote: |
yea...about that...
new tank, filled to the top. Didn't leak until day 2 or 3....right from the seam. _________________
Jake Raby wrote: |
Brian wrote: |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1892 Location: Montreal
Posted: Sun Mar 17, 2024 3:51 am Post subject: Re: Gas leaking when tank is filled completely. Help please. |
I just did this job on my van last Thursday. 6 hours for me including draining 1/2 tank of gas. I already did a reseal a couple years back, the reason this time was a tank swap for the 12mm outlet, and later fuel filter, getting rid of that plastic cube.
My clamps were all "new" fuel injection clamps so undoing was a breeze.
I reused all my seals as they were mint from having just been done a couple years earlier, so no surprises. The evap lines are the biggest pain in the butt to fish through. The tank I took out is extremely clean, my vehicle has not seen winters, so if you are doing a reseal, I would not automatically change the gas tank, unless it looks crusty. I really prefer OEM VW parts as opposed to some of the trash being offered today.
That being said the Spectra tank I bought looks well made and fit perfectly. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22680 Location: NYC/Upstate/ROW
Posted: Sun Mar 17, 2024 4:58 am Post subject: Re: Gas leaking when tank is filled completely. Help please. |
E1 wrote: |
There’s still plenty of $100/hr shops in America around in less-expensive areas of the country. I’d suspect Panama is half of that. |
$20 an hour _________________ .ssS! |
sanchius Samba Member
Posted: Sun Mar 17, 2024 6:35 am Post subject: Re: Gas leaking when tank is filled completely. Help please. |
Wellington wrote: |
Yes, the spectra replacement tank worked well for me as well: https://www.rockauto.com/en/catalog/volkswagen,199...+tank,6268
With these vehicles approaching 40 years old, moving away from fixing individual broken components and towards renewing the whole system whenever possible/affordable has greatly increased the reliability of my van.
When my original gas tank started shedding enough rust to clog the filter, I replaced the tank, the crossover lines & valves, outlet hoses, fuel filter, and fuel pump. I should have also replaced the vapor recovery tanks in the front wheel wells at that time as well. There was nothing technically difficult about this job, just some manual labor getting everything in place. It took me a couple tries to get the crossover lines run correctly with no upward tension, so they weren't pulling the vapor valves out of the top of the tank. My biggest worry was whether I could get the big fuel filler tube sufficiently sealed going into the tank.
Everyone has their own optimal sweetspot for repairs between cost and effort. I tend to overdo it on the DIY side because I enjoy classic car work, I have most of the tools I need, and not paying labor rates gives me so much more runway to buy additional parts and more fun tools. _________________ The Syncro years (2005-16) - The 2WD years (2017-23) - Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Your gold star membership keeps this awesome list going! |
E1 Samba Member
Posted: Sun Mar 17, 2024 8:07 am Post subject: Re: Gas leaking when tank is filled completely. Help please. |
skills@eurocarsplus wrote: |
E1 wrote: |
yea...about that...
new tank, filled to the top. Didn't leak until day 2 or 3....right from the seam. |
Forgot about the “new parts, better or not?” factor.
Geez, that’s just not right… _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
