AllRad Samba Member
Joined: December 04, 2016 Posts: 64 Location: Pacific Northwest
Posted: Tue Mar 26, 2024 4:44 pm Post subject: 1991 Syncro Engine Drop |
Hello Samba,
The time has come for me to step things up. I picked up a used 2.1 WBX off Craigslist with the plan to swap it in for my 2.2, which needs new cylinder heads. My hope is that the replacement will work well enough to buy me time to install the new cylinder heads, a new Mansi oil pump and Mansi injectors. I haven't decided yet, but maybe Mansi 1:35 rockers. I'm too cheap to go full EFI (maybe later).
Up to this point my wrenching challenges have included engine and transmission oil changes, thermostat replacement and the odd cleaning/replacement of other simple items. So, I'm paddling into surf that's way heavier than I have a right to -- but how better to learn?
I will surely post some stupid questions. Patience for the ignorant please.
Here's the 2.2 prior to removal
Here it is in my garage
The engine suspension gantry I made to hold & lower the engine onto a Harbor Freight moving cart. I used a block and tackle and some of that amazing synthetic rope to suspend the thing. My hands were full; so, no action photos.
The engine is out
Is it just me, or is the inside of the bell housing a little gunkier than it should be? Is this an indication that the main seal is less than perfect?
I really had to wrestle with the engine to get it separated from the transmission, which I loosened and lowered using a floor jack. The studs were binding in spite of trying several different angles on both the transmission and engine, for which I could alter the height using the block and tackle. Anyways, the right stud-hole shows some signs of wear. I think its superficial, but opinions would be welcome.
That's all for now. Next up. Install the new to me 2.1 WBX. If everything goes to plan, it will be very interesting to see how they compare.
Cheers. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6368 Location: Honolulu,Hawaii and France
Posted: Tue Mar 26, 2024 5:06 pm Post subject: Re: 1991 Syncro Engine Drop |
Careful to not get your leash entangled on the boat anchor while duck diving!
I would replace the input shaft seal preventively.
Looks like your pilot bearing in the crank was shot too!
Make sure you have one in it if your donor came from an automatic van. You should replace it anyway even on the donor/ _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Tue Mar 26, 2024 7:47 pm Post subject: Re: 1991 Syncro Engine Drop |
Well for a first time pulling an engine it looks like you did just fine. Sometimes it does take a little wrastlin to separate an engine and trans. Good job. Nice picking gantry. I wish my my engine bay was as clean as yours, I live on a gravel road. |
AllRad Samba Member
Posted: Wed Mar 27, 2024 3:18 pm Post subject: Re: 1991 Syncro Engine Drop |
The plan is to swap in the spare 2.1 WBX that's sitting in the garage, then add some improvements to the 2.2 (which I just removed -- it has the orange plenum), then swap the orange monster back into the van as the "permanent" solution.
I need to bring some parts from the 2.2 over to the 2.1, like the clutch. However, I was having some issues with grinding when shifting into 2nd -- when cold.
I also experienced some clutch chattering -- only when hot, like after a 30+ mile trip. The longer the trip, the more the chatter, when starting from a dead stop. Neither of these issues seemed like show stoppers, but worrisome.
I was hoping that the old clutch would work "good enough" as part of the temporary 2.1 patch. I would get a new clutch kit for the 2.2 when the time comes to swap it back into the van.
Can someone help me, because i don't know what I'm looking at. Does this clutch look like it's toast?
Sodo Samba Member
Joined: July 06, 2007 Posts: 9630 Location: Western WA
Posted: Wed Mar 27, 2024 3:43 pm Post subject: Re: 1991 Syncro Engine Drop |
I see a recent clutch in your pics.
Can still see the machining marks on the flywheel.
Are all "the fingers" on the pressure-plate at similar height?
It looks like it was assembled without grease on the pilot bearing, which could cause some of your shifting problems.
I'd polish the end of the mainshaft with some 800-grit paper
And replace (and grease) that needle pilot bearing.
Not too much grease!
You don't want it throwing grease out onto the clutch.
There are ideal greases for the needle bearing but I don't know what they are.
A "disc brake" wheel bearing grease that doesn't get runny when hot might be the best type.
Maybe someone else can guide you better. _________________
....KTMs, GasGas, SPOT mtb |
mathieux46 Samba Member
Posted: Wed Mar 27, 2024 3:50 pm Post subject: Re: 1991 Syncro Engine Drop |
Sodo,
I’m in the same process now, was wondering if brake caliper grease would be a good option for the pilot bearing and the input shaft splines.
