Cavilry6 Samba Member
Joined: February 07, 2016 Posts: 142 Location: Santa Cruz, ca
Posted: Fri Mar 22, 2024 3:21 pm Post subject: Re: Time for a rebuild (?) How to proceed? |
timvw7476 wrote: |
From potential rebuild to repairing a chafed oil pressure sender wire.
Another reason VWs are amusing to own & operate.
This is the second time in a row! I just went through the engine cutting out under load and was sure something catastrophic happened. I parked it for months then one evening when hooking up the battery tender I looked over and noticed that the plug had blown out of the carb! Found it in the engine bay, popped it in place, and drove off without incident. _________________ 1968 Westy Tin-Top
[url=http://www.vw-mplate.com/mplate2-32802.png]Click to view image[/URL] |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12729 Location: on a bike ride somewhere
Posted: Wed Mar 27, 2024 10:30 am Post subject: Re: Time for a rebuild (?) How to proceed? |
Cavilry6 wrote: |
Just to close the loop on this one, I finally got the pressure gauge and it's holding at a nice, steady 50 psi at idle! Phew! |
Yeehaw! How much pressure does it have at hot idle after a freeway flog?
VW spec'd the oil pressure to be somewhat lower than the standard 10psi per 1,000 rule of thumb. Betley specs at 2,500 RPM and engine oil of 160°f, (lazy town driving,) are 42psi when new, and 28psi when worn out.
From experience, an old engine that makes 50psi cold can still drop below 5psi at hot idle and be perfectly healthy.
www.airschooled.com |
