DesertG Samba Member
Posted: Sun Dec 31, 2023 11:15 am Post subject: Wolfsburg West Body Molding and Clips Loose |
Hello Guys, I am installing new molding on a Beetle today. The clips are very loose and don't hold the molding tight to the body. The result, the molding slides around on the body after install, easy. I am using new rubber boots as well.
I have slid the clips into the molding both orientations.
What am I missing.
Thank you!
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113898111BSL _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
viiking Samba Member
Joined: May 10, 2013 Posts: 2670 Location: Sydney Australia
Posted: Mon Jan 01, 2024 8:03 pm Post subject: Re: Wolfsburg West Body Molding and Clips Loose |
Are you replacing ones that were previously fitting?
Or is this a new installation of trim that wasn’t there before?
If the latter, the trim hole size may have been altered. Take some twist drills and manually fit the stem of the drill into the holes to see what hole size you gave and then report back.
It would help if you advised what year model you have. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Tue Jan 02, 2024 8:04 am Post subject: Re: Wolfsburg West Body Molding and Clips Loose |
Thank you. Replacing existing molding. The looseness is not from the hole in the car body.
The clips that slide into the chrome molding are loose. Basically, so lose they slide out. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
Posted: Tue Jan 02, 2024 1:53 pm Post subject: Re: Wolfsburg West Body Molding and Clips Loose |
Ok. Understand.
On other websites there are two sets of clips. Pre 67 and post 67.
Did you get sent the wrong year range clips? _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
brass gears Samba Member
Joined: October 21, 2013 Posts: 72 Location: Calgary,AB
Posted: Sat Jan 06, 2024 6:12 pm Post subject: Re: Wolfsburg West Body Molding and Clips Loose |
I seem to recall having this same issue. I think the issue was with the replacement moulding profile. If you still have your original moulding, compare the profiles. I purchased the Wolfsburg West stainless kit. _________________ ‘70 transporter
‘ 64 beetle |
Posted: Sat Jan 06, 2024 6:36 pm Post subject: Re: Wolfsburg West Body Molding and Clips Loose |
Here’s a pic. It’s like they didn’t get the right bend on it.
I think my solution was to either bend the clips ( I think I broke a clip trying that) or I may have gently made some bends on the moulding where the clips needed to stay. _________________ ‘70 transporter
‘ 64 beetle |