Thanks
Mathieu |
Sodo Samba Member
Posted: Wed Mar 27, 2024 3:54 pm Post subject: Re: 1991 Syncro Engine Drop |
It's been 25 years since I've had a needle-pilot-bearing.... so I've forgotten.
Yes caliper-pin grease sounds better.
But don't ask me
AllRad Samba Member
Posted: Fri Mar 29, 2024 11:39 am Post subject: Re: 1991 Syncro Engine Drop |
What I thought was transmission fluid that had baked onto the inside of the bell housing, turns out to have been (mostly) paint. In addition to the black paint, there was grease and trans fluid present. I don't think there should be any at all, because it could get onto the clutch...right? In any case, I decided to clean it.
Anything worth doing is worth overdoing.
[/img] |
Sodo Samba Member
Posted: Fri Mar 29, 2024 11:54 am Post subject: Re: 1991 Syncro Engine Drop |
If you have time to overdo, slide that clutch fork to the left/right and add grease in the pivots. Or at least try to discern whether it needs to be greased.
And the noses of the clutch fork should be “round and equal” to release the clutch smoothly across its arc of motion.
Flat noses may cause a jerky clutch if the “corner” of the flat spot is at the “wrong place” while the clutch is “feathering “.
If the noses are round then the clutch fork could be “new”. _________________
markswagen Samba Member
Joined: January 28, 2018 Posts: 1039 Location: san diego
Posted: Fri Mar 29, 2024 12:13 pm Post subject: Re: 1991 Syncro Engine Drop |
do you do houses, mine is not as clean as the inside of that belhousing.
AllRad wrote: |
[/img] |
_________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Fri Mar 29, 2024 5:11 pm Post subject: Re: 1991 Syncro Engine Drop |
It seems to be about 50/50 whether a bellhousing will be dry or oily. Typically the oil never reaches the clutch lining though, but that is always a possibility. Oil on the disc tends to darken it. Do both sides of the disc friction surface look the same?
I agree that you clutch components look basically new wear wise. You input shaft should have had a light smear of grease on the splines and on the pilot, and the face of the throw out bearing should have had a light smear of crease as well.
There should be a drain for the bellhousing right where the engine case halves meet, so clean this area well. I have drilled and extra drain hole in the bellhousing before to help oil drain. |
AllRad Samba Member
Posted: Sat Mar 30, 2024 7:17 am Post subject: Re: 1991 Syncro Engine Drop |
Both sides of the clutch look the same. The fingers are uniform and look like they should. So, I’ll be reusing it, after adding grease to the splines and working some into the pilot bearing.
However, I think it might be time to replace the shaft with the forks. The forks look pretty flat.
Looking around, I discovered a wide range in pricing. Advice on where to source a good replacement would be welcomed! |
Sodo Samba Member
Posted: Sat Mar 30, 2024 7:54 am Post subject: Re: 1991 Syncro Engine Drop |
That's not too bad.
Could probably round the 'corners' a little and then replace it at the next clutch if confident in your metal-work abilities.
Try to create "the same arc" on left and right
Here's a couple threads discussing clutches:
Look at my clutch!
Clutch fork removal issues and questions _________________
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4099 Location: East Kootenay, British Columbia
Posted: Sat Mar 30, 2024 11:35 am Post subject: Re: 1991 Syncro Engine Drop |
Depending on your budget and time - I would replace that shaft now while you have it out.
Here's a picture of an original cross shaft in good condition (on right, one on left is cheap-o crap)You can see how much more material there is compared to yours.
As for where to buy, I would recommend Weddle. They have their version of a fairly priced HD version ($40), and also have in stock VW OEM shafts ($128).
GW sells that same HD shaft from Weddle for $119!
https://weddleindustries.com/products/091-141-701-HD/091-141-701-HD
https://weddleindustries.com/products/091-141-701/091-141-701
https://gowesty.com/products/clutch-cross-shaft-heavy-duty?_pos=21&_sid=d44d3ba41&_ss=r
Personally I would spring for the VW shaft, no idea how long those $40 shafts will last. Depends on the steel used and the heat treating of the wear surface.
You can see the "blueing" on the original shaft pictured above.
(that shaft had 112,000 miles on it and I put it back in and now closing in on 200,000 miles) _________________ Currently:
