BFB Samba Member
Posted: Thu Mar 21, 2024 5:36 pm Post subject: Crankshaft Timing Gear Retaining Clip |
How many of ya’ll use a different style clip than the factory vw one? Ive seen Bugguy has some on the classifieds.
Old German guy gave me one of the tapered cones to instal the C clips which makes installation a breeze but removing the factory ones can be a p.i.t.a. some days _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76976 Location: Sneaking up behind you
Posted: Thu Mar 21, 2024 5:40 pm Post subject: Re: Crankshaft Timing Gear Retaining Clip |
I use the factory part... never a problem.
_________________ Glenn
Member #1009
#BlueSquare |
RWK Samba Member
Posted: Fri Mar 22, 2024 5:12 am Post subject: Re: Crankshaft Timing Gear Retaining Clip |
knipex 4510170, these work well for R&R there are other brands with similar pliers. I have the Proto one. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Don Jones Samba Member
Joined: April 09, 2020 Posts: 200 Location: Makaha, Hawaii
Posted: Sat Mar 23, 2024 11:40 am Post subject: Re: Crankshaft Timing Gear Retaining Clip |
Buy bugguy1967 (Tabari)'s retaining clip and never worry about the old stretched out clip you have waiting to fail. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9788 Location: Oregon
Posted: Sat Mar 23, 2024 5:49 pm Post subject: Re: Crankshaft Timing Gear Retaining Clip |
Don Jones wrote: |
X2. I have one in my 1679 I just finished. Installed like a treat!
For the old VW issue snap rings I use the Proto tool to remove and install the ring. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Glenn Mr. 010
Posted: Sat Mar 23, 2024 6:32 pm Post subject: Re: Crankshaft Timing Gear Retaining Clip |
67rustavenger wrote: |
Don Jones wrote: |
For the old VW issue snap rings I use the Proto tool to remove and install the ring. |
Here's the ad it anyone is interested.
https://www.thesamba.com/vw/classifieds/detail.php?id=2385452 _________________ Glenn
Member #1009
#BlueSquare |
woodsbuggy Samba Member
Joined: December 15, 2007 Posts: 210 Location: NE Indiana
Posted: Sat Mar 23, 2024 6:34 pm Post subject: Re: Crankshaft Timing Gear Retaining Clip |
The snaprings do work very nice on factory German cranks with stock cam gears but I have had a few aftermarket stroker cranks with CB straight cut gears and the snaprings would not fit them, they are slightly thicker than the factory clips.
Kenric _________________ The empty can rattles the most! |
txoval Samba Member
Joined: January 23, 2004 Posts: 3557 Location: The Woodlands, TX
Posted: Sun Mar 24, 2024 5:59 am Post subject: Re: Crankshaft Timing Gear Retaining Clip |
Yes you have to flat sand it a bit if using CB straight cuts |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4345 Location: Los Angeles, CA 90016
Posted: Mon Mar 25, 2024 8:39 pm Post subject: Re: Crankshaft Timing Gear Retaining Clip |
Btw, I have the legit snap-on expanders, if anyone is interested in using the best tool for factory rings. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Don Jones wrote: |
thanks. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
