kamzcab86 Samba Moderator
Posted: Fri Oct 13, 2023 10:29 pm Post subject: Re: Rear Disc Brake Comparison |
space wrote: |
Converted to rear discs and never looked back
Would do it to any and all future vanagons |
Ditto. One of the best upgrades done to my van. The drums, completely overhauled not terribly long after buying the van, never worked adequately, particularly in the e-brake department. Now, I don't need to use a chock when parking on hills.
GoWesty kit. _________________ ~Kamz
2016 Golf GTI S
RGS Paul Samba Member
Joined: April 20, 2007 Posts: 663 Location: Los Alamos, NM
Posted: Sat Oct 14, 2023 6:14 am Post subject: Re: Rear Disc Brake Comparison |
I love mine, absolutely an improvement in consistency and parking brake compared to the drums.
I went GoWesty after buying a full Epytec kit because I couldn't find a local shop to turn my hubs. My brother also got the GW kit after trying mine and I gave the Epytec kit to my Dad because he has a couple hobby machinist friends. The price between GoWesty and Epytec was a wash once you include machining and finding all the extra parts you need to source.
One thing l like about the GW F/R kit is that both calipers are from 'trucks,' so I could get matched pad compounds front and rear. I put in EBC Green Stuff pads to get goo initial bite and a consistent braking feel as you modulate pressure.
In regard to the proprietary disks from GW, I figure if I buy an extra pair of front and rear rotors in the next year or so and replace everything in 5-6 years ( I never turn rotors) that gets me at least another decade of good braking. In a decade there will either a) GW will still sell the disks, b) there will be a good alternative kit to try or c) a lot of other stuff will change and driving a 50+ year old vehicle regularly will be a bit impractical.
Paul _________________ '87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman |
Multiman mv Samba Member
Joined: January 24, 2017 Posts: 987 Location: Martha's Vineyard, Ma
Posted: Sun Oct 22, 2023 4:23 am Post subject: Re: Rear Disc Brake Comparison |
I went GoWesty rear disc as well and I have to say I love them. I also did the front GoWesty big brakes and installed the bmw bigger brake booster. The combo of the booster and both front and rear discs provide great stopping power. A noticeable improvement over stock. Recently I drove with the parking brake on for a fair distance. There was a bunch of clothing piled over the hand brake lever and I just spaced it. I heated up the rear rotors pretty good. These things are so beefy that there is almost no way these things are going to warp. The parking brake actually holds very well when parked. I am very happy with the overall setup. The main improvement comes from the entirety of the system, booster, big front brakes and rear disc conversion. I'm not sure how much of a difference someone would notice from just adding one component and not the others. _________________ 1991 multivan, FAS 1.9 tdi, Peloquin limited slip
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
OlisGarage Samba Member
Joined: June 01, 2022 Posts: 137 Location: Indianapolis, IN
Posted: Sun Oct 22, 2023 4:50 am Post subject: Re: Rear Disc Brake Comparison |
Epytec is my vote. I know this is not part of the thread, but I did want to share for those interested in a better priced rear disc conversion. This comes out to about half the price of the kits listed. Though you do have to order custom brake lines, but that is not hard to do.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9622397
custom brake lines: https://www.brakematerialsandparts.com
This guy also rebuilds all kinds of fancy brake components. He did some tractor brakes for me and did an exceptional job. He could certainly rebuild a brake booster as well. _________________ 1981 VW Vangagon TDI (in progress)
1984 VW Rabbit Convertible (daily)
2003 VW Jetta Wagon TDI (recovering from a hit and run) |
indianpeaksjoe Samba Member
Posted: Sun Oct 22, 2023 10:09 am Post subject: Re: Rear Disc Brake Comparison |
I have the gowesty big brake kit in the front and gowesty disc rear. My parking brake works great and I have a super steep crazy downhill to get off my Mesa. I love the setup.
Just sharing my experience.
-Joe |
Jake59 Samba Member
Joined: June 13, 2007 Posts: 179 Location: Seattle, WA
Posted: Sun Oct 22, 2023 1:24 pm Post subject: Re: Rear Disc Brake Comparison |
mathieux46
I see you are repurposing the front sway bar, how did that work out for you? _________________ Curent ride: 87 2WD Westy, 2012 Jetta Sportwagon 2.5S
Past Rides: 62 (23 window) Bus, 64 Ghai convertable, 68 single cab, 72 Super Bettle, 78 Bay window Bus, 84 GTI. |
mitch5 Samba Member
Joined: October 17, 2019 Posts: 138 Location: phoenix
Posted: Sun Oct 22, 2023 1:53 pm Post subject: Re: Rear Disc Brake Comparison |
I went with the gowesty rear kit lest year when they had a slight sale during Black Friday. The price $700? Is pretty comparable to what a proper refresh of the rear drums will cost.
Install was super easy, parking brake is great and I just bought an extra set of rotors for future replacement.
It’s worth the money just to not mess with drums. |
mathieux46 Samba Member
Posted: Sun Oct 22, 2023 4:25 pm Post subject: Re: Rear Disc Brake Comparison |
Jake59,
Yes I reused the front sway bar in the back. Much improvement on the handling, combined with T3technique front Koni shocks all around, 255/40r17 rear tire, body roll is gone!!
See details here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=341321 |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2333 Location: Southeast Kentucky
Posted: Sun Oct 22, 2023 5:25 pm Post subject: Re: Rear Disc Brake Comparison |
I went piecemeal putting together a package for my rear disc brake set-up. I've not installed it yet. The project will be something I get to this winter.
On the flip-side, as many of you know, I've pulled a popup camper with my 84 Vanagon without stopping issues. It has performed well under various circumstances. But, I decided to go with disc brakes.
