jw Samba Member
Posted: Thu Feb 22, 2007 6:13 pm Post subject: Swing to IRS w/wide 5 |
Has this been covered?
I am thinking of converting to IRS so I dont wear tires/get the stupid NC look when lowered. Iv'e seen several great threads on converting to IRS, but I want to keep the early bolt pattern. Are there any special parts I should be getting? Or can i bolt up my back plates and drums and be down the road? I have no experince with the IRS cars, so I dont know exactly how it all bolts together.
thanks
jw |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Thu Feb 22, 2007 7:14 pm Post subject: |
According to the parts books, the rear should be a straight drum swap only. No need to switch anything else. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23525 Location: Kimball, Mi
Posted: Fri Feb 23, 2007 4:10 am Post subject: |
I think parts of it have covered. The drums swap over directly, without the need to change shoes or backing plates. But you'll need to do something about engine support, as the IRS uses the engine hanger bar, while the SA uses forks to support the trans. You can either weld on some forks to the IRS sub frame, or weld in some engine hanger support brackets to the body, and use a case with the 3 mounting lugs for the hanger bar. I hope this helps. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
aveyinc Samba Member
Joined: December 22, 2005 Posts: 737 Location: Northern Arizona
Posted: Fri Feb 23, 2007 11:49 am Post subject: Re: Swing to IRS w/wide 5 |
| jw wrote: |
thanks
jw |
Talk to Derrick about the 70... I dunno what the plans for it are, but it has an IRS tranny that worked before the engine was pulled. If you guys part it out, I want those wheels back though. If the car lives, the wheels stay with the car. _________________
GHOSTWAGENS!
WOMAN with short dirty nails! |
spoon Samba Penetrator
Joined: September 08, 2005 Posts: 1458 Location: Monterey, CA
Posted: Sat Feb 24, 2007 12:25 am Post subject: |
| Tram wrote: |
| According to the parts books, the rear should be a straight drum swap only. No need to switch anything else. |
So, you can just take a 5-bolt drum and mount that in place of the existing 4-bolt drums? I always was under the assumption that even the axles were different. Hmm... _________________ Pit Bull Myths, Busted!
http://www.badrap.org/monster-myths
| EverettB wrote: |
| Type 3 > Type 1 |
Posted: Sat Feb 24, 2007 12:34 pm Post subject: |
| spoon wrote: |
| Tram wrote: |
So, you can just take a 5-bolt drum and mount that in place of the existing 4-bolt drums? I always was under the assumption that even the axles were different. Hmm... |
You have to remove the 4 lug hubs with the drums. Then it's a direct swap. I think you're confusing using short t-1 axles here, as the 5 lug t-3 drum nose, or 4 lug hub nose needs to be trimmed 9/16ths of an inch for use with short t-1 axles. IRS stub axles however, are the same length as t-3 axles, and are a direct swap. My son converted his 76 bug to wide 5 using t-3 rear brakes, and earlier bug 5 lug drums. It was all a bolt on swap. The big problem comes from trying to convert the discs to 5 lug.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
jw Samba Member
Posted: Sat Feb 24, 2007 1:31 pm Post subject: |
BITCHIN!
I am thinking I will go with the weld on IRS hangers to the SA sub. Since I seem to have 2 extra laying around and dont want to weld engine supports to the body.
Avey- he said he was going to get in touch with you about the car. I have a roof clip and told him if he want it, its his if he can find me a fastback roof clip. but if he wants to part it then i want the irs and possibly pan sections. youll get the wheels no problem.
thanks
jw |
