Beskucnica Samba Member
Joined: April 18, 2024 Posts: 6 Location: Europe Balcan
Posted: Fri Apr 19, 2024 8:32 pm Post subject: Indystrial engine typ 122 questions |
Greetings people, I'm calling from Europe country Serbia, I assume that most of the you are associated that with Novak Djokovic or vice versa
I apologize in advance for my imperfect English
I comunicated with guy , he have a vw engine on offer, the price is favorable, he also had another one but he sold it to someone else and if I offered him a buyout, it was not very fair to me
My question is how do they compare
Can that also work without car batterie?
What is needed to test such an engine, I don't know, he told to me that he didn't test it, maybe he's just lying?
My father and grandfather have always been fans of VW, I have a old single cab van fom 60s, that was sold to a friend who will fix it, but it won't start for at least 2 years, so until then it's with me and I live in the vilage and I planned to put that engine in the van and to drive through forests and fields
Engine pictures:
And the first engine that he sold for other one, he seait that this working excelent:
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2768 Location: Hamble, Hampshire, UK
Posted: Sat Apr 20, 2024 12:06 am Post subject: Re: Indystrial engine typ 122 questions |
Yes, that is a set of photographs of an apparently complete set of parts that appear to be an engine.
If you can turn it over by hand a complete rotation and can feel and hear changes in the air compressing in the cylinders it may really be an engine.
It has a magneto so does not need a battery to run but it still needs a battery to start it.
It is going to be a lottery if you buy it, do not pay a lot.
Imagine it as a box of parts, it may have been damaged and removed from a vehicle, or it may have been used in e.g. a water pump and abandoned, e.g. a fire engine water pump, or the vehicle it was in corroded away, so it might only need new fuel hoses and some fresh fuel and oil.
It is less likely to be full of water because there is no path for rain to get in and it looks old and dirty and not corroded.
I would focus first on why the engine you already have does not run, as not starting for 2 years is less time not starting than the engine you are thinking of buying.
If your existing engine was damaged and failed, that is different to failing to start because it has been a long time since it last ran. _________________ Ancient vehicles and vessels
Posted: Sat Apr 20, 2024 1:29 am Post subject: Re: Indystrial engine typ 122 questions |
Thanks for reply man.
Yes, that he told me that he got those engines from a fire truck, with the fact that the one with the Ronco magneto worked very little hours, bat he sold them.
Now there is no engine on my van, it hasn't started in about 15 years and I think that's when my father sold the engine. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12846 Location: Western Canada
Posted: Sat Apr 20, 2024 4:48 am Post subject: Re: Indystrial engine typ 122 questions |
Yes it will run without a battery and if you have or can make a hand crank it will not need a battery and starter to start it either. Those engines have a crank nut on the pulley end for that purpose.
Bare in mind that those are 1132cc 25 HP engines and will be grossly under powered by today's standards. The original engine in your truck/van would have been a 1200cc 36 HP one. Someone restoring a early 1950's VW might pay good money for one of those engines, they are rare as hen's teeth!
Those industrial engines were built to be out in the weather so unless someone has left parts off there should not be any water in them. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Sat Apr 20, 2024 7:35 am Post subject: Re: Indystrial engine typ 122 questions |
I think that I saw on engine plate this is 23kW on engine with Ronco magneto. I see nut for crank on bouth, one have and crank. In my countru in Serbia there are 1200cc engines on ads, they not that rare, some of them sells in Western Europe and more.
I am now in depresion when I remember what I have when I was child my father and grandpa have several beetles, karman ghia, this van who I was tolking about, and one T2 from 70s, ali of this sold in early 2000s for cheap for nothing. This T2 was in perfecly good condition, he has 1600cc engine that looks like new, huuuuh man. I will create new threads about them, add some pictures, but next week. |
EVfun Samba Member
Posted: Sat Apr 20, 2024 7:55 am Post subject: Re: Indystrial engine typ 122 questions |
Beskucnica wrote: |
It appears to be a 40 horsepower (European rating was 34 HP) 1200 engine. The stated power, 23kW, would be 31 horsepower so perhaps it is a low compression version. It has a removable generator stand so it isn't an older 25 or 36 horse engine. _________________
Wildthings wrote: |
oprn Samba Member
Posted: Sat Apr 20, 2024 3:50 pm Post subject: Re: Indystrial engine typ 122 questions |
The ID tag says 1132cc. But if you go by the generator tower it looks like the 40 HP.
...or is the 1192cc? That does make more sense. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Wed Apr 24, 2024 8:39 pm Post subject: Re: Indystrial engine typ 122 questions |
Bouth of this two engines are 1192 ccm
I bought this another one for about 250 eur, I can not wait its come to me, to try this for this money and if there is something to fix I think I am satisfied. |
Posted: Sat Apr 27, 2024 1:45 am Post subject: Re: Indystrial engine typ 122 questions |
The engine is arrived to me, and now I would like to try it.
It has ignition coil that is conected to magneto
One cable from ignition coil goes begind, and other cale goes to magneto here
And and also one cable from here going behind
Begind are some other cables from dinamo
Engine is comes with crank puller, what I need to try it, something to wire, battery, whats is the proces, thanks |
Posted: Sat Apr 27, 2024 1:51 am Post subject: Re: Indystrial engine typ 122 questions |
And behind is cable conected to engine like ground or negativ side to battery with clamp conector |
