Front Door Hinges
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Sun Jan 02, 2005 6:02 pm    Post subject: Front Door Hinges Reply with quote
Guys
I did a search, but I could not find a specific answer to my simple question.
What is the best way to remove the front door hinge pins?
I aquired a passenger side mirror that I wish to install, but I want to be clear on pin removal before I start beating on it like a mad man.
Thanks
Very Happy
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
vwjosh6070
Driveway Camper
vwjosh6070 is offline
PostPosted: Sun Jan 02, 2005 6:18 pm    Post subject: Reply with quote
i just drilled the pin out.... but make sure you go in straight! (ask me what happens). i ended up having to change the hinge out because it got drilled. with the new hinge i got, it also had a pin in it, i just heated it up, put crap loads of some armorall lube stuff, and got a pointed chisel like thingie and beat the pin out with a hammer. good luck on it.
josh, AKA "the infamous josh"
1973 Transporter "Floyd"
****Wheres my old bus?! 1967 Montgomery Ward Camper****
KI4MXO
Mr. Electric Wizard
Mr. Electric Wizard is offline
PostPosted: Sun Jan 02, 2005 6:22 pm    Post subject: Reply with quote
Seriously, the easiest way is with an air hammer...
It made real easy work of it! Smile
"Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper
Riff Raff
Shivering Sambian
PostPosted: Sun Jan 02, 2005 6:40 pm    Post subject: Reply with quote
My next door neighbour (bless his soul) has an air chisel and air. We can load a drift into the air chisel.
So do we just line up the drift and beat it up and out?
That easy (and that tough?)
- Daniel Boorstin
Mr. Electric Wizard
PostPosted: Sun Jan 02, 2005 6:57 pm    Post subject: Reply with quote
I don't know about an air chisel, but if you have an attachment that is smaller than the size of the pin, then I'd go for it.
When I did mine, I took my door off and turned it over. Then put the hinge in a vice and let 'er rip...
Good Luck!
~ Cullen Hightower
Riff Raff
Shivering Sambian
PostPosted: Sun Jan 02, 2005 7:01 pm    Post subject: Reply with quote
Thanks for the sage advice!
Tomorrow night, we drift!!
Very Happy
- Daniel Boorstin
BryanM
BryanM is offline
PostPosted: Sun Jan 02, 2005 8:32 pm    Post subject: Reply with quote
soak the hinge with penetrating oil. I use Marvel Mystery oil.
I removed my door and placed the hinge on a block before hammering the pin out. that way I lessened the chance of loosinging the hinge where it mounts to the door.
-Bryan
Motorwagen LLC
Concord NC
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
dstefun
dstefun is offline
PostPosted: Sun Jan 02, 2005 10:33 pm    Post subject: Reply with quote
Start with lots of Kroil, WD-40, or your favorite rust zapper. Soak, soak, and soak some more. If keeping the paint is not a problem, apply heat (such as propane torch) to the hinge. On mine I ground off the head of the old hinge pin (zapped part of the paint too Sad) so I had a flat surface, pounded it down about 1/16" with a nice new flat punch, soaked it some more, and then pounded it up from the bottom. Repeated that a few times and it finally came right out. Damn tight! Lots of noise, the neighbors love it! Air hammer would have been a plus! It comes out the top due to the knurling at the top of the pin, don't try to hammer it down and out if you grind off the head. Good luck!! Mad-mas:
ToolBox
ToolBox is offline
PostPosted: Mon Jan 03, 2005 4:21 pm    Post subject: Reply with quote
An old fuel pump push rod work pretty damn good. On my 59 I soaked the hinge for a week and the pin came out rather easy with a 20oz ball pein.
derv
derv is offline
PostPosted: Thu Nov 02, 2006 3:21 pm    Post subject: Reply with quote
Older post...but lemmie get this straight.
I am adding a pass side mirror on the Kombi, it currently has a hinge pin in it.
So I should soak it, then hammer at it with a drift from the underside of the hinge and hammer the pin out the top?
