fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Tue Mar 26, 2024 1:42 pm Post subject: Split Case Transaxle To Tunnel Transaxle - Any Parts Reuseable? |
I just dismantled my '59 split case transaxle. This transaxle was a spare and not in use other than as an engine stand. It is not the numbers matching transaxle to my '59 bug unfortunately.
First gear on the mainshaft looks rough and has some nicks, but the axles, differential assembly and the pinion gear stack look pretty good, at least to my untrained eyes. Synchros look nice and also no chips/missing teeth on the gears themselves that I can see.
Will any external parts off this split case unit fit the '61 tunnel trans currently in my '59 bug? I'm wondering in particular if the axles will swap. If not I'm not going to keep anything other than the housing which will become part of a test engine stand
Ted |
EVfun Samba Member
Posted: Tue Mar 26, 2024 2:29 pm Post subject: Re: Split Case Transaxle To Tunnel Transaxle - Any Parts Reuseable? |
Axle tubes and axles can be used on later swingaxles. I hear they are lighter than later short axles. _________________
Wildthings wrote: |
Posted: Tue Mar 26, 2024 3:11 pm Post subject: Re: Split Case Transaxle To Tunnel Transaxle - Any Parts Reuseable? |
Nice, great to hear this. Thank you EVFun. I'll be sure and hold onto the axles and axle tubes.
Guess its time to take apart that ring gear and diff so I can harvest these.
Ted |
esde Samba Member
Joined: October 20, 2007 Posts: 5971 Location: central rust belt
Posted: Tue Mar 26, 2024 4:10 pm Post subject: Re: Split Case Transaxle To Tunnel Transaxle - Any Parts Reuseable? |
you can use the axles, axle tubes, and fulcrums, but thats it. PM me if you would sell the ring and pinion _________________ modok wrote:
Bruce Samba Member
Joined: May 16, 2003 Posts: 17296 Location: Left coast, Canada
Posted: Wed Mar 27, 2024 1:48 am Post subject: Re: Split Case Transaxle To Tunnel Transaxle - Any Parts Reuseable? |
Side gears and spider gears are the same. Axles are identical to 66. _________________
Posted: Wed Mar 27, 2024 9:01 am Post subject: Re: Split Case Transaxle To Tunnel Transaxle - Any Parts Reuseable? |
esde wrote: |
you can use the axles, axle tubes, and fulcrums, but thats it. PM me if you would sell the ring and pinion |
PM sent, thanks esde
Ted |
Posted: Wed Mar 27, 2024 9:02 am Post subject: Re: Split Case Transaxle To Tunnel Transaxle - Any Parts Reuseable? |
Bruce wrote: |
Side gears and spider gears are the same. Axles are identical to 66. |
Interesting I didn't know that about the side gears and spider gears. |
nsracing Samba Member
Posted: Sun Mar 31, 2024 6:38 pm Post subject: Re: Split Case Transaxle To Tunnel Transaxle - Any Parts Reuseable? |
Save them nuts and bolts -
The rest can go to the bonfire. |
