Itsa72 Samba Member
Joined: November 10, 2023 Posts: 8 Location: Des Moines, IA
Posted: Wed Mar 13, 2024 4:49 pm Post subject: Crusty valves/head |
So I am cleaning up and replacing the gaskets on my 1600 DP engine and I found this cylinder valve all crusty like this. The other 3 are just dirty and oily. What could have caused this type of grime. Do I have to dig deeper into the engine. Car has not run for years and I bought it not running. Any advice would be appreciated!
_________________ Owning a classic bug will make you a millionaire….if you are a billionaire 💰
1972 Super Beetle
2019 Jetta R-Line |
Zundfolge1432 Samba Member
Posted: Wed Mar 13, 2024 7:15 pm Post subject: Re: Crusty valves/head |
Water caused that. I’d clean it up then remove the valves and clean the exhaust ports looking for cracks. Valves out look at the seats are they rusted? Cracks between seats are ok.
https://www.thesamba.com/vw/forum/viewtopic.php?t=789939 |
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 573 Location: South of Raleigh
Posted: Sat Mar 16, 2024 6:24 am Post subject: Re: Crusty valves/head |
What does the cylinder look like? |
Rome Samba Member
Joined: June 02, 2004 Posts: 9657 Location: Pearl River, NY
Posted: Sat Mar 16, 2024 12:18 pm Post subject: Re: Crusty valves/head |
I agree. First clean the head in solvent. I use a 5-gal utility bucket from Home Depot/Lowe's and put in 2 gallons of diesel fuel or kerosene as the solvent. Let the head sit in the solvent overnight to help soften the grease. After you work the grease off with a stiff parts cleaning brush, use some brass bristle brushes for a drill to work the "calcified" crap off the combustion chamber. A set of these or similar- https://www.amazon.com/Hiqalty-Crimped-4-Inch-Clea...8336141e14
At that point you can inspect the seats and surrounding areas per Zund's response. If there are no cracks, you'll likely need to have all valve seats reground to work through any pitting from the water corrosion on steel. Then replace the exhaust valves. Chase the spark plug holes with a suitable thread tool. |
Itsa72 Samba Member
Posted: Sun Mar 17, 2024 3:03 pm Post subject: Re: Crusty valves/head |
The cylinder doesn’t seem to be as crusty as the head. I a, wondering since I am cleaning up the heads if I should also replace the cylinder rings. Not sure if that is part of the problem also. _________________ Owning a classic bug will make you a millionaire….if you are a billionaire 💰
1972 Super Beetle
2019 Jetta R-Line |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76977 Location: Sneaking up behind you
Posted: Sun Mar 17, 2024 3:06 pm Post subject: Re: Crusty valves/head |
Dished pistons, looks like the engine came from a Bus. _________________ Glenn
Member #1009
#BlueSquare |
Itsa72 Samba Member
Posted: Sun Mar 17, 2024 3:20 pm Post subject: Re: Crusty valves/head |
Glenn wrote: |
Dished pistons, looks like the engine came from a Bus. |
Came out of a 72 Super Beetle _________________ Owning a classic bug will make you a millionaire….if you are a billionaire 💰
1972 Super Beetle
2019 Jetta R-Line |
Itsa72 Samba Member
Posted: Sun Mar 17, 2024 3:22 pm Post subject: Re: Crusty valves/head |
johnnyvw164 wrote: |
1972 Super Beetle
2019 Jetta R-Line |
