gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Mon Dec 04, 2023 4:21 pm Post subject: Brake wiring thru turn signal switch. |
I'm having an issue with no brake lights, and intermittent left signal light. If i wiggle the switch a bit the turn signal will respond. But no brake lights. I, getting power to and from the BL switch. Pretty sure from there it goes to the TS switch, then the brake lights.
How hard is that switch to work on ? Do I drop the column and start there ?
TIA. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Wed Dec 06, 2023 12:53 am Post subject: Re: Brake wiring thru turn signal switch. |
They are quite complicated, full of unique parts. Doug in Chicago restores them
https://www.type356a.com/blinkerswitch.html _________________ Jack Staggs
Actual name |
Slip356 Samba Member
Posted: Wed Dec 06, 2023 6:04 am Post subject: Re: Brake wiring thru turn signal switch. |
Dougs name sounds so familiar but I’ve not used him for turn signal work. What else does he work on? |
Jacks Samba Member
Posted: Wed Dec 06, 2023 7:46 am Post subject: Re: Brake wiring thru turn signal switch. |
Did you look at the link? He lists other services, along with his home page, at the bottom _________________ Jack Staggs
Actual name |
Posted: Wed Dec 06, 2023 9:27 am Post subject: Re: Brake wiring thru turn signal switch. |
Thanks Jacks, he rebuilt two early fuel pumps for me several years back.
At age 82, my memory isn’t what it once was! |
Posted: Wed Dec 06, 2023 10:16 am Post subject: Re: Brake wiring thru turn signal switch. |
I had a very old can of contact cleaner spray. Maybe 15 years old...Pulled the steering wheel off and used what what left in the can.
Unbelievable ! I now have working brake lights and turn signals !
Going for a drive today. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