Jack
Mr. Hido: To post your bare ass to virtually all hardened bus enthusiasts casts thick, a slag not easily ground smooth.
Riff Raff
Shivering Sambian
PostPosted: Thu Nov 02, 2006 3:32 pm    Post subject: Reply with quote
You can do it that way, but an air chisel with a drift is really the way to go. When I did mine (at the time of this post) it took a couple seconds with the air chisel, no smacked knuckles, no missed swings, it was quick and painless.
- Daniel Boorstin
derv
derv is offline
PostPosted: Thu Nov 02, 2006 3:44 pm    Post subject: Reply with quote
I've got a body shop right across the street, so I guess I will bug them for a few dollars to get that sucka out for me with a chisel.
Thanks!
Jack
Riff Raff
Shivering Sambian
PostPosted: Thu Nov 02, 2006 3:47 pm    Post subject: Reply with quote
Thanks!
Well, air chisel as the tool, but with a small drift for an attachment.
- Daniel Boorstin
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Thu Nov 02, 2006 5:05 pm    Post subject: Reply with quote
imho i would remove the door and support the hinge as you do all this beating. we usually turn the door upside down and place the hinge on the edge of a vise. some patina'd 50+ year old doors might not like the abuse of hammering. cool mirror could = saggy door. there is a press made to do this job on the car if you have a paint job to save
http://www.eastwoodco.com/jump.jsp?itemID=1689&itemType=PRODUCT
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1957 oval
http://www.thesamba.com/vw/forum/viewtopic.php?t=426468&postdays=0&postorder=asc&start=0
1957 dd kombi
http://www.thesamba.com/vw/forum/viewtopic.php?t=186478&highlight=
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Thu Nov 02, 2006 5:10 pm    Post subject: Reply with quote
Removed ours in place with Kroil, a long drift and a mini-sledgehammer, in order to install mirror arms. It worked better to get them moving with the hammer and drift, and then finish the job with the air hammer. The problem with the air hammer is that things happen fast when you hit the trigger, and you stand a very good chance of air-hammering the hinge body or part of the door. After the pin starts moving, then there is a cavity there to keep the air hammer drift from bouncing around.
arthurnugen
Location: The PNW, where "going green" means rolling with moss.
arthurnugen is offline
PostPosted: Thu Nov 02, 2006 7:51 pm    Post subject: Reply with quote
If you have access to a MIG, I'm telling you, weld a bead on the top of that pin. Then, it will slide right out with a drift! Easy as pie.
cdennisg wrote:
Lawyers don't deserve buses.
zozo wrote:
Don't worry too much. You can always trust a lawyer.
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke!
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Thu Nov 02, 2006 8:07 pm    Post subject: Reply with quote
very cool idea does it get hot enough to mess up the hinge paint
1958 custom camper
1957 oval
1957 dd kombi
arthurnugen
PostPosted: Thu Nov 02, 2006 10:27 pm    Post subject: Reply with quote
Yes, a little, but you have to be careful! A lot of indiscriminate pounding with a drift or hammer will screw up the paint, too. Spray it with your favorite penetrant, wait a day, weld a (small) bead, and pound it!
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
Chick Iverson
Chick Iverson is offline
PostPosted: Sat Nov 04, 2006 12:18 pm    Post subject: Reply with quote
I took mine to a local body shop and they knocked out the pin in seconds for a ten spot..........EZ
'59 Euro convertible--'56 type 2 double door panel w/Chick Iverson logo-....2 wrongs don't make a right, but 3 lefts do!
busdaddy
busdaddy is offline
PostPosted: Sat Nov 04, 2006 1:46 pm    Post subject: Reply with quote
An air hammer is probably the best solution but make sure you back it up with something heavy, otherwise you move the pin and the hinge too, very bad. 2-3 feet of 3/4' water pipe would make a good bucking bar to hold firmly against the opposite end of the hinge from the hammer.
