Michaelfind Samba Member
Posted: Thu Jan 25, 2024 10:46 am Post subject: Do's and don'ts with original paint? |
What is the best way to wash, clean, refresh the exterior paint on my 67 bus? I'm thinking it is the original paint except for maybe some touch up spots my father may have had done in the 70s. What should be done or never done with original paint?
Thanks in advance to all the experts here. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Thu Jan 25, 2024 12:57 pm Post subject: Re: Do's and don'ts with original paint? |
Thank you |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76963 Location: Sneaking up behind you
Posted: Thu Jan 25, 2024 1:18 pm Post subject: Re: Do's and don'ts with original paint? |
Moved. _________________ Glenn
Member #1009
#BlueSquare |
jinx758 Samba Member
Posted: Mon Feb 12, 2024 4:56 pm Post subject: Re: Do's and don'ts with original paint? |
No one responded so I'll give it a go.
I'm certainly no expert :
Do not use soap for dishes or clothes, get one specific for autos. It mite seem expensive but only a tiny amount is needed. I had a large bottle last several years.
I got a bucket with a raised grate in the bottom & a fuzzy wash mitt. I dried it with a genuine chamois found at a barn sale. Ideally before a good wax is used it should be evaluated for oxidation.
My L65K Ravenna Green '74 had very light oxidation so I used a Mirror Glaze as the rubbing compound was too aggressive.
I used a cheapy buffer from WallyWorld as I was using too many cans of Elbow Grease.
I didn't have the patience for a Clay Bar but some people swear by them.
Some types of pains benefit from a rejuvenator. I think these have special conditioners that are very beneficial for single stage paint jobs.
All these are based on a FULLY cured paint job.
I have seen the horrors of not waiting.
Trying not to muddy the waters ...
stay safe
jinx
Not sure if this helps any, just my limited experiences. _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
VALVES (cold)
POINTS
TIMING
CARB (fully warmed engine)
SCRAPE ALL GROUNDS
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Wed Feb 14, 2024 11:44 am Post subject: Re: Do's and don'ts with original paint? |
I've seen good results from wet sanding original paint with 2000 grit and then buffing. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
74 Thing Samba Member
Posted: Wed Feb 14, 2024 12:43 pm Post subject: Re: Do's and don'ts with original paint? |
Post some photos |
Posted: Thu Feb 15, 2024 7:11 am Post subject: Re: Do's and don'ts with original paint? |
Thanks for the suggestions. I need to get it out of the storage building to get good pictures. Maybe I will have time and good weather for that this weekend. |
Posted: Thu Feb 22, 2024 7:27 am Post subject: Re: Do's and don'ts with original paint? |
Sorry no photos yet. I had great weather but too many family events scheduled to get anything else done. Thanks for your patience. |
Posted: Wed Feb 28, 2024 2:40 pm Post subject: Re: Do's and don'ts with original paint? |
I finally got the bus out and got some pictures. Thanks again for any suggestions on reviving old paint.
