jardindelalma Samba Member
Posted: Thu Dec 02, 2004 7:57 pm Post subject: Reduction gear oil level? |
what is the correct oil level in the reduction gears.....i have a book that say .5 US Pint....seems like there would be some other method of telling.....
thanks!
P.S. if it matters i have a 65' |
Posted: Thu Dec 02, 2004 8:06 pm Post subject: |
i thought i remembered something about this...but to make sure...
the reduction gear oil and transmission oil level are one and the same....sould be cchecked with bus on all fours (as opposed to being jacked up) and should come to the bottom of the fill plug...
Correct????
thanks! |
Flipseat Samba Member
Joined: July 09, 2000 Posts: 1089 Location: Nursing 40 horses back to health.
Posted: Thu Dec 02, 2004 8:07 pm Post subject: |
Fill the trans until it comes out the fill hole. Thats how I do mine. _________________ Insert random important looking club initials here. |
UZI Platinum FUBU
Joined: February 08, 2002 Posts: 13335 Location: phila-DELFT-ia
Posted: Thu Dec 02, 2004 8:17 pm Post subject: |
when your changing the gear oil, you put the .5 pint in each RGB then fill the trans til it comes out the hole. remember it's the single fillhole is on the passenger side not the 2 plugs on the drivers side. you won't get any gear oil in that way. _________________ Extravagant Lifestyle
| Quote: |
| mannys66: South Philly Van Club, only the most influential and freshest van club in the vw scene |
| Quote: |
| Cuñado: Chrome will get you home!!!!!!!!!! |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71888 Location: Phoenix 602
Posted: Fri Dec 03, 2004 8:46 am Post subject: |
| UZI wrote: |
| when your changing the gear oil, you put the .5 pint in each RGB then fill the trans til it comes out the hole. remember it's the single fillhole is on the passenger side not the 2 plugs on the drivers side. you won't get any gear oil in that way. |
I think that is splitcase tranny only _________________ How to Post Photos
UZI Platinum FUBU
Posted: Fri Dec 03, 2004 9:44 am Post subject: |
| EverettB wrote: |
| UZI wrote: |
I think that is splitcase tranny only |
makes sense, it was most recently that i was under the king panel. _________________ Extravagant Lifestyle
| Quote: |
| Quote: |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26261 Location: Olympia Wash Rinse & Repeat
Posted: Fri Dec 03, 2004 7:20 pm Post subject: Re: reduction gear oil level??? |
| jardindelalma wrote: |
thanks!
Hi Joshua,
When you change the gear oil, fill the RGBs first. Then fill the center section. When filling this, the gear oil will fill the top of the RGBs and the axle tubes. If you end up with a gear oil leak about the upper 1/3 of the center section gear oil drains down through the axle tubes to the RGBs to keep them filled. Hopefully long enough for you to notice the leak before it becomes a danger when that RGB runs dry and the bearings sieze!
On long trips when we get out of the bus. We take a walk around it to look for any fluid leaks and have caught a few that could have been disastorous, but were an easy fix instead.
Eric&Barb |
