Centrifugal air cleaner
BFB
BFB is offline
PostPosted: Sun Feb 25, 2024 11:02 am    Post subject: Centrifugal air cleaner Reply with quote
Anyone have experience running the centrifugal / implement type air cleaners?
Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1
jimmyhoffa
jimmyhoffa is offline
PostPosted: Sun Feb 25, 2024 11:26 am    Post subject: Re: Centrifugal air cleaner Reply with quote
Yep. I ran a UMP cannister for a while which is just a sexy aluminum replica of a production filter like a Donaldson or similar. It takes air filter maintenance from a monthly or every-ride nuisance, to forgetting you even have an air filter. I just silted my good engine thinking I could get by without one, and now I'm going back to a UMP centrifugal filter. It's the only real answer I've found that makes the big problems disappear.
The class 12 Baja 1000 car I have supported runs one, as do about 80% of the competitive cars in the desert. I go to Mexico 4-5 times a year on business, and all the homemade off road contraptions have some drum filter taken off some heavy equipment at the scrapper. Lots of VW stuff down there too, even in north central MX! (Not Baja)
1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
