UND_Sioux Samba Member
Joined: December 09, 2023 Posts: 3 Location: Montgomery, TX
Posted: Thu Apr 25, 2024 1:56 pm Post subject: Floor Pan mounting Flange (perimeter) Height |
Hello,
If someone that has their buggy body off on a stock (or shortened) floor pan; would you mind measuring the approximate height (thickness) of the outer flange of the steel floor pan that mounts to the body? Thanks. |
EVfun Samba Member
Posted: Thu Apr 25, 2024 2:12 pm Post subject: Re: Floor Pan mounting Flange (perimeter) Height |
3/4 inch up from the floor height. I used .062 wall .75 inch square tube to form the perimeter on my hand built floors. _________________
Wildthings wrote: |
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 648 Location: Reno NV
Posted: Fri Apr 26, 2024 6:33 pm Post subject: Re: Floor Pan mounting Flange (perimeter) Height |
I cut the outside off and used 1x3 to make a outside frame
_________________ Halfass Leatherworks*****GOT LEATHER Made to order Leather crafts, you can find us on that face book thing
Belts, wallets, mouse pads, drink coasters, Engraving, most things made in leather.
personal items if you want it in leather in Reno Nv, ***** |
DeathBySnuSnu Samba Member
Posted: Sat Apr 27, 2024 10:40 am Post subject: Re: Floor Pan mounting Flange (perimeter) Height |
I don't know what body you are working with..... but..... if you are making the perimeter anyway you could raise/lower the body.... or as I did, tilt the body nose down. Mine is 2-3 inches wedged nose down just for the sake of looks (and for a little v engine to fit mostly under)
But anyway ..... if you are making it..... now's the time. _________________
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
