s.e.charles Samba Member
Posted: Mon Feb 19, 2024 4:20 pm Post subject: Original 6v battery (photo wanted) |
i didn't do well searching. forum/ gallery/ technical
anyone have a picture of an original 6v battery installed?
i'd like as much detail as possible, (cables/ brackets/ labels) but can
extrapolate if needed.
thanx |
finster Samba Member
Joined: May 26, 2012 Posts: 7966 Location: north o' the border
Posted: Tue Feb 20, 2024 5:17 am Post subject: Re: Original 6v battery (photo wanted) |
for brand labels there's bosch or varta
old moulded-in style
here's a pic of the battery in place where the cover is held down with spring clips that hook into tabs on the floor. 1951
pre 48 the cover looked like this and the clips were mounted front and back
_________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Tue Feb 20, 2024 5:43 am Post subject: Re: Original 6v battery (photo wanted) |
great; thank you. |
Posted: Tue Feb 20, 2024 8:37 am Post subject: Re: Original 6v battery (photo wanted) |
here's another photo, the +ve cable isn't fitted but you can see the grommet where it goes through to the starter at the back of the floorpan. also hoe the rubber mat is shaped around the battery
my3bugs Samba Member
Posted: Tue Feb 20, 2024 9:40 am Post subject: Re: Original 6v battery (photo wanted) |
all these pictures are for a 52 and earlier , then it went to a different size battery and used a metal strap instead of springs to hold it down .... it depends on the year your looking or working on ???? |
Posted: Tue Feb 20, 2024 11:53 am Post subject: Re: Original 6v battery (photo wanted) |
i really like the label on that one = fist grabbing volts!
if i'm not overstaying my welcome on this topic . . . .
any chance of (1) dimension for this battery or the size of the tray it sits on? i can massage the other dimensions to look right.
is there a top view of just the battery for cell cap & bus bar (?) layout i could beg?
and, since i'm all in on this one - a 53 to 57 battery just for variety?
these will go in the garage diorama being planned.
thanks for all & any further help.
sid |
Posted: Tue Feb 20, 2024 11:58 am Post subject: Re: Original 6v battery (photo wanted) |
footnote . . . circa 1969. my '58 was a complete surf wagon. i blacked out the rear side windows and removed the seat cushions. then i found a metal covered kitchen table one day when i was toodling down a dirt road looking for a spot to whiz.
half the table, it slid apart to accommodate a center leaf, fir perfectly across the back where the seat cushion was. so now i had the ultimate "change into my wetsuit in the parking lot" vehicle.
except the first time i sat on it the battery shorted out!
the metal wrapped around far enough to touch the "bad parts". . . |
Posted: Tue Feb 20, 2024 12:31 pm Post subject: Re: Original 6v battery (photo wanted) |
this ad has good views https://www.thesamba.com/vw/classifieds/detail.php?id=2629436
Product information "Battery 6V 66Ah 265A"
Car battery, 6 volts, 66 Ah.
Length: 185 mm.
Width: 165 mm.
Height: 165 mm.
oval batteries would be the same but the cover/battery was held down by a strap _________________ "we're here on Earth to fart around" kurt vonnegut
Posted: Tue Feb 20, 2024 12:50 pm Post subject: Re: Original 6v battery (photo wanted) |
that's a perfect picture(s); thank you.
the one place i never thought to look was in the 'classifieds' section.
next time i'll go there, too. |
52 split Samba Member
Joined: December 19, 2007 Posts: 150 Location: the best island in the world, vancouver island
Posted: Sat Feb 24, 2024 7:13 pm Post subject: Re: Original 6v battery (photo wanted) |
Hello finster how does the metal strap hold the positive cable. Is the end crimped around the cable. Up to what year was the strap used.have a closer photo . |
RockStock Samba Member
Joined: November 26, 2004 Posts: 3929 Location: England
Posted: Sun Feb 25, 2024 1:31 am Post subject: Re: Original 6v battery (photo wanted) |
Worth saving those NOS Wilhelm Hagen 6v Battery pictures
Nice!!
_________________ -StockRocks- |
Posted: Sun Feb 25, 2024 2:24 am Post subject: Re: Original 6v battery (photo wanted) |
if "someone" was intent on building a 1:12 scale model, that would certainly
be a perfect series reference photos . . .
thanks! |
Posted: Sun Feb 25, 2024 4:49 am Post subject: Re: Original 6v battery (photo wanted) |
52 split wrote: |
short answer - I dunno!
but looking around there is this short thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=574504&highlight=battery+cable+strap
plus looking at photos and battery covers it seems that the cable clamp was used with the battery cover that had a cut-out for the +ve cable at the rear. possibly late split early oval time. maybe others more knowledgeable can chip in. _________________ "we're here on Earth to fart around" kurt vonnegut
