mccandmore Samba Member
Joined: July 19, 2017 Posts: 15 Location: St. Louis, MO
Laird.Ostien Samba Member
Joined: January 21, 2024 Posts: 124 Location: maryland
Posted: Mon Mar 25, 2024 9:32 am Post subject: Re: My new Bus |
Thank you. From what I’ve gathered so fat synthetic oil is a go for all trannys but would be a waste for me in my engine considering it’s a stock engine and doesn’t have an oil filter. I will buy valvoline now tho. She’s dropping a bit and it’s pretty black, also I figure getting some of the basic maintenance jobs done now while I’m on spring break and acquiring some of the tools I’ll need wouldn’t be a bad idea. |
dodger tom Samba Member
Joined: March 25, 2013 Posts: 1272 Location: Central Coast, CA, but we're all still Ukrainian
Posted: Mon Mar 25, 2024 9:50 am Post subject: Re: My new Bus |
two options: 1) buy four 2” hose clamps at your local hardware store.
2) go whole hog and buy stainless steel aba hose clamps from steve at the ultimate garage.
https://www.ultimategarage.com/shop/part.php?cPath=309_31_346&products_id=1762
the first option will be just fine for these.
NOT for the new fuel hoses you’ll be installing soon.
we want to avoid that fire you were worrying about, right? _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Mon Mar 25, 2024 9:57 am Post subject: Re: My new Bus |
Laird.Ostien wrote: |
Yes, I used Swepco 201 synthetic 80W90 in the trans, at the recommendation of my trans rebuilder.
VR1, either 30 wt or 20W-50 is also what I am running, based on rebuilder recommendations.
Use the Muir "Phase I" toolkit as a guide to what you need, plus maybe a few Phase II tools depending on what work you plan to do. _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
Posted: Mon Mar 25, 2024 11:33 am Post subject: Re: My new Bus |
KTPhil wrote: |
Use the Muir "Phase I" toolkit as a guide to what you need, plus maybe a few Phase II tools depending on what work you plan to do. |
That’s Exaclty what I was doing and was sitting down with my dad to see what we already had. |
Posted: Mon Mar 25, 2024 11:46 am Post subject: Re: My new Bus |
hard to tell from the photo of your engine, but it appears there is a space between the engine tin and body.
i’m not sure if your style engine is supposed to have a seal in that space, but i expect it is. do some research, and find out.
if so, is the seal there, or is it missing? _________________ 1978 Champaign Edition 2 Westfalia
Posted: Mon Mar 25, 2024 1:00 pm Post subject: Re: My new Bus |
I noticed some gunk and what seemed like oil in the engine bay, immediately caught my attention. I’ll upload a picture, any ideas on this or if it’s a big deal?
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12729 Location: on a bike ride somewhere
Posted: Mon Mar 25, 2024 1:10 pm Post subject: Re: My new Bus |
The engine doesn't have a filter. All oil will look dark quickly; don't stress.
The oil on the right is likely from someone spilling during filling.
Left side could be a leaky pressure switch. (Deal with the blue wire that's about to get roasted on the metal pipe.) A closer picture will tell.
Your engine will leak less if you route the breather hose to the correct port on the air cleaner.
www.airschooled.com |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1270 Location: Bethlehem, PA
Posted: Mon Mar 25, 2024 1:29 pm Post subject: Re: My new Bus |
dodger tom wrote: |
jjvincent wrote: |
dodger tom wrote: |
laird’s gotta be cracking up with all these old guys riffing on interweb stuff he’s probably never heard of. |
If we are talking about computers, then we are not old. |
sorry, jj, if you’re talking about party lines, you’re old, certainly compared to laird.
did you watch first run black-and-white films at the movies?
insert smiley face here.
and, xevin, i ran my thesis data through the old ibm on punch cards. but, i typed it on a sperry word-processing program. |
I might be old but I get trusted to work on these. I try to keep up with the newest trends. For example, the Audi still has a clutch in it to get it to move, but it's still paddleshift (uses an air compressor) and has a button on the center console for reverse. The Porsche has the easy to use PDK. At least the Porsche has HVAC and that's in it.
ce for racing. |
KTPhil Samba Member
Posted: Mon Mar 25, 2024 1:44 pm Post subject: Re: My new Bus |
Run it for even a few minutes without the heater hoses between the fan shroud and the heat exchangers, and oil residue will be the LEAST of your troubles!
Agreed; left side is probably oil pressure switch leaking, right side maybe from the breather area. _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51172 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Mar 25, 2024 1:50 pm Post subject: Re: My new Bus |
Robbie already covered most of the leak story, clean it up and then inspect afer the next few drives to pinpoint the source, it's hard to narrow down once it's spread and spattered everywhere like that. Put a bag over the distributor so you don't get it wet, and do the job away from where everyone walks or they'll track the smell into the house and make you extra popular!, it also kills grass so avoid the lawn.
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Mar 25, 2024 1:53 pm Post subject: Re: My new Bus |
KTPhil wrote: |
Agreed; left side is probably oil pressure switch leaking, right side maybe from the breather area. |
The hose goes from the pipes in the ground to the pipe coming out of engine tin right? And the pipe coming out of the filter on the right. |
KTPhil Samba Member
Posted: Mon Mar 25, 2024 2:02 pm Post subject: Re: My new Bus |
Ignore most of the annotations, but this pic shows the large silver hose routing. _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
Posted: Mon Mar 25, 2024 2:05 pm Post subject: Re: My new Bus |
KTPhil wrote: |
Ignore most of the annotations, but this pic shows the large silver hose routing. |
Is it 3 separate hoses or does it go through all of them? |
Posted: Mon Mar 25, 2024 2:15 pm Post subject: Re: My new Bus |
The third hose that goes sideways to the aircleaner is for preheat, the two more vertical ones go to the cabin heat exchangers.
You don't have the "funny round thing" on your aircleaner, Phil's is from a 72+ Ghia. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Eriebugger Samba Member
Posted: Tue Mar 26, 2024 5:42 am Post subject: Re: My new Bus |
As others have said, looks like a good solid bus. Enjoy and learn along the way!
Just thought I'd throw my 2 cents in here. What's with all the hate about the painted V on the front. No, it's not factory and emulates split window buses but it looks pretty good to me. I've seen other attempts that are bad but the proportions look good. I only wish Volkswagen styling engineers would have carried over some semblance of the icon V on the bays. Wouldn't have taken much to incorporate it into the stamping. The flat nose on the bays isn't one of it's attributes. (Proud owner of a '74). The ones without at least a VW logo are just plain ugly. If you like it, keep it. If not, easy enough to paint over when the time comes. _________________ 1974 Bus
1967 Beetle
1973 Super beetle(project)
1974 Super beetle(project) |
KTPhil Samba Member
Posted: Tue Mar 26, 2024 12:00 pm Post subject: Re: My new Bus |
SAFETY FIRST.
All gas hoses and soft brake lines.
Check tires (including dates codes on sidewall).
Flush brake fluid.
RELIABILITY NEXT.
Review underneath for leaks and loose nuts and wires, and any corroded rubber parts. Note and take pics of any rust you find.
Check/top up transaxle. _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
KTPhil Samba Member
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1966 Location: Manitowoc, WI
