tdskip Samba Member
Posted: Thu Feb 22, 2024 7:04 am Post subject: Quick CIS air sensor plate sanity check question on 1984 |
Hi folks - working on fuel system trouble shooting on a stock 1984 CIS cabriolet that dies when power is applied.
Cold start and idle are fine. Fixed some vacuum leaks but have a quick sanity check question as a CIS newbie.
I understand that the vacuum from the engine will lift the air sensor plate under the air intake boot, the plate rising in the cone then lifts the fuel metering pin/plunger in the fuel distributor.
As a quick sanity check last night with the engine running I manual lifted the air flow plate (having previously removed the cover and made sure everything was clean) and absolutely nothing changed regardless of how much I opened or closed the plate.
I would have though that the engine rpm would have quickly responded to the plate moving - that it didn’t makes me think that there is something very wrong in how the plate and fuel metering pin are connected or adjusted.
Yes/no/maybe?
Thanks for any advice or coaching. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Feb 23, 2024 8:21 am Post subject: Re: Quick CIS air sensor plate sanity check question on 1984 |
Most likely the plunger in the fuel distributor block is stuck. It may need some cleaning to un-stick it. |
tdskip Samba Member
Posted: Fri Feb 23, 2024 12:15 pm Post subject: Re: Quick CIS air sensor plate sanity check question on 1984 |
ps2375 wrote: |
Thanks for the reply, appreciate it.
I will take the fuel distributor off and see what is up, almost wonder if it is missing or the arm from the air plate is bent. |
Johngus Samba Member
Posted: Thu Mar 07, 2024 4:58 pm Post subject: Re: Quick CIS air sensor plate sanity check question on 1984 |
Check your relays. One of my relays was bad on my 84 gli, I changed it and it idled much better!
Posted: Thu Mar 07, 2024 6:03 pm Post subject: Re: Quick CIS air sensor plate sanity check question on 1984 |
Check these relays.
