margard8 Samba Member
Posted: Sat Apr 20, 2024 6:34 am Post subject: starter problem |
Hello, I need help, 1 just bought a 1970 bug, and the starter went out all ready ordered a new one, but mine has a short shaft , and it seems all they sell is long shaft starter, thanks for any help |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31406 Location: Hot Arizona
Posted: Sat Apr 20, 2024 7:24 am Post subject: Re: starter problem |
margard8 wrote: |
Does the existing starter look like the one on the top left? That is an autostick starter.
And your new starter looks like the one in the bottom right? That would be a typical starter for a 1967-on VW with manual transmission.
However, an autostick starter can be simply bolted in to replace the typical starter, it offers a little more power and does NOT require a bushing in the transmission, as it's self-supported. So if that's the case, someone either wanted more power or didn't want to replace the transmission bushing.
So if your existing one looks like an autostick starter, I'd return the new one and get an autostick starter for yours, then you wouldn't need to worry if your transmission bushing was OK. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Apr 20, 2024 8:08 am Post subject: Re: starter problem |
Yep thats it, in the parts book is it called an automatic trany ?? Thanks alot for your help |
Cusser Samba Member
Posted: Sat Apr 20, 2024 8:11 am Post subject: Re: starter problem |
margard8 wrote: |
Yes, called a starter for an automatic transmission.
I recommended to purchase starter for automatic transmission so if the transmission bushing is missing, worn, or even the transmission housing for such is bad, you wouldn't have to deal with that. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Apr 20, 2024 8:59 am Post subject: Re: starter problem |
Thank you |
Posted: Sat Apr 20, 2024 9:54 am Post subject: Re: starter problem |
ok, sorry to be a pain, but any ideea where to get one, they all seem to be on back order |
OldSchoolVW's Samba Member
Posted: Sat Apr 20, 2024 10:24 am Post subject: Re: starter problem |
Just curious ... how did you conclude that the old starter was bad?
Assuming that it does need to be replaced ...
(You may want to have a seat before checking these links.)
https://www.jbugs.com/product/SR17X.html
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=003911023B
You could check your local NAPA. Specify that it needs to be the SR17X starter. _________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Cusser Samba Member
Posted: Sat Apr 20, 2024 12:26 pm Post subject: Re: starter problem |
OldSchoolVW's wrote: |
Just curious ... how did you conclude that the old starter was bad? |
I wasn't even going to travel that road with margard8. But in my 5 decades experience I find way more "failure to crank" issues with battery and dirty/loose/bad connections than with the starters. Here we TEST, we just don't throw parts in and hope.
I've had my 1970 since 1972, and my 1971 since 1976, and both have run on their second starter for over 3 decades. I used genuine "rebuilt by Bosch" starters, not sure such are available these days. And yes, my starters each use the bushing, replaced for first time in my 1970 in 2016-2017 and my 1971 is on its factory starter bushing. Note that if either starter ever goes out, I may upgrade to the self-supported autostick starter.
My first way to check for a bad battery is to try a jump start from another vehicle; if it starts, suspect the battery !!!! Second way is to measure voltage across battery terminals while 5 seconds in trying to crank the engine. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3608 Location: viroqua wi.
Posted: Sat Apr 20, 2024 1:36 pm Post subject: Re: starter problem |
margard8 wrote: |
Did you call your FLAPS ? Oreilly's, Auto zone, Car quest. |
Posted: Sat Apr 20, 2024 1:43 pm Post subject: Re: starter problem |
yes I did test the starter, its shot, |
Posted: Sat Apr 20, 2024 2:00 pm Post subject: Re: starter problem |
I have been a Harley mechanic for about 40 years, I am new with bugs, but yes the starter is shot |
Cusser Samba Member
Posted: Sat Apr 20, 2024 4:33 pm Post subject: Re: starter problem |
bsairhead wrote: |
margard8 wrote: |
I see four brands for automatics listed in stock at RockAuto from $45 to $70.
https://www.rockauto.com/en/catalog/volkswagen,197...motor,4152 _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
glutamodo The Android
Joined: July 13, 2004 Posts: 26335 Location: Douglas, WY
Posted: Sat Apr 20, 2024 5:16 pm Post subject: Re: starter problem |
Autostick starters are well known for having wonky solenoids while the starter motor itself is just fine... the autostick starter motor is pretty robust.
I went through a couple such bad solenoids during the many years I drove my Baja Bug with an Autostick starter (that is still) on it. _________________ Andy T.
