Davecal Samba Member
Joined: March 29, 2024 Posts: 9 Location: Connecticut
Posted: Tue Apr 16, 2024 7:31 am Post subject: Reverse Light Harness |
This car is still very new to me so trying to correct some wiring issues…sloppy people and a few things need re-wiring.
Is this the harness for the reverse lights? The wires on the transmission switch are missing and there’s no wire or inline fuse running from the coil.
1971 Super Beetle. Thank you
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1385 Location: Wichita, KS
Posted: Tue Apr 16, 2024 7:43 am Post subject: Re: Reverse Light Harness |
Davecal wrote: |
Is this the harness for the reverse lights? The wires on the transmission switch are missing and there’s no wire or inline fuse running from the coil. 1971 Super Beetle. Thank you |
Yes, that's the connector that goes to the reverse lights. You'll have to add the other wires you noted in your original post (i.e. a wire w/ inline fuse from coil to backup light switch on transmission, and another wire from that switch to the backup lights terminal in your picture). _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Posted: Tue Apr 16, 2024 9:25 am Post subject: Re: Reverse Light Harness |
Perfect, that’s what I was hoping just wanted to be sure.
Thank you |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 640 Location: Louisiana
Posted: Tue Apr 16, 2024 9:49 am Post subject: Re: Reverse Light Harness |
Single wire from coil thru 8amp fuse along top of fan housing routes with Gen/Alt wiring then around fan housing (YELLOW)
Then 2 wires thru grommet in front engine tin to reverse switch (GREEN)
If you don’t have grommet, slip between engine tin and front engine bay seal.
The return wire from reverse switch then goes to wiring “T” feeding both backup lights (RED), which are behind front tar board.
Good Luck _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
Posted: Tue Apr 16, 2024 12:28 pm Post subject: Re: Reverse Light Harness |
Thank you!
Any know what gauge wire to run? Everything is missing on mine except this connector |
Posted: Tue Apr 16, 2024 12:48 pm Post subject: Re: Reverse Light Harness |
Davecal wrote: |
Thank you!
Official factory wiring diagram for 1971 Super Beetle is shown here:
https://www.thesamba.com/vw/archives/info/wiring/bug_super_8_70.jpg
Wire sizes (in mm˛) are shown for each wire on the diagram. Wiring for the backup lighting circuit seems to show 1.5 mm˛ size for the wiring you're wanting to add, which roughly corresponds to 16 AWG (I think - you may want to double check on that). _________________ 1971 Standard Beetle — fairly stock / driver
