MTT3107 Samba Member
Posted: Mon Apr 01, 2024 2:28 pm Post subject: 1835 cc engine build |
So, I ordered all the parts for the 1835 cc engine I want to build, got most of the stuff from CB Performance.
Plan is for a 1835 cc engine, 69mm stroke, 92mm thick wall cylinders.
And this is where my first question comes.
Ordered the case from them, and had it machined by them to 94mm with standard deck height.
Received the case and cylinders from them, and did a test fit of the cylinders in the case, and noticed that they don't slip all the way in.
Other engines I have built, cylinders slip right in, and are actually a bit loose.
I don't think this is normal.
If it's normal, fine, but if it's not, what do I do about it ?
I'm in KY, so I wouldn't want to send the case back to them in CA.
I also e-mailed them about this, but no answer yet.
Here some pictures.
Opening in the case, is that not supposed to be machined all the way down ?
Here 2 pictures of the cylinder in the case, you can see it is not bottomed out.
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3301 Location: Rapid City, SD
Posted: Mon Apr 01, 2024 2:38 pm Post subject: Re: 1835 cc engine build |
Figure out if they are hitting the step in the case, or if the larger diameter on the cylinder is too large. I had to turn a set of the cylinder bases down recently to make them fit in the case.
Brian _________________ www.type-emotorsports.com |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3334 Location: 802 The Pointless Forrest
Posted: Mon Apr 01, 2024 2:41 pm Post subject: Re: 1835 cc engine build |
if he bought all that from CB , should'nt they have test fitted the parts? _________________ "Albatross"! |
Posted: Mon Apr 01, 2024 2:42 pm Post subject: Re: 1835 cc engine build |
Not a chance.
They grab parts off a shelf, put labels on them, and send them out the door.
BFB Samba Member
Posted: Mon Apr 01, 2024 3:12 pm Post subject: Re: 1835 cc engine build |
That depends on what you order and what you’re paying to have done. I mean ive had them port match intakes before and they did a great job, even numbered the head & corresponding intake. Ive had several heads cnc’ed and fly cut to my specs, so none of that is just pulled off the shelf & shipped..
Did OP measure his cylinders or just assume they were 94mm o.d. ? Were spigots cut to OP’s specifications of 94mm or were they requested to be cut to fit c.b.’s 92’s? _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
Posted: Mon Apr 01, 2024 3:30 pm Post subject: Re: 1835 cc engine build |
I ordered the "1156 White Rhino Aluminum super case 94mm bore std deck" with case savers installed, from them.
It is my understanding that that is what you need for the 92mm piston/thick wall cylinders.
And I ordered the cylinders/pistons in the same order.
At the time I also ordered the camshaft, and was told that camshafts and cases are prepped to order and would take 2-4 weeks to be delivered.
And they shipped after exactly 4 weeks. |
BFB Samba Member
Posted: Mon Apr 01, 2024 3:36 pm Post subject: Re: 1835 cc engine build |
MTT3107 wrote: |
Well then, youd think they should fit. I know sometimes it can take them a couple days to reply to emails and then if they haven’t I’ll send a follow up. They typically respond. Ive never been unhappy with their customer service _________________ Forced induction can overcome a lot of obsticles that gets in it's way
Posted: Mon Apr 01, 2024 3:45 pm Post subject: Re: 1835 cc engine build |
So, went at it again and took some measurements.
The machined part in the case is machined to a depth of 19.3 mm
The part of the cylinder from the edge to the step is only 9.5 mm, so it's not that the cylinder is bottoming out on the step in the case.
I then measured the diameters, the bore in the case is 97.11 mm , and the outer diameter of the cylinder is 96.9 mm at the bottom.
But the area above the step has a diameter of 97.6 mm, so there's the problem.
Brian_e was right, I will have to find a machine shop to get the outer diameter of the cylinder above the step turned down a tiny bit.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31406 Location: Hot Arizona
Posted: Mon Apr 01, 2024 4:37 pm Post subject: Re: 1835 cc engine build |
I am assuming they are AA P&C's?
I never bothered to see if it was the case or the cylinder that was the problem, I just fixed it quickly, and continued on with the build.
I don't think CB had anything to do with it being wrong. They order the cases from Autolinea in either 90.5, or 94mm bore. They come from the factory with the cylinder holes bored to size. CB is just re-selling them. Same with the cylinders.
Posted: Mon Apr 01, 2024 5:34 pm Post subject: Re: 1835 cc engine build |
Yes, AA p&c’s
I reached out tothe local VW group, looks like somebody can do this for me.
Thanks for all your input ! |
Posted: Mon Apr 22, 2024 10:29 am Post subject: Re: 1835 cc engine build |
Just wanted to bring this thread to an end..
The problem was the step on the cylinders, prevented them from going all the way in.
Had the barrels machined, eliminating the step, and its all good now. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9673 Location: Pearl River, NY
Posted: Mon Apr 22, 2024 4:57 pm Post subject: Re: 1835 cc engine build |
Now that the cylinders are sitting fully in the case opening, were you able to measure your deck height yet? |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3457 Location: San Diego
Posted: Mon Apr 22, 2024 5:17 pm Post subject: Re: 1835 cc engine build |
Is the step in the cylinder in order to register the cylinder in the bore more accurately now?
Good example of why everything needs checked, fitted |
