whakg1 Samba Member
Joined: May 30, 2014 Posts: 3 Location: orange county,California
Posted: Tue May 05, 2020 12:47 pm Post subject: Need help i turn my motor over but rocker arms wont move can any |
I turn my motor but none of my rocker arm move can any one please tell me why? |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1042 Location: Calgary, AB
Posted: Tue May 05, 2020 2:08 pm Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
Are the push rods installed? |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3846 Location: Georgia
Posted: Tue May 05, 2020 2:20 pm Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
Or your cam is flat or broken.
Or your cam gear is broken. _________________ Volkswagen!
(Compression 8.7:1) |
whakg1 Samba Member
Posted: Tue May 05, 2020 9:35 pm Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
Yes push rods are install all i the motor was running i pulled it out of my car to put in a sand rail . all i did was removed the oil pump because it was a auto stick put fly wheel and clutch bolted the motor on i try to start it thats when i notice none of my rocker arms are moving when i turn the motor over |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22707 Location: NYC/Upstate/ROW
Posted: Wed May 06, 2020 1:21 am Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
Broken cam gear from incorrect oil pump. _________________ .ssS! |
whakg1 Samba Member
Posted: Wed May 06, 2020 3:13 pm Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
Ok thank you
So what can i do if this motor was out of a auto stick car. Do i just change the cam and gear
I already changed put flywheel and clutch set up i put another intake and carbs 009 distributor anything else i have to change? |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Thu May 07, 2020 7:56 am Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
whakg1 wrote: |
Ok thank you
If the cam is broke, your going to have to tear it down and split the case.
you can assess the rest of the engines needs at that point |
Posted: Sat May 09, 2020 9:28 am Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
I doubt what you have already done would break a cam gear. If it was the wrong oil pump it either wouldn't seat or wouldn't contact the cam at all.
Pull the pump out. Look at the cam through the hole. Turn the engine by the pully bolt and see if the cam turns. Go all the way around a full revolution. If there is a chunk of teeth missing the cam will stop turning. No turning cam = no rocker movement.
If the cam turns all the way around but the rockers still don't rock, pull and inspect the rocker shafts and the push rods. It seems like you would hear something if pushrods are bent or broken but reality is strange.
If everything looks good, but you're not getting love it's time to open the engine and see WTF. Maybe the brass gear on the crankshaft is toast or as I said before the cam lobes are worn flat. _________________ Volkswagen!
oprn Samba Member
Joined: November 13, 2016 Posts: 12829 Location: Western Canada
Posted: Sat May 09, 2020 12:31 pm Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
The brass gear doesn't drive the cam, it drives the distributor and fuel pump. |
Posted: Sat May 09, 2020 4:34 pm Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
Oops. Sorry. Wrong Gear. _________________ Volkswagen!
Stocknazi Samba Member
Posted: Sun Dec 10, 2023 10:40 am Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
I figured I would ask this here instead of starting a new thread:
I was messing around with a September/55 36hp beetle engine that would not rotate, but had just a slight movement. Soaked it with 50/50 kerosene and ATF and managed to get it to spin over fine with not too much effort. Pistons were just a little stuck from sitting. I rocked it back and forth until I could spin it by hand with the flywheel. Definitely didn't force anything.
Anyway, I had the rocker covers off and was watching the rockers move when I was rotating the engine, and I noticed that some were not moving. One cylinder
neither intake/exhaust would move, and one cylinder the intake is not moving. Other two cylinders move fine. All the valves that did not move were partially open, and backing out the adjustment screws allows the valves to close. A couple actually bottomed out on the rocker arm so they still may be partially open.
What are the reasons why they would not be moving? Bent push rods?
Lots of end play, and you can see most of the valves move side/side with a screwdriver, so I know this engine will need to be rebuilt; just wanted an idea what could be wrong before storing it away for later. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson
Posted: Sun Dec 10, 2023 10:46 am Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
With lots of endplay, it needs a rebuild anyway.
Pull it apart and let us know what you find. _________________ Volkswagen!
Posted: Sun Dec 10, 2023 2:57 pm Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
jeffrey8164 wrote: |
Pull it apart and let us know what you find. |
I'm not pulling it apart right now, just wanted to know what all could cause them not to be moving. The only guess I have is bent push rods.
Can't be too many other things could it? _________________ WANTED:
Thomas Jefferson |
oprn Samba Member
Posted: Mon Dec 11, 2023 11:02 am Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
If the cam is broken in half and only the front half is turning... not that likely though. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Mon Dec 11, 2023 1:47 pm Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
Rockers could be simply seized on the shafts. It’s all academic , as you will find a bunch of other bad boys partying in that engine , too. _________________ .ssS! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34086 Location: Conejo Valley, CA
Posted: Mon Dec 11, 2023 1:50 pm Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
Or they are stuck open and so you won't see movement. Pushrods would probably fall out of the rocker tips, though. |
Dusty1 Samba Member
Posted: Sun Dec 17, 2023 5:36 pm Post subject: Re: Need help i turn my motor over but rocker arms wont move can any |
Me: "Hey, Doc! Hey, Doc! It hurts when I bend my arm like this!"
Doc: "Don't bend your arm like that!"
Rusty stuck motor: It was rusty, stuck. Even if you get it to turn over the rings are stuck in their grooves, the cylinders and combustion chambers are cruddy, and hey, bonus! The rusty valve stems are stuck in their guides.
Doesn't matter that it turns over. That only makes it easier to get apart. it won't be right until all the rusty parts are rebuilt.