Side note: My piecemeal approach is only slightly cheaper than one of the package deals from the various vendors that have been mentioned in this Thread. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
xstreamcanadian Samba Member
Joined: March 06, 2012 Posts: 6 Location: Abbotsford, BC, Canada
Posted: Sun Mar 24, 2024 7:50 pm Post subject: Re: Rear Disc Brake Comparison |
Franklinstower wrote: |
Epytec ships to us now. Look at their options too.
If you want to test drive my westy with the Epytec brackets and T4 brakes, (same as Burley) you are welcome too. I'm near the north end of lk wa. |
I know this was a while ago but wondering did you also get a good ebrake with this setup, and if so what were the steps for that? |
akciddento Samba Member
Joined: September 30, 2003 Posts: 32 Location: bristol uk
Posted: Mon Mar 25, 2024 3:19 am Post subject: Re: Rear Disc Brake Comparison |
I have several T3s and have driven before and after with all round brake upgrades. I have a 1986 double sliding door van with audi TT front vented discs and golf rear disc conversion and the difference in driving experience and safety is night and day, from before to after. This is especially apparent if there is any load in the van - eg passengers or camping gear.
I also have a fully loaded westfalia with Oettinger style brakes all round and that stops and drives much more like a modern vehicle. My '83 Double Cab is still on stock discs and drums and so I can swap and compare driving experience side by side. Even though the Doka is lighter than the westie and the double slider the other two out perform it easily and the driving experience is much more reassuring.
One thing I would note is to check what parts are used on the upgrade and how easy they are to a) identify b) source ....
the parts in the Oettinger style brakes on the westie are a mix match of audi, BMW? and Mercedes from the 1980's and are proving a pain to decode and replace - I have a full Epytec rear kit (using T4 brake rotors etc) to possibly replace then and the epytec kit looks (so far) to be very good quality... _________________ http://www.akciddento.com
let's drag race the bus ! |
Franklinstower Samba Member
Posted: Mon Mar 25, 2024 10:31 am Post subject: Re: Rear Disc Brake Comparison |
xstreamcanadian wrote: |
Yes, my e-brake is excellent. holds better than my Golf! It uses a Cofle cable from a Mk 2 Jetta with Rear Disc Brakes. I have the part number somewhere, it is also posted on here by me in a couple of different threads related to the Epytec and T4 conversion.
Parking brake cables: Cofle 191609721F _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Mar 26, 2024 7:18 am Post subject: Re: Rear Disc Brake Comparison |
My driver's side backing plate appears to be disintegrating. Might be time to pull the trigger on the GW kit. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
montanasurfer Samba Member
Joined: March 06, 2014 Posts: 319 Location: United States
Posted: Tue Mar 26, 2024 12:22 pm Post subject: Re: Rear Disc Brake Comparison |
If you have bigger brakes up front and in back, does it require getting a BMW Booster to ensure acceptable pedal feel? _________________ 1987 Vanagon GL - Wolfsburg Edition |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Tue Mar 26, 2024 3:35 pm Post subject: Re: Rear Disc Brake Comparison |
montanasurfer wrote: |
If you have bigger brakes up front and in back, does it require getting a BMW Booster to ensure acceptable pedal feel? |
Have not noticed it takes more.
Mercedes ML320 discs up front, 303mm.
Eurovan disc on rear.
Semi-organic brake pads. Ceramic brake pads will require more and do not work well at winter cold temps. _________________ This free advice is worth exactly what you paid for it.
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6367 Location: Honolulu,Hawaii and France
Posted: Tue Mar 26, 2024 5:10 pm Post subject: Re: Rear Disc Brake Comparison |
It's about the piston area really, depends on what you have mounted. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1497 Location: Victoria,B.C.Canada
Posted: Tue Mar 26, 2024 5:37 pm Post subject: Re: Rear Disc Brake Comparison |
Wellington wrote: |
Does anyone know what caliper and rotor SCP is using in their rear disc kit?
Rear vented is a nice addition, but if it is a "car" caliper it is less intriguing.
So far it seems everyone is reporting the T4 Eurovan caliper is up to the task. |
I think they are circa 1990 Audi V8 Quattro with Zimmerman discs. |
MrPolak Samba Member
Joined: June 20, 2004 Posts: 1337 Location: AG ,atnaltA
Posted: Wed Mar 27, 2024 7:33 pm Post subject: Re: Rear Disc Brake Comparison |
I'm about to finally install my GoWesty rear disc brake kit that I bought two years ago. I have the "bigger" GoWesty front brakes, and I went with their "proprietary" rear rotor because I should never have to replace them. Think about it. If you're worried about it, buy two extra rotors now (they're cheap), and rest in peace.
As for rear drum brakes, the trials and tribulations of sub-standard aftermarket parts are well documented. Yes, I know you like your rear drum brakes. Should I show you the brake shoe wear patterns on mine? Talk to me while I hand-adjust the brakes on my splitty .
I will be back to report in a few weeks. If they suck, I will let you know. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3805 Location: VA/TN
Posted: Wed Mar 27, 2024 8:25 pm Post subject: Re: Rear Disc Brake Comparison |
I haven't upgraded my rear brakes and I am very interested in how the e-brake is compared to a healthy drum brake setup. My e-brake is okay overall but the strong the better.
Small Car I believe is working on a wilwood kit. _________________ Brandon
Instagram @joannthevan |
space Samba Member
Posted: Thu Mar 28, 2024 4:59 am Post subject: Re: Rear Disc Brake Comparison |
shagginwagon83 wrote: |
Small Car I believe is working on a wilwood kit. |
fwiw my disc e-brake holds very well, much better than the drum did
Audi calipers
I believe SC uses the same at the moment _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
