What size tires to buy?
Big Fat
Big Fat is offline
PostPosted: Tue Sep 07, 2004 7:11 am    Post subject: What size tires to buy? Reply with quote
Right now I've got 185/65R15s on my '67 Square, I'm not sure how many notches it's been lowered, but I'd like to go down a bit further.
The backs seem fine for clearance and the fronts are super close - they rub when you turn though.
I'm wondering what the best compromise would be in size - I don't want to lose too much driving ability, but I want to be able to drop it down a bit more and retain the ability to turn.
So... 165s? 155s?
Thanks!
Ice Blue '67 Squareback
Critter1
Critter1 is offline
PostPosted: Tue Sep 07, 2004 8:01 am    Post subject: Reply with quote
My fastback is lowered two notches up front with 145's. No rubbing and it drives fine. I have also seen 195/50/15's on a lot of Type 3's (up front), but that is with 5.5" wide rims. My rims are stock 4.5 so the 195/50's are to wide for the rim.
Justin
Air-Cooled Head
Air-Cooled Head is offline
PostPosted: Tue Sep 07, 2004 8:54 am    Post subject: Reply with quote
Try some 185/55s up front. That's a pretty short tire and will bring it down some. I'm down at least 3 in front, and 185/55s just clear.
Everything known to man has been written.
Readers are Leaders!
Big Fat
Big Fat is offline
PostPosted: Tue Sep 07, 2004 9:57 am    Post subject: Reply with quote
Are you speaking of going to that size to visually lower the car or to counter the rubbing problem? As it is my setup only rubs on turns - but I'd like to go a tad lower without rubbing. Would the 55s let me do this?
Air-Cooled Head
PostPosted: Tue Sep 07, 2004 12:37 pm    Post subject: Reply with quote
Both! My car was slammed when I bought it, with 135's up front. Even with the 135s, I'd still get some rub on turns. I mounted 2 liter rims w/ 165s, and could not turn, at all. Mad I mounted 185/55s on the 2 liters, and no rub! Cool
And it looks even lower too!
Now that you made me do the math, we're talking roughly 1.25" diff in height, between 185/65 & 185/55. Will 1-1/4 inch resolve your rub?
1500 russell
1500 russell is offline
PostPosted: Tue Sep 07, 2004 12:54 pm    Post subject: Reply with quote
I run 195/ 65 on the rear and 135's up front .
The hot new tire to run up front is 175 /55 I think
low pro and wider then 135's
Big Fat
Big Fat is offline
PostPosted: Tue Sep 07, 2004 1:21 pm    Post subject: Reply with quote
Hmm, that I'll have to check, maybe I could take some pictures or something - but it sounds like it might work. I'd like to lose as little width as possible, so perhaps this is the best option. For what it's worth, I've got EMPI wide-5 5 spoke wheels - any chance this is part of the potential problem? I've heard their offset can be a bit of an issue.
Air-Cooled Head
PostPosted: Tue Sep 07, 2004 3:21 pm    Post subject: Reply with quote
I haven't heard that, (since I've got 4 lug, I wasn't listening) but I don't know what the offset is. There's a guy over on VWType3.Org, John J, that runs those wheels. Maybe you can contact him for advice.
So I came home and took some pics. Wink They suck from my home PC, so I'll post some better Wed.
But here you can see, it's down but I still can turn Very Happy
Big Fat
Big Fat is offline
PostPosted: Wed Sep 08, 2004 7:15 am    Post subject: Reply with quote
Wow, looks good... nice Notch! Your setup looks a LOT different than mine - the 55 series tires seem to make a world of difference. I posted on the list to get a second opinion but it looks like I'll probably be going with this size.
Air-Cooled Head
PostPosted: Wed Sep 08, 2004 9:51 am    Post subject: Reply with quote
Thanks for the compliment. I posted some more pictures.
My Squareback is down 2 clicks, and I can still turn w/ 165s, so I'd say the Notch is down at least 3, maybe 4.
Now that I'm looking at it, I wonder if a full tank of gas will cause it to rub? Shocked
Big Fat
Big Fat is offline
PostPosted: Wed Sep 08, 2004 10:23 am    Post subject: Reply with quote
Wow, again... really nice cars. Smile
Your Squareback looks to be about the same height as mine - so with your tires being 165 it's obvious why mine is rubbing. Wink
I just noticed you run "stock 165s" on the back of your Notch - is it ok to run larger (width) tires upfront? I'd realistically like to run the same size all around, and if 185/55s will fit up front, I'd guess they'll fit out back too.
Air-Cooled Head
PostPosted: Wed Sep 08, 2004 3:55 pm    Post subject: Reply with quote
That's a nice Square! Is that "Ice Blue"? It looks silver in the pics.
Actually, the 165s were on the rims when I bought them, so I just put 'em on the car. I had the 185s left over from another car, so I mounted 2 of them on the 2 liter rims, just to see how they fit. I've only driven around the neighborhood with the set-up you see now, and it feels no different. I plan on getting 185 or 195/60s or so for the rear.
Good luck w/ your tires, and let us know how it turns out.
lister
lister is offline
PostPosted: Wed Sep 08, 2004 9:07 pm    Post subject: Reply with quote
I just want to piggy back ride on this wheel issue for one more question: I recently changed my set up too, got the stock rims and tires off I went w/ 195'a in the back and 145's up front.... I noticed a change in handeling and power?/???// am I nuts? or is this typical? Laughing
Always looking to trade for an early square...
Air-Cooled Head
PostPosted: Thu Sep 09, 2004 11:12 am    Post subject: Reply with quote
Personally, I don't like 135s or 145s; just too skinny for my taste. Shame on you And in the rain, Shocked
Depending on the aspect ratio (the second number in the tire size) the tire could be shorter (or even taller) than stock, which would affect speedo reading/engine RPM relationship.
seans67
seans67 is offline
PostPosted: Sat Apr 02, 2005 2:04 pm    Post subject: All weather tires Reply with quote
Bumbing this thread cause there's some good info in here and it's nice to keep it all in one place.
I need to get tires for my 71 square with stock 15" steel rims. This car will be going to Alaska with me and driven most of the year. So I need a good all around tire that can handle the rain, mud, snow but be a good cruiser as well.
My local tire guy recommended Hancock (sp) 165/15 which is stock size right.
What do ya think?
Sean
'71 Squareback '71 Porsche 914 ‘80 Camper '87 Syncro Weekender 1.8T '87 Wolfsburg Weekender '97 Toyota Land Cruiser ‘03 Audi A6 Quattro 3.0 ‘04 Audi A4 Avant Quattro 1.8T ‘05 Audi A4 Quattro 3.0
‘06 Porsche Cayenne Turbo S
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Apr 02, 2005 2:21 pm    Post subject: Re: All weather tires Reply with quote
What do ya think?
I live in the upper mid-west in the snow belt. I drive a lot of gravel roads, which are hard on tires. I am running Cooper's 165R/15 SportMaster GLT M+S.
I run them year round, on road and off road, and have never had a problems with them. They are 4 years old, and still look almost new.
They are pretty quiet on the highway.
Gary: OK. Ima poop.
localboy
Samba Longboarder
localboy is offline
PostPosted: Sat Apr 02, 2005 8:03 pm    Post subject: Reply with quote
Did you try a search? there are numerous posting re: rim/tire size, offset etc. Rim offset can have a major effect on rubbing or not. Don't know much about wide 5 wheels as my '65s were modified to either 4 or Porsche pattern respectively...good luck.
One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project
